Question about LG enV VX9900 Cellular Phone
Lg env v pairs with jawbone but won't connect. is it the code?
Is it the code....????
  • 4 Answers
I have had the same issue with MY Samsung bluetooth headset.
Here's the sequence that works for me:
  1. Delete the headset under the bluetooth menu.
  2. Turn off the bluetooth
  3. turn on the blue tooth
  4. Add the headset back. The default pair code for most devices is "0000" or "1234"
  5. Try to enable/connect. If it fais, simply power off the enV.
  6. Power on and try to connect again (just connect, not pair)
  7. Headset will then pair.
KingGypsy in Phx.
Posted on Jan 23, 2009
  • Norm Hurst
    Norm Hurst Mar 01, 2012
    This got it going again. Thanks! I think the power cycle was key.
Jawbone won't pair with iphone
Hi, you need to plug the jawbone to a computer in order to connect it for the first time to your phone, it can also be an issue with your phone bluetooth, restart might solve it.
Feb 17, 2014 | Apple iPhone Cell Phones
How do i pair my jawbone bluetooth headset to my envy touch?
I found this on another website and it worked for me.
"I was also having a lot of difficulty getting my Jawbone II or "new Jawbone" into pairing mode. I finally ended up carefully removing the outer plastic shield. It popped off without breaking anything and then I was able to easily press BOTH the noise shield button AND the talk button. With the plastic cover OFF, I was able to put my Jawbone into pairing mode on the FIRST TRY!"
Jan 19, 2011 | LG enV Touch VX11000 Cell Phone
Jawbone not connect with phone
Is the jawbone in pairing mode (this means either a solid light on the jawbone by pressing and holding the button. Or it could be a flashing light. Either way you need to be in pairing mode for your phone to discover it.once it is pairing mode the pairing code is "0000" put this in and the light should flash off on the bluetooth
Aug 26, 2009 | Motorola Cell Phones
I can't get my jawbone to pair with my palm centro any idea's
With the jawbone turned off, press at the same time the turn on button and the noise reduction button. The jawbone should blink white and red for three minutes, in that time you shoul be able to find it as a bluetooth device in the free hnd configuration of the palm centro. than yu complete the conection by inserting the code. The next time you turn on the jawbone it will connect with te palm.
Aug 09, 2009 | Palm Treo 500 Centro
I have an LG EnV that will pair but not connect with my LG HBM 210 headset. It worked before but just stopped.
Try removing the battery of the phone while the phone is powered on. Replace the battery, power on the phone, and try to re-pair your phone.
Jun 29, 2009 | LG enV VX9900 Cellular Phone
Can't connect my jawbone with my phone
"I was also having a lot of difficulty getting my Jawbone II or "new Jawbone" into pairing mode. I finally ended up carefully removing the outer plastic shield. It popped off without breaking anything and then I was able to easily press BOTH the noise shield button AND the talk button. With the plastic cover OFF, I was able to put my Jawbone into pairing mode on the FIRST TRY! "
Jun 02, 2009 | LG Vu CU920 Cellular Phone
Cannot pair lg voyager with jawbone bluetooth.
Mine wouldn't pair either so I went to the jawbone site and I did this and it worked the first time.
For Jawbone ICON, while the power is off, press and hold down the Talk button and slide the power switch on. When the LED starts to flash red and white alternately, release the Talk button.
1. Press the OK Key.
2. Highlight SETTINGS & TOOLS and press the OK Key.
3. Select Bluetooth Menu.
4. Select Add New Device. (If Bluetooth power is set to off, you will be prompted to turn power on. Select Yes and press the OK key.)
5. Highlight Jawbone and press the OK Key.
Enter the PIN "0000" (be sure to enter four zeroes and not the letter "O") and press the OK Key.
Mar 22, 2009 | LG VOYAGER VX10000 Cellular Phone
My Treo 755p will recognizes my new jawbone but will not connect. It seems to skip the step where I am supposed to enter a password into to connect to the jawbone. Any ideas? Josh
Delete any other bluetooth devices paired to your phone. Then, for the Palm Treo 755p . . .
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Jan 26, 2009 | Palm Treo 755p Smartphone
With use of Jawbone, recipients on enV get voice echo
About three months ago I bought the LG En V touch from a verizon store. I planned to use it with my old "New Jawbone" and my new "Jawbone Prime". The phone would nto pair at first then when they finally got it to pair I had a variety of problems. Verizon technicians performe a number of different steps trying to make it work as it was supposed to. They even reinstalled the software after about a week and a half I persuded the Verizon stor manager to replace the phone with a new LG EnVtouch and they exchanged my Jawbone Prime also. The new LG EnVtouch had the exact same set of problems. Neither of these phones worked any better with the bluetooth in my Garmin NUVI either. I loved the design and the features but if it doesn't work why bother. I returned the second LG EnVtouch after aabout five more days of frustration. And went back to my old phone. If you buy one of these and it doesn't work return it fast and let them know what you think!
Apr 20, 2008 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
621 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
