Question about Acer TravelMate 512DX Notebook
How to remove the keyboard on a travelmate 512dx?
I don't know how to remove the keyboard in order to replace the CMOS battery. Can you help
  • 15,935 Answers
CLICK HERE to see addendum to other post
Posted on Jan 19, 2009
BIOS
Step 1:
This might not be your laptop it might give you a guide into the cmos battery
The CMOS (Complementary Metal Oxide Semiconductor) battery saves basic settings on your computer. If the date and time function on your Acer notebook isn't working, chances are your CMOS battery needs to be replaced. Separate from your laptop's main battery, the CMOS battery is about the and shape of a coin and is located inside of your computer. Changing the battery yourself isn't the simplest task that relates to your Acer, but it isn't terribly difficult either. Here's how.
Open the notebook screen until you can easily access the keyboard. Locate the plastic bar that borders the top of the keyboard. Insert the flat head screwdriver at one end of the bar and gently pry it up until you can grip the edge with your fingers. Pry the other side of the bar up with the screwdriver and pull out the entire bar, being careful to mind the ribbon cord that connects the keyboard to the computer. Remove the two screws on either side of the keyboard that secure it to the computer. Slide the keyboard up and place it to the side. Remove the four screws on the exposed metal plate that covers the motherboard and remove it. You should now see the CMOS battery in the bottom-right-hand corner of the motherboard. Remove the battery by gently pulling it up and off the motherboard. Replace it with the same model battery (available at any computer store or online). Reassemble the computer the same way you took it apart. Acer TravelMate 6592G Keyboard Replacement Guide http://tomkaminski.com/acer-travelmate-6592g-keyboard-replacement-guide
http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Apr 01, 2013 | Acer Aspire One Netbook 8.9" Notebook
Acer travelmate 2700 bios password and where is the CMOS battry on the mother board
your bios battery is soldered into the mainboard, its under the keyboard, next to the modem board and the bios chip itself.
In order to get to the battery you would first have to dissasemble the laptop, remove the keyboard, power buttons, and the top of the machine. You may also have to remove the display if its holding the top of the cover in place.
Removing the battery is no guarantee of reseting the password. You need to study the bios chip and find out which pins of it you need to short in order to reset its memory. In some cases the password might be stored on another chip.
Oct 09, 2011 | Acer TravelMate 2700 Notebook
ACER TRAVELMATE 602TER: NEED TO REPLACE CMOS BATTERY. WHERE IS IT LOCATED? IF UNDER KEYBOARD, HOW DO I LIFT THE KEYBOARD (I DON'T SEE ANY SCREWS OR A FRAME AROUND THE KEYBOARD!) THE ONLY PIECE...
most netbooks allow the keyboard to be lifter out ,,upwards after inserting a thin piece of plastic/screwdriver at the reccommended points around the keyboard,usually there are tiny sprung clips that need to be pushed,you can hardly see them ,be carefull if you manage to lift the board out be gentle and do not tug or force it as it will be connected with a ribbon type cable to a very fragile plastic clip/socket.
Even this socket/clip will have another plastc sprung device holding the ribbon cable in so be carefull with it.
The CMOS battery is just like a watch battery held to the motherboard with a steel sprung clip,you might have to unscrew the motherboard first rarely this battery might be soldered in place so you might need to have an iron handy.
Jul 15, 2011 | Acer TravelMate 602TER PC Notebook
How do I do to find and replace the battery with a new one? Problem: CMOS battery bad. Real Time Clock Error. Best wishes Bengt Olson Sweden bengt.olson@telia.com
The CMOS battery will be beneath the keyboard and is usually a button cell, (2032 or 2025 size) 3 volts. Just north of the touch pad possition.
Oct 22, 2010 | Acer TravelMate 512DX Notebook
Cmos battery bad real time clock error
Is time to replace the battery. Is gone.
May 05, 2010 | Acer TravelMate 512DX Notebook
How to remove keyboard to change cmos battery for Acer TravelMate 529ATX PC
I have an Acer travelmate 529ATXV and need to change the CMOS battery. I think it is under the keyboard but I am not sure how to remove the keyboard. Any help would be appreciated.
Mar 08, 2010 | Acer TravelMate 529ATX Notebook
Where is the location of the Cmos battery for my
You really need a service manual to try & locate the CMOS battery. With laptops the CMOS battery can be different on each model. These are often located on the motherboard below the keyboard, but a service manual should help you.
Nov 01, 2009 | Acer TravelMate 240 Notebook
Keyboard removal on a TravelMate 512DX PC Notebook
The battery could not be fished out afer removing the memory expansion door?
Jan 19, 2009 | Acer TravelMate 512DX Notebook
I can't find the cmos battery in my Acer TravelMate 512DX
you have got an older model, try this:
follow the instructions:
you will need:
a slim x-screw-driver
a sharp knife with a slim blade and
a cup or else for the screws, don't loose them!
a new c-mos bios battery model: CR-1220 (exchange it while your in there!)
you find c-mos battery and hdd under the keyboard!
- turn off the power, remove accu and charger cable, for static electricity is friendly fire
to your laptop now !
- open your screen to max. fold (angle of 180 degrees)
- look for removable plastic part near to left holder of screen
- carefully remove it
- also remove plastic panel right to it in the section between display holders
metal should be visible now
- carefully! remove keyboard, starting at the left side, continuing topside
as you won't be able to fully remove it, simply turn it over
- unscrew any screws holding the metal plate, remove it
- now you see: left the CPU plus cooler, top right middle the hdd still in an adapter attached
to the mainboard, at it's lower right the C-MOS battery (g
- turn loos these screws
- carefully remove the frame/adaptor holding the hdd
- unscrew again the adaptor
- seperate hd fram adaptor
... and gotcha!
be careful to get a proper notebook hd (samsung or such)
exchange CMOS-battery by chance
reattach new hd to frame, again carefully!
to reassamble: rewind the procedures
put everything back in place
replug, pray and turn on the lappie.
wish you luck.....
Cmos battery for C110 TCI
The CMOS Battery is behinf the main battery behind a platic shield. The shield is relitivly fragile and glued around the edges. Care should be used removing it to prevent ripping. The battery itself is 3" flat pack glued to the case. Mine was wrapped in a black heat shrink with two wires exiting.
The connector is under the keyboard. You will need to remove the 6 scres from the bottom of the case to release and remove the keyboard. The keyboard ribbon cable is attached through a ZIF socket. Be sure and release the cable before removimng the keyboard. Youll have to trace the CMOS battery leads to determine the correct connector.
I found a Maxell ML2032 rechargable battery. Unfotunatly all the 3" flat pack batteries I have found are LITHIUM ION and not rechargeable. If I find a replacement I will post the information.
Apr 27, 2008 | Acer TravelMate C110 Tablet PC
Acer TravelMate 512DX Notebook Logo
221 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
