Question about Garden
Lawnmower runs for about 10 minutes then it starts sputtering and shuts off.checked the sparkplug and it is wet with gasoline.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 18 Answers
Try running your mower without the gas cap, without mowing of course. The breather on the cap might be malfunctioning. Change cap. It is creating a vacuum.
Posted on Feb 11, 2013
5 Suggested Answers
  • 3 Answers
SOURCE: Mower runs for 10-15 mins. then shuts off.
I would agree with the gas cap being the problem. There should be a insert inside the cap which helps with the tap pressure. If this is lost then the engine will run for a few min. and shut off.
There is one other thing and that is the float in the carb bowl. It may be allowing in just enough gas to fill the bowl and then it is sticking. This would account for just enough fuel to run for a brief period and then shut down.
VTX Guy
Posted on Mar 10, 2009
  • 24 Answers
SOURCE: sears riding lawnmower.14hp??
The coil is bad. The coil is gettin hot and shorting out .
Posted on Aug 22, 2009
SOURCE: Riding lawnmower wont run long
Check for dirt in gas tank some times stuff will fall in when filling and block the hole in bottom of gas tank and wont let gas flow clean everything out and see if it works. Also check that all kill switches are tight and not moving.
Posted on Oct 10, 2009
dcurryn601
  • 60 Answers
SOURCE: I have a lawnmower that
sounds like its flooding itself out
Carb problems can be a bear, I would check the flote at the bottom of the carb it may need to be cleaned possibbly oiled and somthimes the even get a hole in them
Posted on Jul 29, 2011
Troubleshooting generators
If this unit dies under load conditions, decrease your load and try it again.
If this happens under no-load conditions, check your fuel supply. Start with the filters, then check pressure and flow.
Jul 21, 2014 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
I have a Murray select 22" push lawnmower. It has a 6.o HP Briggs&Stratton Quantum engine. I cannot get it to start or stay running. I have drained the fuel tank of any fuel that was in it and...
You said you drained the fuel tank so I'm assuming that there was fuel left there over the winter when it was not being used. If fuel is left in the lawnmower for a few months without it being used it can form a gel in the jets and/or the diaphram of the carburettor. I would think that this is the problem.
Depending on how bad the problem is you may be able to solve it yourself. Remove the sparkplug and pour around 5ml (one teaspoonful) of fuel into the opening. Dip the end of the sparkplug in fuel, so the spark gap is wet, and replace the plug. Try starting the lawnmower. The fuel you poured in should ignite and the engine turn over. This could **** the fuel through the carburettor and be enough to get it going. You may have to repeat the process 2 or 3 times. Don't be tempted to pour in more than the 5 ml of fuel or you'll flood the engine.
If this fails you'll need to take it to a mechanic to strip down the carburettor. I hope this helps.
May 09, 2011 | Garden
Honda engine pressure washer won't start
Remove the sparkplug spray isoproxyl (rubbing) alchohol in the cylinder and on the sparkplug this will "dry out the engine" reassemble and, start the engine.
It should start as a "wet with gasoline" sparkplug can not spark nor, will liquid gasoline ignite
May 23, 2010 | Honda 8 HP Engine
My 6.75hp toro lawnmower doesn't stay running,I changed sparkplug,filter beginning of the season,what's causing it to stall out,please help it seems I have trouble with all lawnmowers,my 4th mower in 10...
Are you leaving old gas in the mower for long periods of time(30days)?
Gas will tend to varnish up and do all kinds of havic to your carb.
I would check for spark when it shuts off.
Aug 25, 2009 | Garden
Lawnmower starts but won't continue to run
if you are getting no fuel to the plug you either have a stuck float, plugged fuel line or filter. does the gas reach the carb bowl? does the mower have a fuel pump? if so the diaphram might be bad.
Jun 30, 2009 | Garden
Shuts off after about 15 minutes
If it is gasoline powered, ensure mix is correct if 2 cycle, check exhaust for carbon blockage. Either will cause overheating.
Mar 27, 2009 | Garden
Engine shuts off after about 10 minutes of use
Try loosening the gasoline cap on the engine. My snowblower acted the same way until a mechanic told me it sounds like the engine is not getting enough air. Some gasoline cap vents go bad and starve the engine. If your engine continues to run you can buy a new gas cap.
Mar 12, 2009 | Briggs & Stratton Garden
Truck runs fine but starts sputtering
Sounds like a spark plug wire or plug problem, how many miles on truck?
Nov 17, 2008 | 1999 Chevrolet S-10 Pickup
Engine Quits
sounds like a tipical crankshaft position sensor will fix your car
Sep 26, 2008 | 1993 Chrysler Concorde
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
