Question about Maytag Dishwashers
Maytag mdb7100awb won't turn on
My dishwasher won't turn on but how do I know if it is the control panel or the door latch that needs replacing? There is some power going to the panel as I when the kitchen is dark and the dishwasher door is closed I can see a very faint flicker.
    Sergeant:
    Champion:
  • 249 Answers
Can you upload a video of what is wrung . I might know what need to be replaced. I might know after the video you toke of the unit then
Posted on Jan 04, 2013
  • 1314 Answers
SOURCE: Maytag dishwasher MDB5601AWS won't turn on
ok under the bottom kick-plate you will find a tech sheet first id start with where my power comes in under the kick plate second remove the front panel and check the door switches third check the control for a fuse or burned wires resistors etc refer to the tech sheet but it sounds to me like a power problem
Posted on Jan 25, 2008
  • 236 Answers
SOURCE: Maytag Jetclean Dishwasher EQ Plus MDB7100AWB
the door seal has gone better change the door surround seal also. check for case damage and obstructions aswell.
Posted on Mar 14, 2009
SOURCE: Jenn Air dishwasher door won't close
i had the exact same issue. it's a broken latch mechanism, and is a fairly common problem.
i bought the part at my local repair shop for $45 (you can find it online for $30). it literally took 10 minutes.
you need to right size bit to remove the 10 bolts on the interior of the door. once you have those out, the latch slides right out of the top. there are 2 electrical connectors (careful - you can get a shock. disconnect the 2 connectors, reconnect to the new one, and zip your 10 bolts back in. super easy
Posted on Oct 17, 2009
SOURCE: Need door latch diagram Kitchen Aid dishwasher (Part No. 9744033)
I thought the metal bar had to be locked into place somewhere in the black latch. This was not the case. I just put the white plastic latch in place in the slot in the door and closed the panel and the metal bar went into the correct position against the black latch.
Posted on Jan 23, 2010
rickead1
  • 1998 Answers
SOURCE: Maytag MDBtt60awb
most likely you have a bad motor when replacing the motor ihave found it is cheaper to get the pump with the motor attached where as they charge you more money for just the motor or the pump seprately try allbrands appliance parts they seem to be cheaper
Posted on Apr 30, 2010
My Maytag dishwasher model MDB7100AWB stopped somewhere in the cycle & is making a soft clicking noise. It's full of water & I don't know if it did the wash or not. I turned it off & tried to restart but...
More than likely the control panel is defective. Contact the company at the link for troubleshooting help[ and also the parts that you may need.
https://www.repairclinic.com/
Jun 27, 2017 | Maytag MDB7100AWB Dishwasher
How do I unlock my dishwasher door?
To avoid damaging the mechanism, you must remove the cover of the dishwasher and with a screwdriver blade can unlock the door from inside.
Jul 04, 2013 | Cars & Trucks
Power okay but won't work
My guess would be the door latch switch, if it is out of adjustment or not working the machine will think the door is open and won't run.
Some dis-assembly might be needed of the door to locate and check the switch. See this
Dec 11, 2012 | Maytag MDB7100AWB Dishwasher
Doesn't fill with water
Hi this could be serveral items that will cause this , 1. No water, 2. bad water valve. 3. door latch , 4. Bad controller 5. pump plugged up with food
Dose the door latch feel funny , dose it lock correctly ?
The latch is always the first thing i look at , check it out some more and get back to me , Frank
Dec 02, 2011 | Maytag MDB7100AWB Dishwasher
Maytag dishwasher door handle not latching
I have experienced the same problem. You can take a knife and stick the tip under the latch and pull towards you. Will work for a while.
Nov 09, 2009 | Maytag MDB7100AWB Dishwasher
How do i adjust door switch on a maytag dishwasher model mdb4000awa ?
With a philips screwdriver turn the adjusting screww inside locking lever mechanisim, The latch at the top frame has adjustment screws too.
Vitally
May 14, 2009 | Maytag MDB7100AWB Dishwasher
Maytag Model # MDB7600AWW door will not latch
double check door latch make sure connections are proper if right and still not working probably main board and panel
Apr 23, 2009 | Maytag MDB7100AWB Dishwasher
Maytag dishwasher mdb7601 will not run-
if power to the dishwasher is OK, then the door latch may be the problem. You need to unplug the unit, remove the inside cover to the door and check the door latch switches (may be a pair) with an ohm meter for continuity. Each switch is a make/break connection. If that is OK, the problem could be a power connector to the control circuit board that could be loose.
NO POWER TO THE DOOR PANEL
check door switches at door latch
Jan 05, 2008 | Maytag MDB7100AWB Dishwasher
Dishwashers Logo
63 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
