Question about Hotpoint FFM70 Bottom Freezer Refrigerator
Hotpoint FFM70A fridge freezer - noisy fan, hot compressor
Hi, Woke up this morning to a noisy fridge freezer. I pulled it out and the noise appears to be coming from approx half way up behind the stuck on panel (I assume this is a fan?). Also the compressor is very hot to touch and the radiator is relatively cool. Other recent problems which we have largely ignored include occasional gurgling and freezer high temp warning light. We are trying to weigh up the cost benefit of having it repaired or investing in a replacement - any help is appreciated!
  • 1462 Answers
SOURCE: FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Posted on Mar 31, 2007
  • 105 Answers
SOURCE: Hotpoint FFA60 - Freezer Fan not working
It sounds as if the fan motor itself has failed, & without the fan, only the coils will get cold. A replacement can be obtained from any appliance parts store, or from Hotpoint...check the website. If you are not experienced in appliance repair, I suggest you call a repair person , as some of the fans can be difficult to replace, & it is easy to cause additional damage.
Posted on Jul 18, 2007
SOURCE: hotpoint ultima fridge freezer
It's just simple.Keep the refrigerator open for few days with power on.After when the electricity bill comes,eveerything will be cooled.
Posted on May 28, 2008
  • 958 Answers
SOURCE: Hotpoint FFA70P Fridge freezer. High Freezer temp.
can you check the resistance of the fan?..or even the voltage going to the fan ( just be carefull ) if there is presence of voltage, then the problem is the fan, if there is none, you have to trace why. if it has a diagram, you an trace it. or the switch could have been open that is why it is not running. push the door switch if it has one and check again for presence of voltage. i hope i was able to help.
Posted on Jul 05, 2008
  • 25 Answers
SOURCE: Hotpoint FFA70 Freezer High Temp
sum fans only kick on if cold enough
if the whole evap is frosted up u have a defrost problem
if frost is only partial u need to throw it out cause it either has a bad compressor or freon leak
check your fan by compressor and make sure coil isnt filthy too
Posted on Jul 09, 2008
Where do I find the schematic for a Hotpoint FFM70A fridge-freezer?
There is a copy behind the grill at the bottom of the fridge
Apr 05, 2017 | Hotpoint Refrigerators
Diverter valve on Hotpoint FFA70 recieves no power, Fridge ok
Bonjour..Your system check (hot cold) is correct. Generally all new refrig/freezers cool only the freezer & bleed cold air off to cool the refrigerator. Most diverter/airflow dampers I have seen are mechanically operated for simplicity & to keep costs down. I would unload freezer and pull the panel off where you see the fan mounted. Go slow, don't drop any screws.You may not get them back. Look at the drain pan under the evap. coil. If it has ice that is built up in layers. Suspect the defrost termination thermostat. If the evap coil is clogged with heavy frost, suspect 1 the defrost timer and 2 the defrost heaters mounted on the evap. coil. Let me know how you make out.
Parts http://www.repairclinic.com/Refrigerator-Parts?s=t-Hotpoint+FFA70-%3d%3da4&z=50
Jul 02, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
I have a GE Hotpoint side by side Model HSM25GF7A Serial # VL224529 It is making a loud squealing noise whenever it is running. It also seems to not be cooling as cold as it usually does? I took the...
The noise i suspect is coming from one of the 2 fans...if you hear the noise coming from inside the freezer it will be that fan thats noisy and if from down by the compressor that will the fan thats noisy. the part numbers for the fans are
fan in the freezer (evaprator fan) WR60X10185
fan by the compressor (condenser fan) WR60X10220
They could be purchased from your local appliance parts store or online at,
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
GENE
Sep 07, 2011 | Hotpoint (HSM25IFTSA) Side by Side...
I woke up one morning and the fridge is not working but the freezer is working great. The fridge does not want to get any cooler than it used to be, it is not keeping our products cold. My fridge freezer...
the damper vent door between the freezer and fridge has stuck shut due to being frozen,you need to remove the freezer wall on the inside rear area to see if this door is shut and try to get it to move,also make sure the evaporator fan is running too so air gets moved from the freezer to the frideg
May 19, 2011 | Hotpoint RFA51 Bottom Freezer Refrigerator
I have a hotpoint fridge bottom freezer and after I had filled the freezer with my shopping yesterday, it started making a shreeking noise, I thought maybe it needed defrosting, which it did, so I...
If both section are not working as required then its compressor fault.The noise you noticed must be from compressor related parts,that are fan,the motor and relay.But If freezer is getting over cold and friezed and fridge section not getting cold then Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Jan 31, 2011 | Hotpoint FFA45 Bottom Freezer Refrigerator
Hi woke up this morning and the divider between the freezer and refridge compartments was very hot. Kitchenaid model ksbp25fkss. opened back panel, and compressor was also very hot. also seemed to be...
if it is making a lot of noise then your compressor is going out, if it is full of dirt dust or debree vacume it, or if you have a air compressor, then blow it out, but unplug your fridge to let the compressor cool down, if it is cold outside and you can wheel it there with no problem then you can clean it . you might have a freon leak or a stuck valve let it get cooled off and try again
Dec 12, 2010 | KitchenAid KSBP25FKSS Side by Side...
Woke to water all over floor. Condenser too hot to
is it clean? compressor out on over load. call for service.
Jun 20, 2009 | Freezers
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
ARB2214CB - Condensor is Noisy
It sounds as if the thermal limit on the compressor is cutting off power to the compressor when it gets too hot. There could be 3 reasons for this. One, the compressor is just bad...should be covered under the 5 year sealed sytem warranty (if its less than 5 years old of course) if this is the case. Two, the thermal overload and start relay assembly is bad. They are mounted directly to the compressor (big round black thing) and can be changed for about$14 in parts (unplug the unit before replacing!) Three, the fan that runs in the bottom near the compressor that cools the compressor and condenser is jammed or not rotating for some reason. It should run any time the the compressor is running. If it doesnt, it need replaced or the compressor will do exactly what you are describing. Hope this helps!
Oct 22, 2006 | Amana ARB1905C Bottom Freezer Refrigerator
Hotpoint FFM70 Bottom Freezer Refrigerator Logo
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
