Question about Proform XP 580 Trainer Treadmill
Proform xp 580 - Occassionally, any button i push simply beeps, and nothing else happens, no response from the panel.
    Top Expert:
  • Proform Master
  • 12,223 Answers
Step 1:
please replace the old batteries with a new ones, with the same mark+same polarity+full charge.
Step 2:
adjust the REED switch, see the diagram attached, test for open or faulty, clean it, and tight the connector very well .
Step 3:
tight all connector a) ribbon cable inside for keypads b) upper connectors board display vs lower connector main board.
God bless you
Posted on Jan 04, 2013
SOURCE: Have proform crosswalk caliber
Batteries? Install in the back under the unit :)
Posted on Jan 12, 2010
maxtreadmill
  • 832 Answers
SOURCE: proform treadmill doesnt work
Press the Stop and the Speed Up keys down while inserting the safety key and try to get this unit in calibration mode if you cannot then, the upper console will have to be replace.
Posted on Jun 01, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jun 14, 2010
  • 84 Answers
SOURCE: The board lights up, but
i think your console is shot check connections on the controller board. when pressing buttons, and some commands or none work, its the console
Posted on Feb 28, 2011
SOURCE: I have a Proform 585 and the incline won't go up
As you are hearing the motor sound, It could be a problem as simple as the gearbox on the motor being jammed. We can remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn't run outside the machine and you can hear it try to work, you need to replace the incline motor.
Posted on Mar 15, 2011
Cant get it to run
If the timer goes when you press start there could be one of a few things wrong
  1. Wiring harness
  2. Drive motor
  3. Controller
Better to call for support 877-805-1030
Jan 02, 2014 | Proform XP 580 Trainer Treadmill
I have a proform xp trainer 580 . The display works but the actual walking belt doesnt move.
please see the video and fix it according.God bless youThis happen because the lack of maintenance schedule .
Apr 04, 2013 | Proform XP 580 Trainer Treadmill
Proform xp 580 - Does anyone know how to remove the control panel cover? Is there a diagram somewhere of all screws?
Look up your model on IconService.com, they have the user manual, and also the schematics that I use as a Tech. Note that even as a repair tech, I rarely ever get into the console.
Technical note - on treadmills, the top electronic board is actually called a "console". The "controller" is the circuit board that sits next to the drive motor in the bottom housing in front of the drive roller.
Jan 05, 2013 | Proform XP 580 Trainer Treadmill
Loud clunking noise in rear roller of proform 580 treadmill
You must LUBE the deck belt first, this happen because you do not lube maintenance schedule, Do it every week from use.Maybe you have a WORN deck belt.
2) LUBE the rollers bearing front and end, use WD-40
3) Test the drive belt motor, for cracking or worn, and replace.
God bless you
Nov 29, 2012 | Proform XP 580 Trainer Treadmill
Can't get my proform xp 580 trainer treadmill out the door
sony ericession text pro ck 15i i want incoming sound incrise (or)...how to sending blooth with video
Nov 20, 2012 | Proform XP 580 Trainer Treadmill
I have a proform xp 580 and my treadmill makes a clicking noise as if it is trying to incline what should i do?
1)Please lube the gear and shaft, very well from elevation motor
2) Test the motor, and replace if necessary.,see for ball bearing and lube
3) Lube the deck belt, and guide for instruction manuals.
4) Test the main switch, and reset button with VOM, for open, test and replace see the diagram how to do it.
God bless you
Jun 08, 2012 | Proform XP 580 Trainer Treadmill
My proform 580 runs for 1/2 second, shuts of, and resets and will repeat this as many times that you push the start button
HI,
Your treadmill have problem with the motor control board. The motor control IGBT is faulty thats why its stars at high speed and shuts off immediately by sensing over current drain. The solution is replacing the motor control board or replacing the IGBT on the motor control board. To replace the IGBT you should have a through knowledge in electronics. If you need any more assistance feel free to contact me through FixYa.
AJIN
Jan 19, 2012 | Proform XP 580 Trainer Treadmill
The board lights up, but when you attempt to push a button (speed, program select) nothing happens. I do however have the stop and pace button beeping 3 times when you touch, but nothing works.
Feb 28, 2011 | Proform Exercise & Fitness
Jun 12, 2010 | Proform XP 580 Trainer Treadmill
Proform XP 580 Trainer Treadmill Logo
238 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
