Question about Ovens
Jenn-Air W227B
Jenn-Air wall oven Clock does not work
  • 184 Answers
SOURCE: Jenn-Air Gas Range SEG196 NO CLOCK/DISPLAY
THE ONLY SOLUTION FOR THE BAD DISPLAY IS TO REPLACE THE CLOCK. I HAVE A JENN AIR OVEN TODAY AS A WORK ORDER TO REPLACE THE CLOCK FOR A FAILED DISPLAY.
FOR THE JGW8130DDB WITH NO POWER ANYWHERE, IT SOUNDS LIKE YOU HAVE A SUPPLY PROBLEM. MAKE SURE THE WIRING IS HOOKED UP WITH THE RED AND WHITE WIRES RECEIVING 240 VOLTS AND THE WHITE WIRE ATTACHED TO NEUTRAL / GROUND.IF THE OVEN HAS A BARE COPPER WIRE AND THE HOUSEHOLD WIRING ONLY HAS THREE WIRES, COMBINE THE WHITE WIRE AND THE COPPER WIRE TOGETHER AND ATTACH TO THE HOUSEHOLD NEUTRAL / GROUND .
UNLESS YOU ARE SURE ABOUT THE HOOKUP IN THE BREAKER/FUSE BOX, DO NOT GO SIMPLY BY THE COLOR OF THE WIRES.
Posted on Apr 10, 2008
SOURCE: jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Posted on Apr 26, 2008
  • 114 Answers
SOURCE: Oven digital lighted display is dim
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Posted on Mar 21, 2009
SOURCE: Display on my Jenn-Air electric wall oven is very dim
douglas9101,
I had the same problem and found the solution on-line.
Replace the C3 capacitor on the dispaly module. (100 UF, 35 volt, high temperature)
The local Jenn Air dealer wanted $211 for a new display module.
I purchased a Cap from a local electronics supply store for 79cents.
The only problem is that you need to have a soldering pencil/iron, a solder ******/wick and a small amount of solder.
Steps I had to take on my oven:
- Flip the AC breaker supplying the oven to off to be save
- remove 3 screws on top and 4 on the bottom of the display panel
- gently pull out the display panel and unplug the 2 cables to the display
- unclip the ribbon cable to the display module
- unclip the module itself by pushing on the 2 black tabs
- locate C3
- unsolder C3 and replace with new Cap- keeping the polarity strip the same as theh old Cap
- reasemble in reverse order.
It took me all of 20 minutes. It may sound difficult but is very easy if you have the tools
Good Luck
K
Posted on Jun 15, 2009
dltatsjc
  • 54 Answers
SOURCE: Jenn-Air JJW8530 LCD panel does not light up
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the
design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, Using as small a soldering iron as you can find De-solder it and replace with new, match polarity marks and don’t use any more solder than needed.
If you run into trouble drop me an e-mail to dltatsjc@aol.com and I’ll try to help.
Good luck.
Thanks for this site..
Link to Photo sequence of capacitor replacement (Captions still will not link):
http://picasaweb.google.com/dltatsjc/Photos?authkey=Gv1sRgCJPKv9CRgsXxNA
Posted on Oct 12, 2009
Jenn-Air W241-C wall oven
Unless you can find one in a used oven, I don't know. Jenn air website says they are discontinued and offers no substitute part.
Jul 17, 2014 | Jenn-Air Ovens
F7 code flashes on jenn aire 27 inch wall oven
The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
I hope this helps.
Mar 01, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
MY JENN-AIR MODEL #WW2460B WALL OVEN DOES NOT DISPLAY THE CLOCK/TIMER. IT STOPPED WORKING DURING A SELF CLEAN CYCLE. IS THERE A WAY I CAN ORDER THE PART TO REPLACE IT MYSELF AND ARE THERE WIRING SKEMATICS...
There is a high limit thermostat that will cut all the power to the upper oven elements. Their is a wiring diagram in this link http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Wall-oven-Parts/Model-WW2460B/1266/0125300?pathTaken=&prst=0&shdMod=WW2460B
when clicking on it,it will say not avaliable. A trick i have found is to open that link and then using your computer tools select the maximum zoom i use IE set to 400% and its pretty ledegable.
Gene
Aug 11, 2011 | Jenn-Air Ovens
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
My Jenn Air Electric Wall Oven Control panel lights have gone out
You will need to replace the display assbly.
It is a very common problem with maytag/Jenn Air
Feb 19, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Apr 10, 2008 | Jenn-Air JGW8130A Electric Single Oven
Jenn-Air self cleaning wall ovens model W2451
We have a W245 self cleaning oven and the woven gasket is falling apart, can we purchase a new one to replace it?
Jan 16, 2008 | Jenn-Air JJW8527C Expressions Collection...
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
