Question about HP ProBook 4730s Notebook
My notebook does not want to switch on. The battery has been replaced with the original one for it and I replaced the ac adapter. When I plug the ac adapter in it the light just flash twice blue and
I also opened it and cleaned it out. I checked the connection and it was fine. My notebook is only a year old. Just outside the 1 year warranty. Please help me anyone.
    Sergeant:
    Champion:
  • HP Expert
  • 427 Answers
Have it checked in service. Do not dismantle again. It could be a defective charger, but also a shortcircuit because you opened it
Posted on Apr 17, 2013
4 Suggested Answers
gsage
  • 180 Answers
SOURCE: Hi. My HP nx7000 Notebook does not switch on at all
If you have warranty get it in for a new m/board ok
Posted on May 09, 2009
Geekman
  • 32281 Answers
SOURCE: HP Pavilion dv9700t battery dead, faint blue flash from plug
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Posted on Oct 18, 2009
techman007
  • 1112 Answers
SOURCE: My dv7-1245dx has the same charging problem. Has
Hi:
This is due to a faulty DC to DC converter IC on the laptop mother board, this part is not replaceable, you must replace the mother board as the chip is part of the motherboard.
Posted on Dec 27, 2010
Acer aspire notebook will not switch on after battery discharge even with mains adaptor plugged in. Help Noel
1. Remove the battery and the ac adapter from the laptop computer. Press the power button for about 10 seconds. This will discharge thee flea power from the laptop.
2. Connect the battery and the ac adapter. Charge the computer for about 30 mins then try to turn the computer on.
If this does not work, try to turn the computer on with only the AC adapter connected. If this works then it time to replace the battery.
Jun 26, 2011 | Acer Aspire One PC Notebook
I have a hp 6735s laptop. Its just out of warranty. When plugged into the mains adapter it is no longer charging the battery. This means it only works when plugged in. Have i inadvertantly set the...
best way is to just try out the battery on another laptop, or try another battery on yours. If the laptop is not very old, and I suppose yours isn't more than 2 years old, your battery shouldn't be dead.
Aug 16, 2010 | HP Compaq 6735s Notebook
Fujitsu lifebook blinking battery led, bad ac adapter?
i would try purchasing a universal laptop charger on ebay and see if it works. they are under 25 bux. worse case scenario you will have a backup ac adapter. be careful plugging in other ac adapters because the polarity could be wrong or it could have to much amps
Jul 11, 2010 | Fujitsu LifeBook A6025 Notebook
Power goes out whwn I unplug ac adapter
ther must be a short in the plug, get it checked before something goes really wrong
Jun 01, 2010 | Toshiba Satellite M35X-S311 Notebook
I have a HP dv7 laptop it does not work with the ac adapter but worked with the battery, whenever it is working with the battery and the ac adapter is connected it shuts down.
Remove the battery and plug the ac adaptor in check wethere the light on the port where you connect the ac adaptor glows or not, if no then check the wethere the ac adaptor is getting warm or not after you plug it in for few minutes if not then ac adaptor has to be replaced.
If the light on the port is glowing then it is likely that the power supply of the notebook has gone bad as it is not able to switch to ac adaptor or the port where you connect the ac adaptor to the notebook has a short circut when the acadaptor pin is connected , better try with a different ac adaptor to be sure wethere the issue is with ac adaptor or the notebook.
My best wishes
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
I had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Sep 26, 2009 | Dell Inspiron 1501 Notebook
I have a Gateway 4525GZ power problem
your ac adoptor is not correct it is low amh
please check for original adoptor
Jul 30, 2009 | Gateway 4525GZ Notebook
Travelmate only powers up with battery inserted. But AC still charges battery. Orange light goes on and of
Sorry to tell you this but you may have a problem with the charging system. That will require you to return it to Acer or an Acer service center. You can also try this. I got this from Acers' travelmate support website:
If the notebook does not power on:
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
You can aslo google your specific model of Travelmate to see if others are having this issue.
Les
Jun 27, 2009 | Acer Computers & Internet
I HAVE A ASPIRE 5520 IT WONT START THE FAN STARTS AND THE DVD BUT IT JUST KEEPS ON LOPPING
I had the same problem but what you can do is...
  8. If its not the batery or AC adapter you might have to send it to Texas, just go to www.Acer.com
Jun 14, 2009 | Acer Aspire One PC Notebook
Bad motherboard for M1730
take out the battery of your machine and plug in the power. if it works well, suspected faulty battery. you need to replace it.
May 19, 2009 | Dell Inspiron 6000 Notebook
HP ProBook 4730s Notebook Logo
76 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
