Question about Plantronics Voyager PRO Bluetooth Headset
Plantronic voyager legend won't pair with iphone 4s contacts
Paired to two devices with no problems, but I cannot use the 'call' command, it doesn't seem to recognise any names.
supernova278
  • 1932 Answers
SOURCE: Trying to connect Plantronic 220
1.First switch on the bluetooth in mobile phone.Keep the headset switched off.
2.Now press the call button for 2 seconds if you are paring this headset for first time,If this head set is aired already with another mobile press for 8 seconds until the headset status indicator begins to flash blue then red
3.Now search the bluetooth by your mobile device.It detects and you can pair it
Thank You
Posted on Nov 10, 2010
  • 34 Answers
SOURCE: Pairing LG Shne cu720 to Plantronics Explorer 220
Try holding down the button on head set untill the phone reconizes
Posted on Jan 03, 2009
SOURCE: Plantronics Voyager 520 &having trouble pairing it w/LG VX5400?
i am having a problem getting my explorer 230 to conect with my phone can any one help?
Posted on Mar 02, 2009
award462
  • 395 Answers
SOURCE: PAIRING PLANTRONICS BLUETOOTH WITH IPHONE 3G
On your phone. goto the Bluetooth menu and select "Add Device or Add Headset"
Refer here to put the headset into pairing mode:
http://www.fixya.com/support/r5009033-put_most_bluetooth_headsets_into_pairing
Posted on Jun 02, 2010
IPhone not pairring with parrot ck3100: I pressed "forget this device"
remove other paired devices on your device, may be the device has crossed the limit of phones it can connect.
start pairing fresh on both devices- phone and bluetooth device.,
Jun 06, 2017 | Apple iPhone 4S
My iphone 4s can not find my 903
Once you make your iphone discoverable, then put the Plantronics 903 headset into pairing mode by pressing the power button until it flashes red and blue. If it's not flashing red and blue, it's not in the pairing mode. Below is a link for the user guide which has the pairing instructions:
Plantronics BackBeat 903 Pairing Instructions
Good luck from Headsets Direct!
Nov 25, 2011 | Plantronics Backbeat 903 Bluetooth...
My iPhone 4s won't pair with this kit hkt 300 by
Hi
I have just paired my Iphone 5 with the Hkt300.
I used the code 0000 while holding down the button on the car set.
Have fun
John
Nov 04, 2011 | Samsung Radio Communications
Plantronics voyager pro plus is connected and paired with blackberry tour. when a call is coming in, I cannot answer or hang up the phone from the bluetooth headset.
Make sure that your Blackberry's headset mode is activated. If the headset mode is turned on in the Blackberry menu and settings, you may also need to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
My plantronics 330 is paired to my iPhone 4. It works fine with the phone, but with no other applications. I want to hear the mapquest voice directions on my iPhone through the ear piece but it doesn't...
If you would like for your Bluetooth headset to stream music or any other audio applications to your phone, the Bluetooth profile in both devices must support Advanced Audio Distribution (A2DP) for audio streaming. Unfortunately the Explorer 330 does not support this newer technology. I would suggest updating your headset to a newer model but remember your phone must also support A2DP. The Plantronics Voyager Pro+, Voyager Pro HD & the M1100 Bluetooth profiles support A2DP. I will include a link for Bluetooth headsets below.
Bluetooth Headsets that support A2DP
Nov 21, 2010 | Plantronics Explorer 330 Headset
I've plugged everything in, no signal on headset...what could be the problem?
Make sure that the Plantronics Voyager 510S / 500A headset is powered on (remember that it has an individual power button on the actual headset), and that it is paired up to the 500A base unit. Below is a link for the user guide.
Plantronics Voyager 510S/500A User's Guide
Oct 27, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Have a 500 plantronics wireless headset/base, which are connected to either a meridian 2616 or 3903/04 and not able to get the dial tone on the headset (all cables are connected / move frecuency in the...
The Plantronics 500A base should be plugged into the handset receiver jack on the phone, not the headset jack. It could be that the headset needs to be re-paired to the base unit, or the lifter is worn out (if using one). If you manually remove the handset receiver from the phone, and you power on and activate the headset, does sound come through ? If so, it may be the lifter. Here is a link for the 510S / 500A user guide to troubleshoot, and also a link for the pairing instructions.
Plantronics Voyager 510S User's Guide
Plantronics Voyager 510S Pairing Guide
Aug 01, 2010 | Plantronics Voyager 500A Deskphone Adapter...
My Plantronics Voyager 510 will not go into pairing mode.
i actually got this to work with my iphone 3G S. i pressed the little black button then saw a blue light flash, and then i pressed and held the + volume button and the call control button until it started blinking blue and red and my iphone picked it up instantly. it did take a couple of times to get the headset to go into pairing though
Jan 16, 2009 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics Voyager PRO  Bluetooth Headset Logo
619 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
