Question about Makita DC18RA Rapid Battery Charger For LiIon NiMh NiCd Batteries
DC18RA battery loader is not working anymore.
When power 230VAC is connected the green light is on. When battery is in slot red and green are intermittend blinking.
  • Makita Master
  • 885 Answers
Makita chargers are designed to check a battery before charging them. If both the red and green lights are flashing after you put a battery on the charger, it is reading a problem with the battery and will not charge it. It could be a bad cell, a problem with the circuit board, etc. but as long as it reads the problem it will not charge the battery.
Posted on Jan 18, 2013
Fault Light/ inverter failure
the current from the 12volt supply is not sufficient try a fully charged car battery instead, your inverter needs 30 amps and above of current from 12 volt power supply
Jul 20, 2013 | Televison & Video
My dc18ra makita battery charger flashes red and green lights no matter how many bateries i try
The pcb inside the battery has a microcontroller that monitor the charges and charge cycle. When the cell falls below a certain voltage, it will instruct the charger not to charge and will show with a red-green flashing light. If the battery has been tried 3 times in succession then the pcb will brick itself from the makita charger. So first replace the bad cells. There are 2 solutions at this moment: charge with a 3rd party lithium charger like the imax b6 or replace the pcb with a working one. check out my blog on http://mkbl1830.blogspot.com/
Mar 17, 2012 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita DC18RA Makstar Li ion Charger three lights
Alternate Red and Green flashing means bad battery. Buy a new one, or take it to a Makita Service center for replacement if it's under warranty.
Normally the yellow light indicates hot battery, but it could also mean dirty battery contacts so the heat sensor can't be read, or that the fan is clogged with dust and unable to cool the battery. The manual says let the battery cool and try again. If the yellow still flashes, it's contacts or the fan.
Read the manual online at:
http://www.makita.ca/data/upload/accessorypbim/417_im_english.pdf
Oct 28, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Red and green light flashing on 5 of my bl11830 battaries and they will not take a charge
If you put a battery on your charger and both red and green lights flash it is indicating that battery is defective. There may be a short in the battery or they just may be too old and worn out to charge anymore. If the charger is reading the battery as defective it will not charge the battery. The only fix is to buy new batteries.
Jan 20, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Red and green light flashes alternatingly with only one of my batterys of my makita 18v li-ion fast charger
unplug charger to let it reset. plug back in and then try again, if it still flashes red/green that would indicate a battery failure. check for warranty replacement.
Aug 26, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Hi, My Makita DC18RA won't charge anything it just flashers the red and green light simultaneously it is not the batteries because I can charge them fine using anther charger. What is wrong with the...
none of these answers help. you cant return old chargers to the store, and the poster said his battery charged on a different charger. i have the same problem with 2 makita battery chargers and need to know if there is a part inside the charger that can be replaced.
May 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
When put on charge the green and red light flash
Yep, not the batteries, mine is doing the same thing but my second charger works fine with the same batteries
Jan 19, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
MAKITA LXT BATTERY CHARGER
hey
flashing orange=cooling abnormality.
you need to wait for the battery to cool.
see my mod page, it has all light explanations in it.
Have fun
Avi
Jan 09, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita DC18RA Rapid Battery Charger For LiIon NiMh  NiCd Batteries Logo
288 people viewed this question
Top Makita Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
