REMOVING LASER FROM SONY DVD RECORDER RDR HX650
TRIED TO TAKE THE DISC HARD DRIVE OUT BUT IT SEEMS TO BE BLOCKED, I unscrewed the four screws but it wouldn't pop out
  • 6 Answers
SOURCE: Can't record onto disc
press dub on your remote, it will open the menu choose your programme you want record then click on hdd to disc.
Posted on Mar 31, 2008
  • 104 Answers
SOURCE: when I put in a new a recordable dvd disc in my
There are three things you can do that will eventually give you a working solution. Depending on the level of problem. Start with 1 progress to 3 until it works.
1. Use a cleaning disc. (one that use an alcohol based liquid)
2. If the cleaning disc does not solve it, you can use an ear bud, with some iso-propyl alcohol to clean the DVD lens on the drive directly. (you have to open the player and the drive)
3. The guaranteed working solution is to replace the DVD drive inside the player. This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer.
You simply remove the face plate, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Remove the old drive, and fit the new drive by reversing the removal procedure.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap DVD drive locally, try ebay.
I have done this on over 50 players for my clients in the past. I use LG IDE DVD roms and IDE DVD writers for the DVD recorders, irrespective of brand.
Let me know how it goes.
Posted on Feb 28, 2010
  • 69 Answers
SOURCE: Sony RDR-VX530 DVD Recorder / VCR Combo - cannot format DVD+R
is it possible to record dvd+r?
is this machine not only dvd-R
Posted on Apr 07, 2010
rulds2008
  • 3866 Answers
SOURCE: Can't get rid of dirty disc error message at 1 min
Ok you might need to have it cleaned professionaly worse comes to worse have the lens replaced, something ether got on the lens or the laser is not reading or writing correctly. Can it be fixed? Sure depning on the problem inside I could not tall you 100 p[ercent as I have not looked at the unit.
You might want to take a gander inside and see if the lends is not dirty.
Thanks an please rember to leave postive ratings and feedback.
Posted on Apr 12, 2010
SOURCE: Connecting my laptop to DVD recorder and recording onto the recor
You FIRST need a way to get the Signal, INTO the laptop, you need to get a USB to TV/Video Dongle, Now using this and the software that came with it, as well as other software, You Hook up the OUTPUT from the DVD Player, to the Video Input on the USB Dongle, Either, Component (Best) or Composite, (OK) Video, and AV Audio, and set to "Record" on the PC, and "Play" the DVD and then the PC will "Record" the incoming signal from, the DVD player, to the HDD in the PC. Once digitised, and saved it can be manipulated, any way you want.
Now if you want to do the REVERSE IE: Take a signal FROM the PC, to the DVD, then you simply setup the DVD as a Second monitor, use a TV to set it all up, once it is all working on the Laptop and TV, simply swing the Output, away from the TV's Input, to the DVD's Input,and select record, the PC, will then output whatever, to the screen, and whatever is displayed on-screen, will be recorded by the DVD's hard drive.
You First though must setup the PC to have multiple monitors, it is best to get the most up to date drivers and install them in the PC. FIRST. Go to this MS link below it shows you how to set u,setup as CLONE mode, I think will be best, also don't set initial resolution too high to start, set it to say 800x600 32 bit, to start, and work up, until your TV complains and stop. As related once setup, swing the PC's output to the DVD, and record.
http://support.microsoft.com/kb/307873
Posted on May 08, 2010
Hi there, My sony rdr hx510 will not open and is making a grinding rotating sound. Baby girl either put 1 one or 2 discs in incorrectly. Can you advise on how I can get it opened and renove the discs.
Must used a philip screw driver take out all the screws to the dvd player.Must take the DVD player aparts.Take aparts out the dvd player guard shield to the dvd drive to take out the dvd dic or dics out.Don't push the open button any more,the disc or discs is jamming ur dvd door tray.Will burn out ur disc tray motor,if u keep trying push the open button,trying opening it that way.
Sep 24, 2010 | Sony RDR-HX520 DVD Recorder
My Sony RDR-GX7 dvd recorder keeps giving me a "disc error" message every time I try to play a disc. How can I fix this?
Hard to say because this could be caused by any number of things. You could try cleaning the optical read head but this could get very involved unless you use a cleaning disc which may not work. You could try different discs such as a CD to see if that still fails. It could be the disc format. If everything fails then most likely a repair is required. Go to https://eservice.sony.com/webrma/web/index.do and locate a SONY repair location.
Aug 07, 2010 | Sony RDR-GX7 DVD Recorder
Apr 07, 2010 | Sony RDR-VX530 DVD Recorder/VCR
When I put in a new a recordable dvd disc in my RDR GX 300 it will format & then it says this picture can not be recorded, even though I have previously recorded the program on my DVR from Directv. I...
Feb 27, 2010 | Sony RDR-GX300 DVD Recorder
Sony DVD Recorder RDR-HXD990 will not timer record.
DVD wont consitently read discs drops out even though no scratches on discs
Jan 29, 2010 | Sony RDR-HX510S DVD Recorder/HDD Recorder
Sony RDR-GX315 DVD 3 problem
sounds like your laser is getting weak. repair is usually not economical. laser is about 90% the cost of the unit. hope this helps if it still plays but not record. keep it as strictly playback unit.
Jun 04, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Sony dvd recorder rdr gx7 sending disc error message
The laser readerwriter is most likely burned out, it is the most common failure. The option of repair is not really feasible as the cost of new is really low.
May 25, 2017 | Sony RDR-GX7 DVD Recorder
Sony DVD RDR-HX650 - set up
Sony UK has info how to hook up this unit. Please check there.
Sep 05, 2008 | Televison & Video
DVD -R finalizing
you maybe need to clean up the laser head and try it out again,it may help.
Aug 11, 2007 | Sony RDR-VX515 DVD Recorder/VCR
I have a Sony RDR HX510, can you help me?
Have you finalised the dvd disc in the machine ? you must finalise all dvds before playing them in other machines.
Mar 18, 2007 | Sony DVD-NS530 DVD Player
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
