Question about Maytag MDBS561AWS Stainless Steel Dishwasher
Mdbs561awb i have no controls i changed the control panel and contol board but i have no controls
2 Suggested Answers
  • 523 Answers
SOURCE: controls not working, but panel is
touch pad
Posted on Jun 01, 2010
Nordic track a2050 contol console lights but controls do notvwork
Remove the control panel and try to clan the board using isopropyl alcohol using a brush. Leave the board for one day so that it would get dry. Then install the control board back and check and check it. Sometime moisture acclimated on the control panel can cause such problems . If you didn't get isopropyl alcohol then put the control board in sunlight for one or two days. Then install the control panel and check whether it works or not. also try to replace all the switches on control panel board. you will get it in any electronic spare parts shop.Beside not to put it on direct sunlight it can cause problems to the display
If you wish to get some more details about treadmill repair then check the following link.http://electro-medical.blogspot.com/
Aug 20, 2016 | Nordic Track Exercise & Fitness
Have can I change the shut down temprature on my hp dv5 1160 eg laptop?
If you can control the temperature it would be in the Bios, System Setup or Control Panel.
To get to the Bios or System Setup restart your laptop then watch the screen to see which key it says to hit to get into the Bios or System Setup and hit the key when the message appears.
To get into the Contol Panel, click Start/Control Panel or Start/Settings/Control Panel.
May 13, 2012 | Computers & Internet
My dryer is dead. I have ohmed out the cord and changed the dryer control board (8546219). Still dead, nothing at all. Any other ideas? I have checked the fuse and it is good. I had a local repair man look...
hello again,
no thier doesn't seem to big issue with with reconditioned control panels in fact i dare say yours is good since the dryer didnt start with the original one and still wont start with the one you have replaced. having checked teh thermal fuse to be good and with basically 2 control boards yet the dryer doesnt run it seems very possible the motor is going to be the problem...not sure what led ya to the control board yet it the drum doesnt turn the very part that turns it when power is applied to,if it has powewr to it and doesnt turn the drum it would seem to me its bad....dont get me wrong on this but its like having a broken leg and going to the doctor and saying i believe that my heart is weak since my legs hurts and totally disregarding the broken leg
GENE
Oct 04, 2011 | Kenmore Elite HE4 Electric Dryer
Touch pad is out
sounds like contol board or breker at panel off...or control board...
May 12, 2010 | Jenn-Air JES9800A Electric Kitchen Range
Profile fridge/freezer not cooling. Contol pannel
Fist thing you want to do is unplug pull away from wall and remove the cover that covers the motherboard. Then try to loosen by squeezing the plastic tabs that hold the mother board in place pull the board away just enough to expose the back side. Tell me if you see burn marks that are sometimes visible on boards when they become defective. What I want to find is if the high voltage side has failed powering the low voltage side or you just mayhave a defective control panel. Are lights out on the dispenser control panel? Is the model you listed correct PSW26? I can help if you like, Thanks, Sea Breeze
Feb 10, 2010 | GE Profile PSW26P Stainless Steel Side by...
Auto Programme starts up every time I turn on my LG 42PX5D TV. I've had it for 3 years and only started to happen yesterday
Unplug it,for a couple hours.Replug it back should stop.Not check ur manual contol see any buttons stuck in plastic that held the manual contol board.Might have to replaced the manual control board to solved this problem.
Feb 06, 2010 | LG 42PX5D 42 in. Plasma HDTV
My dishwasher wont turn on,or power on
Verify there is power to the electrical outlet. Make sure that a GFCI breaker has not tripped. Try unplugging it from the electrical outlet for about 5 minutes and plug it back in. Does this computer have a soft touch control panel? With the power disconnected remove the inner panel to reach the control panel board. Inspect the ribbon connector and make sure that the connector is fully inserted and has not slipped out. Check the ribbon connector for any signs of a short. My dishwaher was doing the same thing and it turned out the control panel ribbon connector had shorted across causing it not to work. If the contol panel tests good then lt could be a fuse located somewhere on the dishwasher or the computer board.
Sep 17, 2009 | Dishwashers
Maytag MDBS561AWS Stainless Steel Dishwasher Logo
41 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
