Question about Electrolux Vacuums
I have a Lux Commercial Electrolux vacuum sweeper-Model U129Q. The red light that indicates a full bag stay on even after changing the bag.
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Posted on Jun 20, 2008
SOURCE: Repair my Electrolux 2100 cannister vacuum cleaner
On my 6500, I just disconnected the air line from the switch and now the vaccuum won't sense the bag pressure; I just have to check the bag myself now.
Posted on Jul 10, 2008
  • 134 Answers
SOURCE: electrolux 2100
HI
sounds like the hose is blocked. Drop a coin throgh it to check
Posted on Feb 20, 2009
  • 566 Answers
SOURCE: Electrolux #1521 Canister Vacuum won't stay closed
hi from uk your problem with the canister cover/door coming off whilst vaccing ? you have renewed bag ? ok but there is a filter/gauze also inside the canister where bag is fitted if you check inside you should see the filter at opposite end from where bag is secured it is usually fitted behind a slotted pull out plastic gate ? this filter/gauze is to allow air out of canister when vaccing and the filter traps any dust that may accumulate inside the canister case so the dust does not get blown out to atmosphere/rooms SO if this filter is clogged it will not allow vacced air to escape out of canister so result is build up of pressure within cylinder and eventually cover flips open ! so for now you can remove filter/gauze and wash then dry refit this will allow air to escape from canister but still retain dust particles from escaping as it is designed for however may i suggest you replace filter when convenient ? all above is on assuming that the latch on cover is working ok and not now damaged ? hope this helps best wishes
Posted on Mar 01, 2009
  • 73 Answers
SOURCE: Bag full indication comes on; changed bag; still wont run.
Turn the knob on the top of the vacuum all the way to the right and try it again
Posted on Aug 27, 2009
I cannoot find bags to fit my Little Lux Model # L673BA
You can find those bags at
http://www.totalvac.com/850-12.html
Fits all Electrolux canisters/tanks made after 1954, (except Lux 9000, Guardian, Epic 8000, Renaissance, Harmony or Oxygen models) Generic 12 pack of Electrolux vacuum bags.
Mar 01, 2011 | Electrolux Little Lux Bagged Handheld...
Vac light comes on after i changed the bag
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
http://evacuumstore.com/
Apr 14, 2010 | Electrolux Lux 5500 Canister Vacuum
My electrolux vac shut off for a full bag. After replacing the bag the vac won't start and the bag full light stays on.What should I be looking for to resolve my problem?
If the suggestion that renevacdoc did not work, it is most likely that your valve assembly(full bag control) has gone bad and needs to be replaced. You will have to take your vac to the Aerus/Electrolux dealer/service store for repair.
Joe
Nov 07, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Lux 5000 put in new bag but when i turn on the
It sounds like the valve assembly (full bag control) is faulty. Threr are two O rings inside of it and the plactic holding the bottom one has broken. You'll have to take it to the shop.
Oct 25, 2009 | Electrolux Lux 5500 Canister Vacuum
Vacuum cleaner Lux model motor fails to start
This vacuum has a 10 year warranty on the motor, and 5 years on everything else. Look in the yellow pages under vacuums, for the AERUS dealer, that is the new name for the traditional Electrolux company.....
Mar 23, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
Can't change bag - Electrolux Oxygen canister
my oxygen has a little red lever on lh side of bag enclosure, that has to be pushed to left and bag then is free to be removed. make sure you have the correct bag to replace.
Jan 28, 2009 | Electrolux Lux 5500 Canister Vacuum
Electrolux Canister - Renaissance model
Probably a clog, because the change bag light is nothing but an airflow sensor.
Check your hoses to ensure that there are no blockages, and also check inside the powerhead behind the brushroll.
-R
Aug 07, 2008 | Electrolux Lux 5500 Canister Vacuum
Electrolux Renaissance canister
there are a couple situations to this issue. one is the bag that was replaced is a incorrect one and it is not meeting the switch for the bag pop circuit. some over the counter bags cause this issue. another problem could be the switch itself. or the bag door not being tight enoug to make contact with the bag.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
82 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
