Question about Dell Optiplex GX270
Will lotus 123 load from a cd on windows 8
I have a lotus cd how do I down load it in windows 8
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 53 Answers
You have to create a batch file to run Lotus 1-2-3, and (so far as I can tell) you have to run the program from your root drive, because the program makes its calls TO the root drive. Here's the batch program you create in Notepad or other plain-text editor:
cd\
cd\lotus
123.exe
cd\
exit
* Delete the 'exit' if you want the window to stay open as a DOS window, after you're done with the program. Save the file with a '.bat' extension. (Note: unlike XP, you can close the window with your mouse, afterwards.)
* After creating that file, you have to right click on the file name, select 'Properties (in Win8, Vista, XP) and do some more tweaking. The Properties dialogue box SHOULD show the following tabs: General, Shortcut, Options, Font, Layout, Colors, Compatibility. Each of these needs editing.
GENERAL tab: select Normal Window or even Maximized (though it won't actually maximize). Also in Win8, click on Advanced, and 'Run as administrator'.
OPTIONS tab: select Large cursor. You can always change it, but since the program really won't run fullscreen, you'll want the cursor to be oversized, since the window will be smaller and will shrink everything in it.
FONT tab: this is what Windows uses to select the screen size, despite all the other settings (which you also still need to set). In Win7, you have three types of fonts to set. Click on the 'Bold' option, as that makes the text easier to read.
For True Type 'Consolas' font (which results in a more square window), pick a font size between 18 and 24. More than that will be bigger than your entire monitor screen, when you actually run the program (looks are deceiving, you have to test the results with trial and error).
For True Type Lucida Console font, use the same 18-24 font size range, but the screen will be much shallower and wider, so you can afford to decrease font size to 18-20. 28 is really too wide, on a widescreen monitor (1366x768 pixels). But maybe you'll like it, or your monitor will accommodate that size. Mine wouldn't.
For Raster fonts, 12 x 16 is the optimal setting. ON some (i.e., Dell Ultrasharp) monitors, Raster fonts look best. On my Toshiba 19L4200U TV monitor, the Lucida Consule setting is clearest.
LAYOUT tab: Pick a window size width no greater than 85, and height no greater than 38. Then test to see if it's too big. If yes, you'll also need to decrease font size, as well as the Layout size, here. Experiment, because you can't gauge the right mix of window and font size, just by the diagrams in the dialogue box.
COLORS tab: Lotus 1-2-3 makes hardware calls on the screen, so whatever you put in this tab, it will ignore. But other DOS programs might 'obey' the colors you set here. If you remember the old Norton Utilities days of setting Mode, etc., that's what this is.
COMPATIBILITY tab: You can't set resolution to override at 640x480. The setting is either ignored, or your monitor will freak out. For Lotus 1-2-3, in Win 8 I didn't need to turn on the 'compatibility mode'. It made no difference in the results. (You don't need it in XP, either.)
* Finally, you have to find the program itself, then right-click on the program name and edit its Properties. Here, that program is 123.exe, and it has to be in your root directory. (All the program files Lotus will use, must be there; at least one wk1 file must be in C:\123 at startup. I'm sure this can be tweaked, but I'm using the default Lotus program settings for a typical installation.)
Posted on Jan 04, 2013
Is there lotus 123 software that is compatible with Windows 10? I have lotus files on my computer but cannot access it.
right click on lotus 123 and and in properties click on the compatible tab
click in the square and high light the win 10 operating system
If win 10 is not there , it is not compatible
Aug 04, 2017 | Lotus Computers & Internet
Lotus 123 how to see the top row
try selecting upper left corner, which should select entire sheet, then unhide. Best guess, haven't used 123 in a while....
Aug 18, 2014 | Lotus Smartsuite 4 1-2-3 5.0 123 5 Wordpro...
Lotus 123 problems
Microsoft Excel should open your old Lotus files.
Go to File > Open > Select Files of type: Lotus (*.wk?) and select your Lotus file.
Alternatively you could install and use OpenOffice spreadsheet or LibreOffice Calc and open your Lotus files.
Jul 24, 2014 | IBM Lotus 123 Millennium Edition 9.5...
I have ancient lotus 123, approach, amipro and need to fit them into the new lotus smartwuite. How
well an ancient is fine what is not fine is that xp you installed is most likely not compatible with older versions, which were 3.x and early xp ok
time for an upgrade methinks.
May 29, 2012 | IBM Lotus SmartSuite 9.8 Millennium...
Problems opening lotus 123 files, very slow
I have all my Lotus files on a server and am not experiencing this problem. Did you install the desktop version or the network version. Mine is desktop and I get my files off the server. Works well.
Feb 11, 2010 | IBM Lotus 123 Millennium Edition 9.5...
Cannot open program. Error message "Lotus 123 Application has encountered a problem and needs to close". Worked fine last week.
Are you running Lotus Notes as well? There is a known compatibility issue and a patch for this.
Have you upgraded or installed new software recently ? Version 9.5 is not the latest version and has some issues with newer software.
Nov 17, 2009 | IBM Lotus 123 Millennium Edition 9.5- U...
Want to load lotus on to a vista system.....can I??
  • The Notes 8.0 feature release (released in August 2007) was fully tested and is supported with Windows Vista.
  • The Notes 7.0.3 maintenance release (released in October 2007) was fully tested and is supported with Windows Vista.
  • Notes 7.0.2, the in-market Notes release (shipped in September 2006) when Vista was released on January 20, 2007, is supported on Windows Vista. Releases prior to Notes 7.0.2 are not supported on Windows Vista.
  • Due to the broad changes in the Windows Vista release, and no more 6.5.x Maintenance Releases, Notes 6.5x is not supported on Windows Vista.
Nov 15, 2009 | IBM Lotus 123 Millennium Edition 9.5...
How do you get the bottom of the page without
Try any of this.
<End> OR
<Shift><End> OR
<Ctrl><End> OR
<Alt><End>
something out of this should work
Apr 14, 2009 | IBM Lotus 123 Millennium Edition 9.5...
LOTUS 123
am a sales tax auditor in hospet i have purchased a new duol core desktop pc in that pc xp installed
but lotus does not support the xp os please give me solution
Jul 09, 2008 | IBM 1-2-3 Millennium Edition 9.5 for PC
Dell Optiplex GX270  Logo
148 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
