Question about NEC-Mitsubishi MultiSync 1735NXM Monitor
DVI port not working
I tried hooking up my ps3 to my nxm1735 monitor using a hdmi dvi adapter but when i plug it in the screen goes black and says check video cable nad then turns off when i turn it back on the screen is blank. I checked my hdmi dvi port with cable on a friends computer and it worked fine but when i tried it to my monitor it just said the same thing. Please advise me on what to do.
  • acdcdude54 Jan 19, 2009
    but how do i do that?
    Champion:
  • 203 Answers
Change the resolution of the screen the computer does not suport that resolution, if you chang that will be ok.
Posted on Jan 19, 2009
  • Daniel Florin
    Daniel Florin Jan 20, 2009
    start the pc in SAFE MODE at the boot time  pres F8 and chose SAFE MODE with windows , than go to CONTROL PANEL DISPLAY OPTION and change seting from there .chek on your friend to see what is the corect resolution of the creen tha pu the same rezolution on your's.
My monitor(HPL1950) was working good until i unplugged it to play on PS3. When i connected the monitor to my PS3 with HDMI it showed black screen. There is photo showing the screen. Help please
If your cennecting using an hdmi to dvi then you might want to check that your ps3 is only sending video and not video and sound as not all screens have a dvi port that supports sound and dvi. Also it could just be a resolution issue. Try having the resolution of your ps3 to 720 or possibly lower and see what happens. Then if all good work your way up to find what your monitor can handle.
Nov 07, 2015 | Video Game Consoles & Games
ASUS Motherboard AT5IONT-I, Win7pro,4G RAM,SSD. Everything works fine with a screen plugged into the DVI connector. HDMI output does not recognize any screen, tried everything, installed latest Nvidia...
i have the same problem!
AT5IONT-I, Win7pro,4G, bios 0502
tried many screens, nvidia driver versions etc.
hdmi only works in single monitor configuration. hdmi blanks on detection of dvi monitor. argh!
Apr 18, 2011 | ASUS Motherboard AT5IONT-I Atom D525 ION...
I have my PS3 hooked to the HDMI port, but the monitor won't switch inputs to the HDMI port. If I have something plugged into the dvi port it works fine, but I currently need only the HDMI port, and do...
There are a varity of HDMI cables, ensure that your version is supported also using the input touch "button" to change the input through VGA, DVI and HDMI.
damnor01
Nov 22, 2010 | Acer H233H bmid Monitor
How do I hook up the moniter to the CPU?
First figure out what output video the computer has. These days it can be VGA, DVI, or HDMI. Then determine what video inputs are on the monitor (same list). Then plug in the desired cable. Many monitors only come with the VGA cable. If you do not have a VGA port on the computer you would need a DVI to VGA adapter to use that cable. Otherwise buy the DVI or HDMI cable. (DVI to HDMI cables exist if you have HDMI but no DVI on the monitor and only DVI on the computer. However, you need to check your video specs closely. A Single link DVI is different than Dual-link DVI and the cables are not interchangeable.)
Once the data and power cords are plugged in, power up the monitor and then the computer. The computer should find the new hardware and install (or ask for a disc to install) the drivers.
I hope this helps.
Mar 20, 2010 | Gateway Computers & Internet
PS3 to Infocus LP 350 projector using HDMI
M1-DA is a type of DVI connection that produces both analogue and digital signals, the easiest and most quality source cable for you to get is a HDMI to M1-DA cable which is now widely available for purchase.
Infocus should have included this cable in with your projector, but instead the power at bee decided to put a M1-DA to DVI-D cable instead when most visual devices now support HDMI and not DVI nowadays.
Thanks
Sep 04, 2009 | Sony Playstation 3 (PS3) Console
My monitor says cable not connected
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck
Jul 03, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Apple 20" display black screen
I've read that aftermarket DVI cable adapters don't work well with this set-up. You might try the Apple DVI to ADC adapter. It's expensive but I see them on eBay or craigslist from time to time at less than half the normal $99 cost.
Aug 26, 2008 | Apple 20" Flat-Panel TFT LCD Cinema...
Ps3 hook up
Yes, you can! But not straight out of the box. You need to purchase a DVI to HDMI cable adapter. It will convert it so your tv can use it. Here is a link to some:
http://www.connectworld.net/syscon/dvi-to-hdmi-adapters.html
Hope this helps! Please rate me!
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
371 people viewed this question
Top NEC-Mitsubishi Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
mukhtar21 shaikh
mukhtar21 shaikh
Are you a NEC-Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
