Question about Westinghouse 24 in. MDP531 RF Free-standing Dishwasher
Westinghouse 906 I have just moved into a house that has a Westinghouse 906, I have no instructions for it, I am finding that it is stopping after the pre-wash cycle, but I am unsure if there is a problem with it or I have just not started it correctly as I don't have the instructions. If someone could help me out with instructions that would be very much appreciated. Thanks in advance
  • 3 more comments
  • Julia Oakley Jul 02, 2007
    Thanks for your help Gendos, but when I go to the site you have put in your solution there are 3 to choose from and I am unsure as to which one to download
  • Julia Oakley Jul 03, 2007
    Thanks Gendos, I can't find anything on the door frame and I think the dishwasher is pretty old and have since been told that it probably doesn't work, so thanks anyway
  • Anonymous Jun 01, 2008
    hi i am having the same problem, washing machine stops after pre wash cycle.
    The machine flashes a light & motor runs for a minute or so after it freezes in the cycle.
    any solutions?
    the machine is a westinghouse 906 model.
  • Anonymous Jun 06, 2008
    exact same problem
    it won't finish the wash and flashes the pre wash light.
  • Anonymous Apr 09, 2009
    I have the same problem too! What a piece of junk this 906 seems to be.
Mine had a similar problem i got a 905 though and it was doing the same i pulled the front door apart to get to the switches and other electrical things and all i did there was a vacuum hose thing (black) i blew into it and re assembled to hole lot i think something might have been blocked in the hose or where ever it goes to and wallah it worked but make sure you turn off the power first
cheers viking63
Posted on Apr 12, 2008
    Scholar:
  • 76 Answers
Jules1676 The use and care manual for your dish washer you can download from the Frigidaire web site: http://www.frigidaire.com/support/ResultsPage.asp?strModel=mdp531rf&User= I'll be glad to help you with any further questions. Gendos post back...
Posted on Jun 30, 2007
  • Gennadiy Kagan Jul 02, 2007
    jules1676
    Your choice should be based on the complete model number of your dish washer. You can find it on the door frame.
    Gendos
    post back...
My Westinghouse 906 has played up by only working in pre-wash mode when set in another wash mode ….try using Heavy mode this may take longer but at least it may wash dishes properly
Posted on Feb 22, 2009
I have a whirlpool washing machine, it was working ok before I moved house but now it wont rinse or spin,I cant find the instruction manual the model is AWOE8761 where can I get an instruction manual
simply you can download your instruction manual on samsung main website. Go here and search your washing machine model, you can get the manual
Sep 12, 2012 | Whirlpool Washing Machines
Westinghouse sb915 - draining too early.
1. Is your drain point higher than the bottom of the dishwasher? (ie, does it drain into the garbage disposer or does the drain line drop down below the floor into house plumbing?) Did you just install the unit? You may have to install an "air gap" to prevent syphoning.
2. Did the dishwasher work then suddenly stop working? (asking for clarification)
Dec 13, 2009 | Westinghouse Dishwashers
Stops mid cycle often
Hi there, did you ever find out what was wrong with your dishwasher? I have a Westinghouse 904 doing the same thing but when we moved into this house the manual was long lost. Any thoughts would be greatly appreciated.
My email address is shaneane@clear.net.nz
Jun 02, 2009 | Westinghouse Dishwashers
Dishwasher not emptying
either the pump is not working or the discharge hose is clogged, if you have an air gap on the sink take the hose off and hold it down see if the water comes out by tself if so the pump is bad if not the drain is colgged take out the bottom tray you will need a 1/4 inch nut driver take the plastic screen cover plate off clear it of debris, there is a sharp metal blade in there so be careful, after cleaning it out turn on to rinse and see if it drains if not you will need to either replace the dishwasher or the pump, dollar for dollar new dishwasher time
May 30, 2009 | Westinghouse 24 in. MDB421 RF Built-in...
Clogged screen for White Westinghouse washer
the screen is located inside the water valve. you will need to take the hose of of the valve and take a small flat screw driver and pull the screen out
Jan 02, 2009 | Westinghouse WWS833ES Super Capacity Top...
User Manual of Asea Cylinda 1200 Dishwasher
One of these was in my house when I moved in, still have the manual. Very efficient dishwasher.
A is a prewash (machine will stop after it). Manual says it's meant to rinse stuff while you wait until you've filled the machine to run a full wash.
D is economy wash. Water is heated according to the switch you select on the front.
C is a prewash that will continue on to D (normal cycle). Water is at incoming temp.
B is another prewash that will continue on the C etc (heavy cycle). Like C, water is at incoming temp.
E is dry cycle. Heating element is on/off depending on switch on the front (dunno why you'd turn it off..)
While turning the dial, push it in and it will stop exactly at the start of theach cycle.
Mine has stopped emptying, think the pump has died, looking for a replacement..
Apr 25, 2008 | Dishwashers
My westinghouse 905 dishwasher starts ok but stops somewhere in the cycle, not having washed the dishes properly.
Hi. I have a Westinghouse 905. At first all ok then we found that it cuts out and short cicuits the whole house. Trips the electricity switch. Restart gets to about half way through then same thing happens. Any help please?
Tks
Apr 22, 2008 | Dishwashers
My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Jan 29, 2008 | Smeg 24 in. DWF612WH Free-standing...
WESTINGHOUSE 906 DISHWASHER
Has anyone managed to find a Manual for the Westinghouse 906?
Dec 09, 2007 | Westinghouse Dishwashers
Powder not dispersing
possible the wash arms are not rotating - a common cause of powder not being taken. check by opening the door when in use and look to see if arms rotate. if not, then remove the arms and clear the jets especially the angled jets at the end which cause the arm to rotate
Jun 21, 2007 | Westinghouse 24 in. MDP531 RF...
Dishwashers Logo
1,245 people viewed this question
Top Westinghouse Dishwashers Experts
Fred Sops
Marvin
Marvin
Lawrence Oravetz
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
