Question about Philips 55PP9363 55" Rear Projection HDTV-Ready Television
TV will not power on
Hello, I have a 3 year old TV bought from Sears and it will not power on. All of the other units that are plugged in the same extension outlet have power but the TV does not. Is this a power supply issue; Can i buy a new power supply to replace the old one? PLEASE H E L P.....
  • Jean Delsoin Jun 27, 2007
    Thank you for your quick response, i will have someone come and look at it. Do you know where the reset button would be, i did not see one behind the TV? I am not sure if i will ne to open the back of it.
  • Anonymous Feb 22, 2009
    tvshuts off after 20 seconds
  • 432 Answers
I guess you already tried different outlets and plugging the TV straight to the wall outlet. DO NOT ATTEMPT TO WORK ON THIS YOURSELF!! Have a qualified tech come out and look at it. First, call around, found out where the reset button is. Get price quotes.
Posted on Jun 27, 2007
6ya staff
SOURCE:
3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Dec 10, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
2 year old Kenmore freezer won't keep cold. It
Check underneath the unit and make sure the compressor is running and that the compressor fan is turning.
Oct 15, 2009 | Freezers
Hello, I have an RCA Truflat tv that I bought
If you can hear sound and the sound coems from your TV, try changing the volume with teh TV remote control. Your TV isn't off it is still on. Just the video board or portion is cutting out. this could be a ton of things, I would try changing out the power strip or plugging the tv into the wall directly to make sure it has enough power. other then that you can try a home brew solution like putting a fan next to your tv to cool the component that seems to be overheating and shutting down your picture.
Aug 25, 2009 | RCA Televison & Video
Hello my dryer is only 3 years old. Last night it stopped drying. The drum will turn and the light comes on. It is an electric dryer. What might be the problem. Thanks.
Have you tried a different cycle? The thermostat that controls heat has failed. There are more than one for the different heat settings. Try a different setting, then go from there.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 01, 2009 | Dryers
I have a 35 year old Sears garage door opener.
Buy a new unit. this old unit is not safe and therefore parts will no be available.
Jan 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
1/2 the picture
Hello
You will have to a tec. for this one as you have lost half of your vertical sweep.
Sorry
guy9
Jun 16, 2008 | LG 42PX5D 42 in. Plasma HDTV
Television will not turn on
My 47" Vizio wouldnt turn on this morning.....had a similair problem 3 yrs ago.....this is what i did and fixed the problem myself.....apparently you have to reset TV. Here is what has worked for me. So unplug tv power cord from the tv. Hold the power button and imput button together ( located on side panel ) for approx 45 sec......plug cord back into tv. Press power button on tv and voila !!!!! Tv came back on!!! I have had my Vizio almost 5 yrs. But have to call the unhelpful customer service atleast once a year.... I hope this works for you :)
May 03, 2007 | Vizio L32 32 in. LCD HDTV
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
