Question about Kitchen Ranges
How to use the aftron cooking range griller
I HAVE A AFTRON COOKING RANGE BUT I DONT KNOW HOW TO USE THE GRILLER SO COULD YOU PLEASE HELP ME OUT WITH IT.
SOURCE: auto cooking
all i want to no is how to activate the oven when the power comes back on which nobs to press
Posted on May 12, 2011
MNTECH
  • 1543 Answers
SOURCE: cooking element
You do not list a full model number. Typically a JBP78_____ uses a WB44X10013 bake element. Disconnect power to range. Take out two 1/4 inch hex head screws holding element in at back of oven. Pull element out a few inches into oven. Disconnect wires. Reverse to install. Not too hard if it is an exposed element. A bit more involved on ranges with "hidden" bake elements (which are under the floor of the oven).
Posted on Oct 11, 2008
smjdragonfly
  • 79 Answers
SOURCE: Oven stops heating during cooking
Heating element
Posted on Jun 18, 2009
milten1
  • 1304 Answers
SOURCE: Our Whirlpool gas range does not stay lit.
this is called cycling and it is totaly normal
gas ranges have a plus or minus 25 degree swing to set temp
it will turn on at -25 degrees
and turn off at +25 this is what maintains propertemp
Posted on Oct 05, 2009
fixyourboard
  • 310 Answers
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Oct 13, 2009
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
I need the user manual for my air con Aftron AFPAC 1200H. I am trying to check if i need to add water if so where do I add from and how much do I add. Also do I need remove water if so how do i do that?
Good Luck. Your best bet is to contact Aftron at this e-mail address: aftron@alfuttaim.ae
I checked everywhere and this outfit should be out of business. Try the address if you have not as that is the sole resource I have found that maybe able to help you. Please rate me on FixYa.com
Aug 03, 2011 | Heating & Cooling
Is there a place where I can find the cooking times for meats? Our old grill had a wonderful booklet which listed the cooking times for a one inch steak, chicken breast, ribs, etc. Thanks!
Since all grills heat and cook differently, time is not always the best judge for cooking meats. Use what I and many other professional griller's use, an instant read insertable Meat Thermometer. They are not expensive and can found in the kitchen accessories dept of any big box store. I'm not talking about some electronic gadget. I'm talking about the same thing professional chefs use. It's small, fits in your pocket and has the cooking temperatures for beef, pork, fowl, fish, etc written on the side of it's holder. Whether you like it rare to well done, the temperature range is indicated on the side of the holder.
Keep in mind, the thermometer on a grill is reading the air temperature when the hood is closed. Not the temperature at the cooking grates. Which can be 50 to 100 degrees F, hotter.
If this doesn't sound like want you want to try. Go to www.foodnetwork.com and I'm sure you'll find what you're looking for. Plus, some GREAT grilling recipes.
Hope this helped you and Happy Grilling!!
Jul 15, 2011 | Brinkmann 5 Burner with Smoker 8101750S
I HAVE GLEM GAS COOKING RANGE PURCHASED 6 YRS BEFORE FRM SAUDI ARABIA. NOW IN INDIA CHENNAI. PLS LET ME KNOW THE SERVICE CENTRE DETILS
Please give me details of Glem gas cooking range service centres in Kerala . My id -mecentpl@yahoo.com
Nov 14, 2010 | Ovens
How to clean and maintain grills after cooking
When you say oil I assume you mean cooking oil. Cooking oil will do nothing to remove rust. If cast iron grate try to re season them. If steel grate use some S.O.S or a soap pad then spray with Pam. Hank
Jul 19, 2010 | Char-Griller Char Griller Pro Deluxe...
How do I use this grill? Charcoal in the larger cavity and wood in the firebox???
I assume you have the model with the side firebox? If so, when smoking you have your charcoal and wood in the firebox and the meat to be cooked in the large cook chamber. This is indirect heat cooking. Your cooker is dual purpose. You can load the large chamber grates with charcoal and cook as would with a charcoal or gas grill (direct heat cooking), or you can cook low and slow using the smoker portion. The heat comes in from the firebox and into the cook area. Ideally the temp in the cook chamber should be around 225 while smoking meats in this manner.
Google "smoker forums" and you will find a group of guys will to help you learn to cook with a smoker and share cooking secrets.
I hope this helps.
Jun 21, 2010 | Char-Griller Wrangler Charcoal
Cooking info
You can print a new manual off of www.chargriller.com. But, the basics are:
1) Take cooking grates off of grill
2) Put enough charcoal on the grill to cover the desired cooking area two coal layers high
3) Pile up desired amount of charcoal (laid out in step 2)
4) Spray lighter fluid all over charcoal pile
5) Light the pile
6) Let the pile burn until the flames die out and most of the coal has turned white
7) Spread the coals back out (use tongs they will be hot). Put any coals that are still black on top of the white ones.
8) Put your cooking grates back on the grill and let the last black coals turn white and the grates heat up.
9) Now cook!
Apr 14, 2010 | Char-Griller Super Pro
Need aftron lcd tv manual
my aftron tv has been locked by mistack.it is showing the locked symbol only.please help me
Dec 19, 2009 | Sharp R-510HW Microwave Oven
Cleaning the griller
I dont know if this will solve your problem. I put water on the grill and let it heat up. This usally loosens up all thefood stuck to it. Hope this helps you
Sep 28, 2008 | Breville 800GRXL
Char griller patio pro Model 1515
You can get a PDF file off of chargriller.com I believe.
May 04, 2008 | Char-Griller Smokin' Pro CG010
Kitchen Ranges Logo
409 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
