Question about Dell E172FP 17" LCD Flat Panel Monitor
Dell model no E198FPf LCD Monitor has agreen light but wont turn on
  • Dell Master
  • 1,684 Answers
Your problem is caused by a failure of the filter capacitors in the power supply board, this is a common issue on LCD monitors. Here is a link to repair information for this model. You can repair the monitor by replacing the filter capacitors.
http://www.ccl-la.com/catalog/product_info.php?products_id=195
Posted on Feb 09, 2013
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: Hello, my Dell E173FP 17"
It has shorted out transistors in the inverter circuits, check them out first, also check the fuse in the inverters section.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Oct 11, 2010
  • 3 Answers
SOURCE: My Dell Monitor E198FPf didn't
I was given the same monitor by a friend which was displaying the same symptoms, upon disassembling the case and examining the power board (the larger of the 2 boards inside the case) it was apparent that the problem was 2 defective capacitors located on the upper right hand corner of the board (a capacitor is the barrel shaped components that have an X indentation in the top of them), when these components fail they swell and the X indentation will split allowing the internal pressure to be released safely. specifically it was theC862 cap which is a 25V 1000uF & the C869 cap which is a 25V 470uF. Both components cost less than $1.00 each and after replacement the monitor is working fine.
Posted on Sep 17, 2011
Monitor model 1702FP wont start. lights keep cycling
The flashing power and signal lights are caused by 4 bad capacitors on the main driver board. Here is a link to information showing where they are and how to replace them.
http://www.instructables.com/id/FREE-17%22-LCD-Monitor---How-to-do-it%3F/
Sep 23, 2012 | Dell 1702FP 17" 1280x1024 .264mm Midnight...
My hp monitor blinks agreen light but no light displayed on the screen please whats the solution
Either a issue in the power supply of the unit or something related to the display panel itself.
Says here a 30 inch?
Jun 16, 2012 | HP Commercial Specialty Performance ZR30w...
Mointor dell flat screen
flashing amber normally just means it has gone into standby because it's not getting a valid signal, when you bought the other monitor did you use a different vga/dvi cable when you plugged it in? are both inputs the same? for more information on the padlock please read this page http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Apr 29, 2012 | Computers & Internet
I have a Dell LCD monitor (model number: E198FPf) that will not turn on. The power button is flashing and the monitor has a faint flicker with no discernable image. I removed it from the computer that it...
i believe you may have answered your own question here because what you are stating is a malfunctioned monitor if you plugged other monitors to the cpu and they worked and the monitor in question is not working maybe it was a storm surge and since it did not have a surge protector then maybe the monitor is shot and you may need to replace the monitor...
hope this helps
Feb 21, 2011 | Computers & Internet
My Dell Monitor E198FPf didn't display anymore, the power button is keep on blinking. Is there anybody can tell me what's the reason and solution to my problem. Thanks.
Jan 13, 2011 | Dell E173FP 17" LCD Monitor
Dell Monitor wont turn on.
Your monitor has a self-test feature. Have you tried using it? The link below will give you directions on how to do this. It will also give you information on common problems.
http://support.dell.com/support/edocs/monitors/E176FP/En/index.htm
Jun 03, 2010 | Dell E176FP 17" LCD Monitor
Dell monitor e17s fbp.. wont turn on
Flashing power LED light means you may have shorted (Emitter to Collector) out transistors (c5707) or bad fuse (fuse has high resistance) PF751. Those are what you need to check. see pictures here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
http://s807.photobucket.com/albums/yy352/budm/Dell%20E15x%2017x%20series%20PWR%20INVERTER%20BD/
Post back what what you find so we can guide you further.
Feb 27, 2010 | Dell E173FP 17" LCD Monitor
Dell monitor power on and power light goes on and off
First place to look will be the power supply caps, look for caps with bulging top, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
http://www.lcdrepair.us/e176-177fpc-inverter-power.html
http://www.lcdrepair.us/e176FPf-inverter-power-logic.html
http://www.lcdrepair.us/e176-177fpm-inverter-power.html
Feb 16, 2010 | Dell E176FP 17" LCD Monitor
Dell flat panel monitor -power button blinks green to amber - no
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 10, 2009 | Dell Dimension 2400 PC Desktop
Dell E172FP 17" LCD Flat Panel Monitor Logo
219 people viewed this question
Alun Cox
