Question about Aprilaire 550 Humidifier
Why am I getting water blowing into the furnace and flooding the floor? This is happening after 12 years of service.
The repair man said it is because the furnace is to big for the house. My furnace is 125'000 my house is1400 sq ft . I purchased the furnace with the humidifier.
    Genius:
  • Aprilaire Master
  • 1,033 Answers
Hello, this can be either a clogged drain line or the tubing supplying the water into the humidifier is cracked. The size of the house has nothing tomdo with the water leaking into the Furnace.
Posted on Jan 05, 2013
  • Tim Dowden Nov 25, 2013
    there is a very small orfice in the hose where it inserts into the solenoid. Over time the water either enlarges the hole in them or they fall out if the line is removed. Order one on ebay and replace. Should fix you problem.
  • Robert May 15, 2014
    Most likely this is something you can fix yourself. Just clean out the drain line and check that tubing has no cracks.
As these guys have said, I doubt the problem is the size of your house. It would seem to me that the issue is the possibly the drain line being clogged. That might be a simple fix that could save loads of money right there for you.
http://www.proctor-mech.com/services/
Posted on Mar 21, 2015
4 Suggested Answers
  • 8 Answers
SOURCE: Have solenoid: MOPD 125, WATT 2.3, VOLT 24/60, for
I am guessing you have sent 24 volts to the solenoid directly and the the solenoid did not activate?
If you have not send power directly
If the solenoid does not activate that way more then likely needs a new solenoid.
Posted on Mar 06, 2009
SOURCE: aprilaire 600 humidier: water continuously runs
sounds like you may have it wired to a continuous power source vs one that shuts off with the furnace. The most common wiring is red to C & white to W
Posted on Jan 13, 2010
  • 118 Answers
SOURCE: Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
Posted on Feb 04, 2010
Aprilaire 700 water never shuts off
the float may be bad or sticking allowing water to run continusly even when unit is off.
Nov 06, 2013 | Aprilaire 700 Humidifier
We had our furnace repair turn on our Aprilaire 760 last summer. It gives off a very strong smell similar to an air freshener. We'd like that to be less in intensity. Furnance company says it's just fine....
I hope this helps you, have the repair person check to see if a furnace filter air freshener was installed at your last furnace check up without your knowledge. Also checked all wall and or floor registers to make sure the source of smell is not coming from them, it may be circulating though the duct system.last thing is to replace media pad in humidifier along with furnace filters, if you have air cleaner wash filters with hot water and baking soda, wipe & let dry before re- installing them. Your repair person may have use a strong smelling cleaning solution in humidifier that is now circulating though out your home, good luck.
Jan 24, 2010 | Aprilaire 700 Humidifier
When furnace cycles on the humidifier overflow spout has a tremendous flow of water that pours all over basement floor. Is there a valve problem ? I can connect a drain tube from this overflow spout to the...
If the water stops when the heater is not running then the humidifier is working fine. I know it seems like alot of water but that's how it's designed.
Jan 02, 2010 | Aprilaire 550 Humidifier
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
NEED MOTOR, EATON 416 025 20 FOR SEARS FURNACE HUMIDIFIER
It`s pretty expensive but Appliance Factory Parts has the same motor except at 24 volt and you have to use the gear from your old unit and a step down transformer..as yours is 115 volt..
Around $80 as they will combine the shipping if you call them..
Local electric motor shop repaired my 1994 motor for $35 after I explained to them I could not find a replacement..
I talked to Sears repair service man, he said our units are too expensive to produce today but are better than these new high flow models they use allot of water that just goes down your drain..
Mar 17, 2009 | Humidifiers
Water runs out back humidifier into plenum & onto floor
Hi John Your whole question did not show up (maybe you can re-post) . I can answer what part i understand though. If the humidifier was wired in right it will not send power to the humidifier until the furnace is on, and calling for heat. This stops the unit from working in the cooling mode in summer.Make sure your furnace filter is clean as well
Hope that helps
Mar 05, 2009 | General Filters 1042-LH Humidifier
Aprilaire 550 has exploded with water
No water should not just sit there in the system. It is supposed to recirculate itself. You should really call a tech out and have them check your system.
Feb 11, 2009 | Aprilaire 550 Humidifier
FURNACE RUNNING LOUD
sounds like either the motor is off balance
or is going bad again
either way id be on the phone to the guy who did the rapair
more than likely the set screw on the sqiral cage came loose and now its vibrating
Nov 11, 2008 | Aprilaire 700 Humidifier
Aprilaire 600 bypass water flow rate
The water is only dispensing over the evaporator pad while the furnace is in the heating mode. When the furnace finishes cycling the humidifier will also stop.
Mar 04, 2008 | Aprilaire 600 Humidifier
Aprilaire 550 Humidifier Logo
980 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
