Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic 56" projection color problems
The colors on my projection TV are off. As of lately, everything has a yellowish/greenish tint to it. The blue is extremely blue while the red is coming across as brown/dark brown. I've played around with the color, tint, brightness, etc. and nothing seems to be working.
Any suggestions?
    Problem Solver:
  • 6 Answers
There are so many technologies for the projection tv's ever one has their own caracteristic faults with out you mention the technoligy used on your tv will be deficult to help you but assuming is a lcd projection you must have a problem with the optical block the repair will be expesive if you do not have a manufactuer warranty for it
Posted on Feb 08, 2009
Picture is starting to get greenish, yellowish colored
hitachi model 51f510 projection tv has horizontal lines & has greenish tint,do i need to chang the bulbs??i alredy tryd the magic focus button & manual focus,but unsuccesfl,any ideas????
Nov 27, 2009 | Hitachi 51F510 51" Rear Projection...
Hitachi 50V710 Greenish Tint
Make sure that there is no Magnetic feild around the LCD
Sep 06, 2008 | Hitachi 50V710 50" Rear Projection...
Green Color Tint
I had a similar problem with my tv. Sometimes it depends where the tv is located, have you moved it? Magnesium in the earth caused my tv to have greanish tints in all four corners of my tv. Try moving your tv forward, backwards, or side to side. Let me know if this works.
Cynthia
Feb 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Color is a problem. Screen picture has greenish
well it seems you have an issue with one of your video boards, it could be that the Analog Video Board (the one with the inputs and outputs) is partially damaged, but it can also be your Digital Video Board, which is the one that projects the image
Jul 22, 2009 | Panasonic Televison & Video
Blue colors appear greenish in middle third of screen...there is a circle of yellowish green in the center of the screen
You have a bad optical block, the block has a 2 year warrnty but you will have to pay labor to have a tech change it
Aug 08, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Phillis 55pw9363 yellowish - greenish picture
cleaning the CRT lenses and mirror will help, however with that model I would suspect that the gree and blue CRT needs the coolanr changed to get a your color and clarity back. thats a common problem with all phillips rear projection TVs
Jun 13, 2008 | Philips 55PW9363 55" Rear Projection...
Tint on television stays a greenish color.
Tubes are probably dirty. Very expensive fix. Unless it has a warranty or is recently new, look for a local cheap one or one with a smashed screen of the same size. Easy to change the screens out and is very cost effective.
May 14, 2008 | Hitachi 50UX57B 50" Rear Projection...
Color problems
I have the same problem... today I got a digital satelite tech come out and hooked a HD digital reciever to the tv and now I have the greenish/yellowish/blue tint hhhmmmmmmm?
Mar 19, 2008 | Akai PDP4295ED 42 in. EDTV-Ready Plasma...
Mitsubishi CS-40707 Greenish/Yellowish Display
Yeah, I had mine checked for the same thing. The "blue" - There's only three - red yellow blue- portion of your tube died. Not repairable. Last I checked it costs at least $1,000 for a new 40 inch tube. Good luck. Mine went to the garbage dump!
Feb 25, 2008 | Mitsubishi CS-40707 40" TV
Greenish yellowish tint on the tv
I have been advised that the color/light engine of the TV fails often and will typically create a green tint on this unit. I have one on order to get a replacement installed. BTW, it is not "user serviceable" and (for me) will require moving the TV to the repair shop for the change-out.
Nov 11, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
181 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
