Question about Acer Aspire One Kav10 Netbook
I only want to use the left click to click on items and not thave the touch pad click on items
Is it possible to only use the left click button to click on items instead of the tapping or double taping on the touchpad
    New Friend:
Yes, depending on what mouse you have, most of the time you need to install it, if its not installed, go to the control panel, select the mouse category, This will help install the drivers. Should solve the problem. If mouse driver is installed, control panel, select mouse category, and a mouse properties box will display.. check to make sure the switch primary and secondary buttons option is not checked.
Posted on Jan 04, 2013
  • Mrtherv Jan 04, 2013
    Thanks for your impute. Unfortintinly that is not the answer I was looking for. I guess I should ask how do I stop using the mouse to click on items or double clicking on items? I only want to use the left button to click on items and use the mouse to only move the curser.
  • Larry Young Jan 04, 2013
    sorry, misunderstood your question.
PABLOCSA
  • 1124 Answers
SOURCE: laptop touch pad, left and right click buttons not working
Go to Toshiba website and download the touchpad driver, and reinstall it again
Posted on Nov 17, 2008
davepcrepair
  • 75 Answers
SOURCE: Acer aspire one touchpad right button not working
you can try using the function key ( fn ) and the touch pad key on my acer it is the F7 key hold the fn key and press and release the touch pad key that will turn the touch pad mouse off and on also goto control panel / mouse and try switch primary and secondary see if that will make the right button work if not its probly hardware related and your best bet is to keep the external mouse going rather than fixing that one
Posted on Mar 24, 2009
SOURCE: touch pad not working correctly
If u are having Synaptics Driver....then
check that Tapping is enabled...
follow steps to know that:
Open Control Panel..
Now Open Mouse
Now click on tab "Device Settings"
then Click on "Settings"
a new window popups
Click on "Tapping" which is listed on the corner of the window
Now after clicking on it...on the right...check that there is "Tapping Enabled or not"
if not...click on that White box...
and Apply
then ok
Done :)
_________________________________________________________________________________
Sorry 4 my english!
Posted on May 17, 2009
ta_mcguire
  • 125 Answers
SOURCE: acer d150 left trackpad button not clicking/working
go to control panel click on mouse and set for right handed
Posted on Jul 30, 2009
yboyandrei
  • 828 Answers
SOURCE: My touchpad will not respond when I tap it
On the bottom bar by the clock, if your computer is newer there should be a small icon that controls your mouse. Simply right click on it and check the box "tap to click" or similar. Hope this helps!
Please rate me if i am helpful.
Thank you.
Yboyandrei
Posted on Aug 22, 2009
Testimonial: "Thank you so much! BINGO! I am so grateful. God bless you."
Unlock cursor for acer laptop
Your laptop comes with a touch pad that acts as a mouse. Instead of connecting a mouse each time you want to use your laptop, you can use the touch pad that is integrated underneath the keyboard. This comes in handy when you are in a tight spot such as in a classroom or on an airplane. At times, you may need to unlock the laptop touch pad because someone who borrowed your laptop disabled it. It may also be locked due to a slight malfunction that you can easily fix by enabling the touch pad in your computer settings.
Click the Windows "Start" button in the bottom-left corner of your desktop. Scroll up and click "Control Panel." Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner. Click the "Enter" button and then click the "Mouse" link. Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have. If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button. If you are under the touch pad tab, click the enable button. Click the "Apply" button and then click the "OK" button. Hope this helps.
Dec 08, 2012 | Acer Computers & Internet
Unlock mouse intel core 15
depending on your laptop this will vary
If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad.
To enable your mouse pad on a Windows PC go to the Control Menu.
Under the Printers and Other Hardware option, click on Mouse.
Then, click on the tab on the top of the pop-up menu that says Device Settings.
The touch pad for your computer should come up as a selectable option.
Click on it and you will see the option to enable your device, then click OK
or
Right-click on a blank spot on your desktop. Scroll down, select "Personalize" and then choose "Mouse Pointer."
Click the "Device Settings" tab. Highlight your TouchPad in the "Devices" section. Hit the "Enable" button.
or
Click the "Start" button in the lower-left corner of your computer.
Type "mouse" in the field above the button. Click "Mouse" in the list of items that appear.
Click the "Device Settings" tab. Highlight the touchpad item in the "Devices" list.
Click the "Enable" button. Click the "Apply" button and then the "OK" button.
hope this helps
Sep 25, 2012 | Intel CTL E09L 2goPC Laptop
How can i activate my mouse sensor???
or
or
hope this helps
Sep 24, 2012 | Acer Aspire 5102WLMi PC Notebook
How do i turn on touch pad
You probably have a Synaptics Touchpad. What you have to do is look for the Synaptics logo(it's like a white circle on a red background) in your status bar(lower right corner of the scree, neer the clock). Double click that icon. A window called Mouse properties appears. The last tab is Device settings that also has the Synaptics Icon. If you click it you should see a list of all Synaptics devices on your laptop. Since you only have one you will only have one item in the list. Double click that item and a new Properties window will open. You have a list on the left side of that window. Select tapping and make sure Enable tapping is Checked. That should be it.Good Luck!
Nov 16, 2011 | Compaq (153515-001) Touch Pad
I have a Sony Vaio and though the touch pad allows the cursor to move around the page it does not allow me to click on anything. I have a Logitech mouse that I use but that is because the touch pad is not...
You may need to enable the buttons for Sony Vaio Synaptics TouchPad as follows...
1. At the bottom left of the screen on the Taskbar, left-click on start.
2. On the pop-up window, left-click on Control Panel.
3. In the Control Panel window, left-click on Sony Notebook Setup
4. On the Sony Notebook Setup pop-up, left-click on the Device tab.
5. Left-click on Pointing Devices to high-light it, then left-click the Settings button.
6. On the Mouse Properties pop-up window, left-click on the Device Settings tab.
7. On the Devices listing for Synaptics TouchPad, left-click the Settings button.
8. On the pop-up window Properties for Synaptics TouchPad on PS/2 port....
9. Left-click on Buttons item to bring up a Buttons frame with an Enable buttons check box.
10. If the check box is not checked, left-click on it to enable the buttons for the TouchPad.
11. Left-click Apply button or OK button to enable TouchPad buttons and exit the pop-up window.
Feb 01, 2011 | Sony Computers & Internet
Touch pad doesn't work
Determine What's Wrong
laptop'smag-glass_10x10.gif touch pad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touch pad may be damaged by excessive use or foreign substances such as water, dirt or food items.
Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return."
Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touch pad to become unresponsive. But if any of these steps fail to remedy the problem, then the touch pad may need to be repaired or replaced.
Repairing/Replacing TouchpadA touch pad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touch pad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touch pad is deemed a necessity, such repairs are rarely worth the cost.
Attempting to replace the touch pad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop.So just attach a mouse to it so you can work easily.Please rate me if this solution works for you
Thanks......Have a great time.
Jul 28, 2010 | Computers & Internet
The touch pad, left & right clck buttons.
  • Hi, click on the "Start Button," next in the (right area) click on the "Control Panel." In the window there will be "listings" different categories; choose the "Mouse," from the "Hardware and Sound" click on it to open the next window. Next select the "Device Setting" button, once the window open, click on the "Setting" button just below the"highlighted" TouchPad, or Mouse. The area of your immediate concern is the "Buttons" put a [check] mark into "Enable" buttons. Try out some of the "items listed" Tapping, Virtual Scrolling... "You must click on the "Apply, OK buttons when finished." Note: Restart the computer; this will make sure the changes are correctly applied, and working properly. "Rating the solution will let me know if the problem is fixed, or you will need further assistance, thanks."
Jun 19, 2010 | Toshiba Satellite A135-S4527 Notebook
Touch pad working fine but left clicker doesnt
Usually the green means that the button is pressed. Check the touch-pad buttons for dust or dirt. If they're clean, then probably need to be repaired.
Aug 26, 2009 | Computers & Internet
How to set up mouse pad so it works with touch
Check in the control panel under mouse. There should be a setting to enable tapping. If there is a touch pad icon on the bottom right of the screen you can also right click on that and select options.
Dec 31, 2008 | Gateway MT3705 Notebook
Broken Button
Hello Roinette,
It is unfortunate to know about that. However as you told that the left click button of the touch pad for you acer laptop has broken or damged, the only way to get it resolved is to get the laptop serviced. As the laptop touch pad and keypad is integrated directly with the mother board it is not possible to fix just that paricular button. The pad must be replaced. Get in touch with the acer technical support , they will replace the pad for you.
Thank you. Best of Luck.
Oct 20, 2008 | Acer Aspire 3100-1405 Notebook
Acer Aspire One Kav10 Netbook Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
