Stuck in power save mode and can not get it out
My desktop is stuck on power save mode and none of the buttons on the keyboard and it is still stuck i tryed to cut the power and it is still stuck. help
  • Computers & ... Master
  • 5,660 Answers
I suggest your computer isn't stuck on Power Saver Mode
Your monitor went to Power Saver Mode
Power Saver Mode, Sleep Mode, NO SIGNAL = Same/same,
in this instance.
Why?
Because your computer isn't working.
The two leading causes of desktop computer failure is it is dirty inside, and/or a bad Power Supply.
There are issues with bad capacitors on the motherboard, too.
1) State the computer manufacturer, and model number.
I don't like giving generic one-size-fits-all information.
2) Do you have a multimeter, or access to one?
An economical model can be purchased for as little, as $5 to $12.
Available in a multitude of stores. An auto parts store is but one example.
I have seen them on checkout aisle racks, in major discount stores.
3) Is the computer dirty inside?
4) Is there a working computer that has a Compatible power supply, that you can borrow for a temporary test unit?
Won't hurt the Power Supply, if something is wrong with the computer.
(Unless of course you open it up, and everything is melted together inside the computer! lol!) {DOUBT IT}
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer ON a table, computer unplugged from power, computer case open;
TOUCH an unpainted area, on the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
OR,
Try what JLTJJ recommends,
http://www.fixya.com/support/t220703-dell_e173fp_stuck_in_power_save_mode
Post back in a Comment.
Regards,
joecoolvette
Posted on Jan 04, 2013
5 Suggested Answers
ghouliass
  • 105 Answers
SOURCE: my ibm desk top is stuck in power save mode monitor won't work
So the only way you have to act is, turned off and directly on the mainboard, so do it carefully.
You'll have to find out, where, on the mainboard is located the battery, (a small coin like
unpluggable metallic piece)
Remove it and let all static electricity completely disapear, so, let the cpu power unplugged,
battery removed, for 1h,
Then, place back, battery, try to start again if not working it's hardwaire failure.
Posted on Nov 20, 2008
  • 23 Answers
SOURCE: My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Posted on Jan 24, 2009
cinek79
  • 320 Answers
SOURCE: i have a dell dimension
Hi to resolve your problem switch it off from power, open it and reset BIOS (you can do it by: found reset pins and and put the jumper in reset position for few seconds and then put it to previews position, or remove CMOS battery for a while and put it back. Note that your settings will be reset and you need set it up again. Regards. If it help please rate it. Need more help let me know.
Posted on Jul 21, 2011
buda2832
  • 59 Answers
SOURCE: Gateway desktop enters power save mode while in use.
boot and adjust the power settings for all "when on A/C" to never. to take it out of power save press any key on the keyboard or press the power button (but dont hold it down)
Posted on Jul 08, 2012
Stop computer feom going into power save mode by itself.
You should be able to stop this by going into the control panel, select power options and change the settings for the hdd, sleep etc.
Just set them to 0 and that should stop it powering off.
May 22, 2014 | Dell OptiPlex GX260 PC Desktop
Jul 08, 2012 | Gateway Computers & Internet
Dell e521 is stuck in power save mode and flashing the numbers 3 and 4
Try Hitting the Power Button. Some systems require you to hit the power button to bring it out of Power Save, Sleep or Hibernation.
May 15, 2012 | Dell Dimension E521 PC Desktop
I have a dell dimension 3100 pc about 5 yrs old. Lately its stuck in power save mode and i can't get out of it. It happened when i had to manually cut the power supply at the socket as the screen was...
Jul 21, 2011 | Dell Dimension 3100 PC Desktop
My moitor is stuck in power save mode. I have done everything..I don't know what the problem is
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
Jan 07, 2011 | Gateway 500XL PC Desktop
When I leave my computer, after a while, the screen says that it is going into the power saver mode. When this happens, I can't do anything with the comuter. Can't turn it off, can't get the screen out of...
Basically you need to tell the computer to "wake up." Different systems come out of power-save mode different ways.
First, try pressing the key to the left of the [CTRL] button on the right side of the keyboard. It looks like a list with an arrow pointing at the second line.
Next, if you have a keyboard with a little button that has a quarter-moon logo design on it, press it.
Also, look at the power light indicator on the CPU. It should change color when it goes into power-save. If it does, try pressing the power button once for it to wake up. The same is true if there is a power button on the keyboard.
If none of these work, you should look at your preferences and make adjustments. The power-save mode adjustments are generally found in the control panel under Performance and Maintenance in the Power Options section.
Hope this works for you!!
Jan 13, 2010 | Dell Dimension 3100 PC Desktop
My computer(a dell) is stuck on save power mode
The reason your computer is in power save mode is because the little battery inside your tower is going dead. It needs to be replaced. It is a small battery about the size of a nickle inside your tower. Change the battery and it will solve your problem.
Apr 07, 2009 | Dell Dimension 4700 PC Desktop
Dimension E521 stuck in power saver mode
OK, I am sorry to say that it seems to be more than I thought. Here is a link to a forum where other people are having the same problem. I expected it to be a setting but this sounds like I'm wrong. I sure wish I could be more helpful. Here's the link though. Good luck, I know how frustrating it is.
http://forums.techguy.org/hardware/541286-monito-stuck-power-save-mode.html
Jan 31, 2009 | Dell Dimension 2400 PC Desktop
1r1sh
A+
Net+
MCP
Jan 24, 2009 | Gateway 506GR PC Desktop
My ibm desk top is stuck in power save mode monitor won't work
Nov 20, 2008 | Computers & Internet
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
