Stuck in power save mode on my desktop
My desktop is stuck on power safe mode and i have tryed to reboot it and fn and f8 and unplug and everything and i have gotten no were fast. I need this desktop for work.....HELP
  • Computers & ... Master
  • 5,660 Answers
sweetyanne
  • 68 Answers
SOURCE: Inspiron 530S Power Save Mode Loop
First you need to make sure that there are no other removable devices plug on the system, like usb, external hard drives, then if that will work try to go to the bios, press f2 when you see the dell logo, and go to the system setup, go to the boot device configuration and make sure that removable device is not the first boot device, if it is the first one choose hard disk and then second boot device ad cd rom/dvd rom and then disable the 3rd boot and the fourth boot device. Make sure to save the changes. And restart the system again. Once the computer is back and running try to go to support.dell.com and check the bios, download if there is a bios update for the system.
Posted on Oct 30, 2008
  • 33 Answers
VIRUS
Posted on May 28, 2009
  • 186 Answers
SOURCE: Can't factory restore dell inspiron 531 (windows xp).
You might want to try going into setup and setting your boot drive options to DVD drive as your 1st, HD as 2nd and Floppy as 3rd. Put your windows disk in the DVD before boot and run the program from DVD.
Posted on Jun 23, 2009
gherna1
  • 190 Answers
SOURCE: dell optiplex 760 won't go into safe mode
It sounds as though your PF keys are disabled by the BIOS settings. Try this:
Upon cold start or reboot get to the BIOS setup. You may have to press F2 or delete, or whatever key the first POST messages instruct you to use. Different BIOS manufacturers use different keys, and you have to be quick to interrupt the boot process using the correct key. If you fail to determine what key it is, reboot once again, until you see/read what key does the job.
Next, once you're into the setup screens, look for a section where you can set/deny access to the F8, F9, F10 etc keys during the boot process.
Make sure you ENABLE them, following the instructions on what keys to use to set/reset these choices. Make sure you SAVE AND EXIT.
On the next reboot, upon the disappearance of all POST messages, make sure you press the F8 key repeatedly until you see your OS boot options menu, among which you'll find Safe Mode.
Posted on Aug 24, 2009
  • 153 Answers
SOURCE: I have a dell optiplex sx280 computer and monitor
How's the status light of your computer monitor? is it blinking amber? and the status light of your computer tower's power button? blinking amber as well or solid green or no light at all?
1. Disconnect all the connection at the back of your computer tower
2. Press the power button of the computer tower for 15 seconds
3. Reconnect the power button and the monitor cable at the back of your computer tower and turn on the computer (if it turned on that means that one of the device plugged at the back of your computer tower is faulty)
4. If still the same problem, open up your computer tower.
5. Reseat the video card, Reseat Hard drive, Reseat Memory, Reseat CPU, Reseat power cord coming from the CPU to your computer (doing all things one-by-one to pin-point the root cause of the issue)
If none of the troubleshooting steps fixed the problem, possible that the power supply is faulty and if the power supply is faulty sometimes it goes with the motherboard.
Posted on Jan 09, 2010
I start my computer up put my pass word in and then the sreen goes blank with just the mouse arrow showing could you help
unplug everything... even the USB stuff what about 1min. then just put the power cord only back in and log back in.
Feb 07, 2015 | Dell Computers & Internet
Have a gateway computer and it is in power save mode cannot get it out of
Have you recently installed any updates? Have you installed any hardware? Have you tried unplugging it and hitting F8 to go into safe mode to restore it?
Jan 23, 2012 | Computers & Internet
It was rebooted because of virus. now it must b unplug from the wall then reconnected to get power.
Try booting it up in safe mode by holding down F8 on boot up and then download and install Malwarebytes and Super Anti-Spyware which are both free. Install them update and run one at a time.
Mar 14, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
On battery power screen dull fn plus arrow key does nothing
The screen is supposed to be dimmer on battery power. Your notebook does this so that the battery lasts longer.
Hope this helps!
Oct 20, 2010 | Samsung NC10-14GW Notebook
Dell Dimension 4600 will not reboot. I have to turn it off, unplug the power, push the On/off switch for a moment, let it set for 15 min then it will reboot. I have recently upgraded from 256kb ram to 1gb,...
from what you describe, they system will not shutdown. So try the following:
  1. Boot to safe mode (F8 at boot) and then see if the system will reboot from the safe mode.
  2. Boot to the Safe Mode again, Start RUN MSCONFIG, edit the startup group, (Basically uncheck all the items in the startup tab) reboot in the normal mode then see if it shutsdown. If it shutsdown normally, then start adding items back one at a time until you identify the items that were causing the items.
Jan 12, 2010 | Dell Dimension 4600 PC Desktop
When i apply power to my PC, it goes right into power save mode.
At boot up press F8 and boot in Safe Mode. Once booted then go to Start->Control Panel->Power Options. Here you will be able to set it up correctly to not go into power save mode immediately. Save and reboot - normally this time.
HAPPY HOLIDAYS
Dec 25, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Jan 24, 2009 | Gateway 506GR PC Desktop
Dell 1200 Inspiron OS boot problem
Two things you should try to resolve this issue: -
  • Check that the FN button on the keyboard to switch from the Laptop monitor to external monitor has not been enabled - these are usually 3 state switches (Laptop screen ON, External screen ON, Both ON) it is really easy to accidentally hit this without realizing.
  • If this works there is no need to try the second option.
OR
  • Try booting to safe mode - as the laptop boots up and you see the Bios summary screen depress the F8 button and you should receive a screen containing several options.
  • Select the option to Boot to safe mode.
  • If the laptop boots up ok then login to XP, don't be alarmed at the change in screen resolution.
  • Right-click My Computer on the desktop and select Properties - Hardware - Device manager
  • In the tree-view containing the different hardware select Display Adapters you should see your graphics card in there
  • Right-click and select Scan for Hardware Changes if it is ok the close and reboot as normal
  • If there is a problem here it implies the driver is somehow corrupted and may need re-installing from the disk that came with the laptop.
Nov 15, 2008 | Dell Inspiron 1200 Notebook
Computers & Internet Logo
David Payne
David Payne
