SOURCE: Put mower in reverse, turned it off and mower
There are safety interlocks on zero turn mowers. These prevent starting unless you have:
1. the handles in 'neutral' position
2. the brake on
3. the mower engagement (PTO) switch off
4. yourself in the seat.
Chances are one of these conditions hasn't been met. Since you were reversing when it happened, perhaps you haven't got the handles back to neutral position?
SOURCE: Why is my troy-bilt mustang
it could need a oil change if it as some age to it could need a new ring set or a new overhaul and it my need a new plug ...
SOURCE: When I turn the key on to start my Troy-Bilt RZT
Do you hear a clicking sound???NO ?? Do you have the speed ?turning handles in the extrem OUT position? Is the ground cable connected to the engine block?? Is the Red cable connected to the + Positive post on the battery?? Is the BLACK cable connected to the - Negetive post on the battery?? Why did you need to replace the fuse? Is the battery charged??
If none of the above corrects the problem replace the ignition switch
