Reset bios password
I dont know the password of the bios, how can i reset (with jumper ) the bios of motherboard "micro star model ws - 6301"
other details: n1996
ms - 6301 ver :1
    President:
  • 2,110 Answers
Try to remove the cmos battery from the motherboard and insert again...it will reset ur bios password...
Posted on Jan 19, 2009
I have had success by simply removing the battery from the motherboard for a minute or so then replacing the battery.
Micro star mian board passward on bios ms-6724
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 02, 2011 | Intel MicroStar MS-6724 Socket 478 P4...
I forget bios password for ibm thinkpad r30-2656
Removing the BIOS password is difficult because the password is stored on an EEPROM chip and removing the BIOS battery will not remove the BIOS password.
For details on how to remove this password, click on this link and follow the instructions :-
http://www.fixya.com/support/r4335050-remove_bios_power_password_thinkpad
Feb 22, 2011 | IBM ThinkPad R30 2656 Notebook
"Reset you're cmos/bios jumper to
HI,
No need to worry. There are many known ways to reset / remove / bypass the password:
  • By removing the CMOS battery
  • By using the motherboard jumper
  • By using MS DOS command
  • By using software
  • By using Backdoor BIOS password
Now I'll try to explain each method one by one:
A. By Removing the CMOS Battery:
Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
B. By Using the Motherboard Jumper:
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
C. By Using MS DOS Command:
This method works only if you have access to the system when its turned on because this method requires MS DOS. Open Command Prompt from Programs menu and provide following commands one bye one:
debug
o 70 2E
o 71 FF
quit
NOTE: The first character in the above commands is "O" and not the number 0.
After providing the above commands, restart your system and it should reset the CMOS Settings along with the BIOS password.
If you are curious to know how it works? then let me explain the above commands:
In this method we are using the Debug tool of MS DOS. The "O" character present at first in these commands, outputs the values to IO ports. The number 70 and 71 are port numbers which are used to access CMOS memory. By providing FF value we are telling CMOS that there is an invalid checksum and it resets the CMOS settings as well as BIOS password.
Jan 08, 2011 | Intel DG31PR Motherboard
Where can i get fc micro star n1996 model ms-7211 audio driver
Hi mabellmk85,
You can find all the software and drivers for that board HERE.
Good Luck,
and don't forget to leave a rating,
Thanks
Mark
Sep 27, 2009 | MSI PM8M3-V (7211010VPM8M3V) Motherboard
Reset bios on MSI ms-7301 motherboard
Kindly visit the following site
http://www.msi.com/index.php?func=downloadindex
Select the correct model number for your mainboard or motherboard and download the user manual for the same. It has details on how to reset the cmos or the board using the jumper settings
Thanks for using fixya
proton
Aug 15, 2009 | MSI Computers & Internet
I NEED THE JUMPER SETTINGS FOR MICRO STAR MS-6533E MOTHERBOARD. THANS FOR THE HELP!
why are u trying to set the jumpers ? i should have thank u if u add some more details. all the jumpers onboard have their own purpose. look carefully on ur mainboard, u'll see the jumpers with their distinct labels.
May 05, 2009 | Computers & Internet
Micro-star motherboard model MS-6526 drivers free download
pls see the link for all free drivers direct from MSI dont pay when u can get it FREE Pls rate me FIXYA for help
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=492
Apr 01, 2009 | Computers & Internet
Computers & Internet Logo
958 people viewed this question
David Payne
David Payne
