Question about Refrigerators
What water filter fits LG model GS73T65CEF fridge
5 Suggested Answers
  • 363 Answers
SOURCE: location of water filter on lg fridge freezer
OPEN DOORS LOOK IN UPPER RIGHT AND UPPER LEFT
Posted on Jul 22, 2009
  • 17 Answers
SOURCE: I have an LG Model GS73T65CEF side by side and
hello I had the same problem, you have to push the lock button then the sound stops, I do not know why but it works.
Posted on Feb 18, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Where is the water filter on an LG fridge model #
Your filter is in the upper left corner of the fresh food compartment.
(See manual link page 7 for picture)
Actual filter change out steps are on page 28 of the first link below.
Your 2.60 MB manual can be found here:
http://www.managemylife.com/mmh/owner_manuals/16317/LG-Bottom-Mount-Refrigerator-L0611001?brand_name_search=LFX21960ST+LG
Your filter original part number is 5231JA2006A but has been replaced by PN 9990 and is item 624A here:
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Refrigerator-Parts/Model-LFX21960ST/3204/0161000/50030277/00001?componentDescription=&brandDescription=&searchTerm=Filter#Partslist
Thanks for choosing FixYa,
Kelly
Posted on Oct 03, 2010
machinetech7
  • 1344 Answers
SOURCE: Frididaire fridge Model GLEC30S8EBA ,water not entering fridge , filter new. Is it the solenoid valve ?
Note: Always make sure your filter is current if you have one. Not doing so will cause water to not despence properly
Pull the machine out and remove the lower back cover. Locate the water valve. With the water turned on and connected remove the 5/16" water line (the bigger one) and then have someone else press the water in the door. If the cylinoid is operating correctly it should spray water out.If so, you just verified that the valve and electrical portions are working properly and either the filter is bad or the resevoir, , located inside the lower refrigerator side is frozen. If no water comes out but the valve vibrates, then the valve is bad. If no water and no vibration, continue reading.With the machine plugged in but the wires that go to the valve for the dispenser off take a volt meter and place a lead to each wire and have someone press the panel in the door as if getting water. The reading should go from 0 to around 115-120 a/c.If your not getting electricity down there at anytime than thje door switch is bad.
Testing the ice maker:
As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in.
Posted on May 23, 2012
Hi I have an LG fridge freezer model number GR L206CPQA and there is a horrible smell coming from the water from the dispenser, the filter has been changed and the ice seems to be fine but the fans on the...
Sorry but your model number doesn't register with me in the USA.
My experience tells me that the plastic water line from the filter to the water tank to the dispenser outlet is your problem. Replace those parts and you should be ok.
Hope this helps.
Nov 14, 2011 | LG Refrigerators
Hooking up water line to LG LRSC26920TT - water runs great through line, but once connected to fridge, no water runs through line in fridge - no water comes out when trying to fill a glass. No water...
dissconnect water line coupling behind lower kick plate under door. push water dispenser; and sell if water flows out line. keep a towel handy. it there is water; then, the problem is in the door itself. of course, make sure the water solenioids are working.
Apr 17, 2010 | LG LRSC26925 Side by Side Refrigerator
Hello!ad my black glass fridge freezer delivered today with ice n water dispenser and plummer cudnt work out instructions if the water filter canister goes on the inside or out! also where does the pipe...
Post your model number for filter help. The water supply hook to the water inlet valve on the back, Usually near the bottom. It has a fitting where the incoming water will fit. You may have to remove part of the cardboard on the back to get to it.
Oct 28, 2009 | Freezers
How do i change lg fridge water filter
have just changed the filter on our lg fridge, it's not easy: the filter is external, at the back of the fridge. the fridge has to be pulled away from the wall and then the filter can be seen.
Aug 14, 2008 | LG Refrigerators
Refrigerators Logo
207 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
