Question about Amana ARB2557CSR / ARB2557CSL Bottom Freezer Refrigerator
Amana ARB2517C is making a clicking noise and not cooling?
  • Amana Master
  • 4,655 Answers
The clicking sound is the overload kicking off the power going to the compressor as to protect it. What you will need to repair this is a=> 67002783 Overload
And you will need a=> 65889-4 Run Capacitor
These parts are found inside the cover on the side of the compressor and the run capacitor is found near the compressor. I will be here to answer any questions you may have, Thanks Sea Breeze
Posted on Jan 04, 2013
  • John Tripp
    John Tripp Jan 04, 2013
    To keep the compressor from getting too hot I recommend unplugging the refrigerator until these parts can be replaced. Thanks Sea Breeze
3 Suggested Answers
  • 56 Answers
SOURCE: freezer and fridge not cooling properly
Clean it up. Check under it and behind, clean ,vacume and or blow out all dust and check the fins on the bottom, a soft brush and portable air compressor work really well but very dusty, take out side if possible, or just vacume really well.
Posted on Jan 26, 2009
  • 246 Answers
SOURCE: My Amana ARB9059CS refridgerator is not cooling.
The clicking noise you hear is a relay trying to start your compressor but your compressor does not want to obey! Compressor most likely is bad and needs to be replaced or all your refrigerant gas has leaked out and would need to be repaired and system re-charger with refrigerant gas. Not a cheap venture either way. Might want to consider getting a new one.
Posted on Nov 07, 2009
Fridge and bottom freezer not cooling. Light on when door opened. Is there a reset switch/button? It is an Amana
There is not a reset switch/button. Do you hear any noise at all, fans or clicking noises?
Jan 11, 2011 | Amana ABB1927DE Bottom Freezer...
Amana ARB9059cs: compressor makes loud noise (come and go). Refrigerator not working but bottom freezer is working. All lights on. Please advise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
Jan 25, 2010 | Amana ARB9059CS Bottom Freezer...
I HAVE A AMANA ARB2517C THE REFRIGERATOR KEEPS FREEZING EVERYTHING I HAVE TAKEN EVERYTHING OUT OF THE FREEZER AND FRIDGE AND LET IT THAW OUT AND WHEN I TURNED IT BACK ON WITH THE SETTINGS SET ON 1 OR COLD...
Your defrost system has gone out and it will continue to freeze until you replace it.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 Am until 9 PM CST and we will get the correct defrost system out to you asap.
We look forward to working with you. Thanks, Ella
Nov 13, 2009 | Grilling
My Amana ARB9059CS refridgerator is not cooling. Fans blowing top and bottom. Makes a clicking noise every few minutes. Tried unplugging it for a day, then plugging back in. Did not help.
Nov 07, 2009 | Amana ARB9059CS Bottom Freezer...
6 yr old Amana has stopped cooling- light is on!
To make sure there is no damage to the compressor I want you to unplug the refrigerator. I will instruct you on what to test or advise you on how the repair should take place. If this is what you want, let me know. The problem could be something simple but to do these test answer me about this solution. Thanks, Sea Breeze
Jun 30, 2009 | Amana ABB1927DE Bottom Freezer...
Amana ASD 2620HRZ side by side not cooling at all!
if all of that is running your ref. should be cooling.can you hear your compressor running?or can you hear it run for a few seconds and click.If you hear a clicking noise the relay to compressor has gone bad,if it is running then you have a leak in the sealed system.
Mar 08, 2009 | Amana ASD 2624 Side by Side Refrigerator
Freezer and fridge not cooling properly
Jan 26, 2009 | Amana 22.6 cu. ft. Side-By-Side...
AMANA REFRIGERATOR MAKES A LOUD POP!
Dear Customer
Please perform the following
If it's cooling ok, they're probably normal sounds. Modern refrigerators can make many noises, most people aren't home long enough to hear them. A popping sound could be defrost water hitting a hot defrost element, or refrigerant making noise in the cooling lines. If it's working ok, ignore it. Please rate this,Thank u
Dec 17, 2008 | Amana ACD2232HR Side by Side Refrigerator
Amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
Aug 05, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Amana ARB2557CSR / ARB2557CSL Bottom Freezer Refrigerator Logo
126 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
