It doesn't seem to defrost unless i turn the system off or inconsisant
Defrosting doesn't go on correctly
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
What do you mean by "Defrost" to Standard Televisions? Provide more details please.
Posted on Jan 05, 2013
3xart731gb/01 wiring diagram
YOU HAVE A TIMER IN YOUR MACHINE PART NUMBER 2188379,WITH A SCREW DRIVER TURN IT SLOWLY TILL YOU HEAR A CLICK,YOU MANUALLY PUT IT INTO DEFROST,WITH THE BACK INSIDE WALL OF THE FREEZER REMOVED THE HEATER SHOULD COME ON,IF IT DOESN'T MOST LIKELY CAUSE WILL BE THE DEFROST THERMOSTAT LOCATED ON TOP OF THE EVAP COIL,IF YOU HAVE A METER YOU CAN CHECK IT BUT WHEN YOU HAVE A DEFROST PROBLEM IT'S A GOOD IDEA TO CHANGE OUT THE T-STAT ANYWAY,YOU CAN UNPLUG THE MACHINE,CUT THE TWO WIRES CLOSE TO THE T-STAT AND CONNECT THEM TOGETHER,PLUG IT BACK IN AND TURN THE TIMER INTO DEFROST,IF THE HEATER COMES ON YOU KNOW YOU HAVE A BAD T-STAT PART NUMBER 2321799 AND IT'S AROUND 27 DOLLARS,YOU HAVE A CALROD HEATER IN YOUR MACHINE AND THEY HARDLY GO PART 2313330 AND IT'S AROUND 25 DOLLARS.THE TIMER IS LOCATED IN THE FRESH FOOD SECTION ON THE RIGHT WHERE THE CONTROLS AREhttp://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-3XART731GB01/1198/0165000/W0212020/00009?blt=06&prst=&shdMod=
Jul 06, 2012 | Refrigerators
I have a 2003 dodge neon..and the rear defroster doesn't work..it has a button for it..and it just shuts off and back windshield doesn't clear at all...even if I keep turning it back on it...
Yeah, I'd think it would have lines, too, unless some new way of doing it that I'm not aware of. Maybe the rear window was replaced with a window without the defrost option. There should be a small two wire connector coming out of the back shelf near lower driver's side of rear window. That would be the defrost connector to the window lines (that aren't there,lol).
Well, good luck with that! I think there are aftermarket kits for rear window defrost, though.
Nov 23, 2011 | 2003 Dodge Neon
My Whirlpool EL7ATRRKQ01 ALL REFRIGERATOR cools but it doesn't seem to ever shut off. No matter where I move the temperature dial, I can hear the fan going all the time. The only time it shuts off is...
First I would check cold control. Thats where you turn it off, if your temp is not warm. it seems
to be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Jul 30, 2011 | Refrigerators
I have the superba model and it doesn't work. stop working two days ago. a soda exploded in the fridge and two days later fridge and refrigerator not working. I would appreciate some solution. thank...
Leo Ponder
imufo2
Jul 30, 2011 | KitchenAid (KSRD22FKST) Side by Side...
I purchased this Frigidaire freezer three years ago. Around a week ago, I noticed that the items I had stored in the freezer have begun to thaw slowly. Although the freezer is still "working", it...
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Take out back panel of freezer to check for icw build up. The coils should be clean.
Also check evaporator fan in freezer
If this was helpful please rate me
Leo Ponder
imufo2
Jul 23, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
2001 volvo s40- When defrost is chosen on control, the AC light comes on and the air exits the front vents. Very little air exits the defrost ducts on wnshield
I am not an expert of Volvo's but what you describe is normal operation for most cars. If hot air was directed at a very cold windshield it could crack it. So when you kick it over to defrost, the hot air is mixed with AC air and the amount of air flow is restricted so that it doesn't crack.
Did the operation of your Volvo defrost system seem to change all of a sudden and that is the reason you posted this? If so how did it change?
Jul 01, 2011 | 2000 Volvo S40
I have an Amana 25 Side by Side Refrigerator, approximately 20 + years old. The freezer side doesn't seem to maintain the cold for freezing. I have vacummed and cleaned around the coil, in...
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Jun 20, 2011 | Amana Refrigerators
Freezer coil is iced over & frig is not cool ing. Today just cleaned coil underneath & now is worse. Just now turned freezer off & am defrosting coils w/hair dryer. What to do next?
DEFROST PROBLEM
Apr 20, 2011 | Refrigerators
My Whirlpool refrigerator trips the main breaker of 40 Amps
A refrig cannot pull 40 amps in defrost , unless there is a direct short in the defrost system ( timer , heater , bimetal ) . I would use an extention cord ( for test purposes only ) , and try a different plug . Sounds like the circuit breaker is weak . In defrost , the MOST you should get , is 6 amps . This will not throw a 40 amp breaker . If you have an amp meter , remove the back refrig panel behind the refrig , and connect to one of the power cord lines (just not the green ground ) , turn into defrost and check the amps . This will tell you if short is in refrig , or weak breaker .
Sep 06, 2009 | Whirlpool ES5FHAXS Side by Side...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
