Question about Sony CDX-M800 CD Player
Sony cdx-m800 unlock code - Sony CDX-M800 CD Player
  • 49 Answers
SOURCE: sony cdx-m800 code
These are the official codes from Sony, you will need the remote to enter, only one will be required by your unit:
1) DISC+ SOURCE LIST OPEN/CLOSE
2) OFF SOURCE ATT OPEN/CLOSE
3) MODE PTY/DSPL SOUND OPEN/CLOSE
4) SOUND MODE ATT OPEN/CLOSE
5) MENU ENTER MODE OPEN/CLOSE
6) SEEK- SEEK+ MODE OPEN/CLOSE
7) OFF PTY/DSPL MODE OPEN/CLOSE
Let us know how you get on
Posted on Jan 14, 2008
SOURCE: sony cdx m610 car stereo
sound - mode - att - open/close
pres buttons buy this order.
Posted on Aug 25, 2008
SOURCE: SECURITY CODE
hey could sum1 please give me a securitey code for my sony cdx-800 much appraitated
Posted on Nov 01, 2008
tech48
  • 624 Answers
SOURCE: sony cdx m800 no display
I think you are going to need the service manual to properly troubleshoot this. You can try to follow these instructions without one, but having one makes it so much easier. You will need to have the radio on a work bench with the CD mech out and the harness out of the car as well so you can turn on the radio and check some voltages. Since you are an electronics engineer, I should not need to point out any safety precautions, after all, I am just a technician.
For starters, check the voltages at pins 7,8,15,16,17 on connector CNP909 the 24 pin connector for the display on the main board. Pin 1 should be the one closest to the corner of the board that connector is near. Pins 7 and 8 should have 10 volts each, pin 15 should have 5 volts and 16 and 17 should both have a much higher voltage. I suspect you may be missing the 10 volts from pins 7 and 8. If so, check the voltage at the emitter of Q914 on the main board. It is a digital transistor (surface mounted) and when the power is on it should have 10 volts there and 10 volts on the collector and zero volts on the base. If any of those voltages are not there, check Q915. It should have 10 volts on the collector, 5 volts on the emitter and 5.6 volts on the base. It is not a digital transistor but is surface mounted and much bigger than Q914. If you are missing the 5.6 volts on the base, check the zener diode D905. It should have 5.6 volts on the cathode and ground on the anode. The cathode goes directly to the base of Q915. Use your multimeter on the diode check mode and see if it looks normal. Could be that zener diode is shorted. There is also 2 capacitors in parallel with that zener, C928 and C930, check those as well. If one of them shorts out it will look like the zener is shorted.
You can also check CNP805 for the 10 volts, it is supposed to be there as well. I don't know what pin number but I think that connector is on the top of the board. The 10 volts should be either pin 5 or pin 7, depending on which side you start at. CNP805 is the connector for the sub-board with the reset switch on it. After you know what these voltages are on CNP909 we should be able to narrow down the problem.
I hope this helps, I really do not have a lot of time right now. I have a power supply to fix and a big stack of car amplifiers to repair. Let me know if you need more help, I just may not be able to answer as quick as you may like, but I will answer when I have time.
Dave
Posted on Jan 27, 2009
SOURCE: son cdx m800 code contatcts
pleace send pin code cdxm800 sony
Posted on May 05, 2009
Lost code for sony cdx-m800
You can enter a 4-digit security code as an option after purchase of the unit. If you do so, make sure it is noted down somewhere. If you did select a code (or the previous owner has done so) this must be used when the unit is removed from the vehicle, or the constant power source is disconnected from the unit. When constant power is restored to the unit, the security code must be entered before the unit becomes operational. If the code is lost or forgotten I am afraid the unit has to be re-coded by a Sony dealer.
Hope this helps, Good luck with it.
Apr 02, 2011 | Sony CDX-M800 CD Player
Need info on a Sony Model CDX-M800 the radio came
Installation/Connection Instructions:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CDXM800&region_id=1
Nov 05, 2009 | Sony Car Audio & Video
Son cdx m800 code contatcts
Jan 23, 2009 | Sony CDX-M800 CD Player
Black out
this is a coincedence. The CDX-M800 had a HUGE problem with the ribbon cable on the face going bad, causing this exact problem.
$14.00 and some time will put it back into perfect condition.
http://cgi.ebay.com/ebaymotors/Fix-your-Sony-CDX-M800-flexible-ribbon-cable-CDX-M800_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ43947QQihZ020QQitemZ300287945333QQrdZ1QQsspagenameZWD1V#ht_2258wt_1213
Jan 21, 2009 | Sony CDX-M800 CD Player
Can you help me?
That ribbon wire is called as "data cable or IDE cable" You can find it at any computer store..Should cost you around 3$
Dec 01, 2007 | Sony CDX-M800 CD Player
Please help
you can buy these from ebay just type in sony cdx m800 ribbon theres loads on there pretty cheap aswell hope this helps
Sony cdx-m800 code
Oct 18, 2007 | Sony CDX-M800 CD Player
SECURITY CODE
Apr 23, 2007 | Sony CDX-M800 CD Player
Sony CDX-M800 CD Player Logo
20 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
