Question about Epson Office Equipment & Supplies
What is the fn key
Help says to press Fn + F4 button, what is the Fn button????
  • Epson Master
  • 3,287 Answers
I suspect this is a message you're seeing on a notebook, computer or other device that has a keyboard. The "Fn" key is the "Function" key. When the "Fn" key pressed at the same time another key is pressed - in this case the F4 key, a different result will occur when compared to pressing the F4 alone. This works the same way as when you use the SHIFT key and a letter key - instead of a lower case letter, you get an upper case letter.
Typically, the keys on the keyboard are labeled in a light color. Keys that have a second purpose or function, will have a second label printed in a different color / slight smaller text or both. This label may be text or an icon or graphic. In order to invoke the second function of the F4 key, you will need to inspect the keyboard for the key that has is labeled with "Fn" text on it. Here's what a typical "Fn" key looks like:
The Fn key is in the lower left corner of this keyboard.
I hope this answered your quiestion and good luck!
Posted on Jan 04, 2013
Benimur
  • 6966 Answers
SOURCE: my acer lap top will not recanize the projector when i press the fn plus thef8 keys
Hi, Try lowering your laptop's resolution (Display Properties) to 1024x768 (or even lower like 800x600), before fn + F8. You can also try lowering the Monitor's screen refresh rate (60Hx). Another setting you can check is Advanced Settings tab or button and check settings for projector (instead of TV). If it works in the lower settings, you can try moving the settings higher until it quits again. If the above does not fix your problem, you may need to re-install your graphics/video driver. Hope this gives you an idea. Post back should you need additional information. Good luck and kind regards.
Posted on Aug 24, 2007
  • 4 Answers
SOURCE: can't get projector to display
i have sold over 100 of these (useless)... projectors so i can tell you that you need to;
go to display properties in the laptop and make sure you can see 2 screens otherwise you wil get nothing out of the video output/vga depending which model you have. go to the projector menu and make sure auto is set for the source/input. if your laptop has VGA out set optoma to VGA. start the projector up again and then the laptop in that sequence. if you need any more help email me.
Posted on Dec 03, 2008
projdoc
  • 2236 Answers
SOURCE: I have connected laptop to infocus projector and
make sure you have the settings correct on the projector. select computer on the top panel. if still nothing, reset the settings to factory default (in the menu). also make sure you have matched resolution.
Posted on Nov 25, 2009
SOURCE: cannot seem to get simultaneaou screen with HP
TURN OFF THE COMPUTER AND AS IT START6S MAKE SURE THE PROJECTOR IS SET TO COMPUTER SIGNAL AND AUTO SEARCH. USUALLY TURNING ON THE COMPUTER WILL CREATE THE SCREENS IMAGE AND YOU ARE DONE.
Posted on Jan 19, 2010
heathgr
  • 442 Answers
SOURCE: message
Reduce the screen resolution to 600x480 for instance and see if the projector can handle the low res output OK. Then increase screen resolution on the PC unitl the error message appears. Try the video menu settings in the acer
Posted on Feb 26, 2011
Hi there I have a Toshiba CT - 9969 and want to connect my laptop using VGA? What must I do and where do I switch to VGA on the remote? Thank you
connect to TV using VGA port and select device or mode to PC in tv menu. or using remote
press laptop fn +F4
or see display change button in FN buttons .press with or without FN button . if you use HDMI pls cinnect with HDMI cable and in TV pls select HDMI mode in video mode
There is a row of Function keys at the top of the keyboard on every Toshiba notebook. These give you quick access to some useful functions. To activate them, just press the FN button on the keyboard together with the function key to activate the following commands.
press FN+F4
Nov 16, 2016 | Toshiba Computers & Internet
Tip
How to use F1, F2 ?..Function buttons on Hp laptop.
For those who do not know how to use the F1, F2, F3..... buttons on HP laptops, here is an opportunity for you to know.
We see these buttons on most laptops but don't know what they are used for. F1, F2....... buttons are the first set of buttons on the keyboard. These buttons makes it easy for anyone to access some programs on the computer without using mouse.
Follow the below procedures on how to use some of these functions:
To put your HP laptop on sleep mode, Press and hold Fn button on your keyboard, (without leaving it) then press F5 (Fn + F4).
To lock your HP laptop, Press and hold, Fn button, then press F6 (Fn + F6).
To reduce the brightness of your HP laptop, press and hold Fn button, then press F7 (Fn + F7).
To increase the brightness of your HP laptop, Press and hold Fn button, then press F8 (Fn + F8).
To put your laptop on mute, Press and hold Fn button, then press F9 (Fn + F8).
To reduce the volume of your HP laptop, Press and hold Fn button, then press F11 (Fn + F11).
To increase the volume of your HP laptop, Press and hold Fn button, then press F12 (Fn + F12).
To shut down your laptop or to view other shut down options, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
To close any page on your HP laptop, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
Good luck.
on Nov 06, 2010 | Computers & Internet
Tip
How to use F1, F2 ?..Function buttons on Acer laptop.
For those who do not know how to use the F1, F2, F3..... buttons on Acer laptops, here is an opportunity for you to know.
>To put your Acer laptop on stand-by or to view shut down options, Press and hold Fn button on your keyboard, (without leaving it) then press F4 (Fn + F4).
>To make your Acer laptop be on sleep mode, Press and hold, Fn button, then press F6 (Fn + F6).
>To lock your Acer laptop's Touchpad, press and hold Fn button, then press F7 (Fn + F7).
>To put your Acer laptop on mute Press and hold Fn button, then press F8 (Fn + F8).
>To close any page on your Acer laptop, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
Good luck.
on Oct 23, 2010 | Computers & Internet
Alt+f4 key not working for window 8 acer laptop
Mosly F1 to F12 keys are multifunction buttons, so they will work with help of "Fn" key.
Press and hold Fn then use Alt+F4.
Nov 15, 2014 | Acer Computers & Internet
How to increase brightness without fn+f6 keys because for now the f6 key is not working
Press and hold the "Fn," or function, key on your EEE PC-1000's keyboard.
Press "F3" while holding "Fn" to lower the brightness on your monitor.
The brightness on your computer decreases each time "F3" is pressed.
Press "F4" while holding "Fn" to increase the brightness on your monitor.
Each time "F4" is pressed, the brightness increases.
Press "F8" while holding "Fn" to decrease the volume from your EEE PC's speakers.
Each time "F8" is pressed, the volume decreases.
Press "F9" while holding "Fn" to increase the volume from your EEE PC's speakers.
Each time "F9" is pressed, the volume increases.
Press the "Ins" key while holding "Fn" to take a screen shot, or make a copy of what is currently on the computer screen.
hope this helps
Oct 08, 2012 | ASUS EeePC1000 1000H 1000HA 1000HC 1000HD...
Hp laptop no longer connects to external display via fn + f4
The Fn+F4 button toggles between the LCD and external monitor.
From LCD only or both LCD and external monitor or external monitor.
only. Press the Fn+F4 keys again to toggle the various screen selections.
Sep 16, 2012 | Computers & Internet
I dont know how to switch on wireless on my aspire 1640z
You have to press the front button whit the parabol symbol. Regards, MaTi_FleSh
Jul 03, 2011 | Acer Aspire 1640Z Notebook
I have a MSI laptop. My wireless internet disactivate on its own. I do not remember which key I have to press to activated it. Can you help me with this? I think I have to press my Function key with...
try
Fn+F1 -
Fn+F2 -
Fn+F3 -
Fn+F4 -
Fn+F5 -
Fn+F6 -
Fn+F7 -
Fn+F8 -
Fn+F9 -
Fn+F10 -
Fn+F11 -
Fn+F12 -
Fn+Esc -
or
Button symbolized antenna near power.
Thanks
Jan 04, 2011 | MSI M670 Notebook
VAIO VGN-Z520N/B 13.1" Laptop : where is the volume control on sony vaio laptop...
You can use the Fn+F3/F4 Function Keys to control the volume.
To increase the Volume, press Fn+F4 and then press Up or Right, or Keep pressig Fn+F4.
To decrease the volume, press Fn+F3 and then press Down or left, or Keep pressing Fn+F3.
Hope this helps..
May 13, 2010 | Sony VAIO VGN-Z520N/B Laptop
Which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
Oct 11, 2008 | HP Pavilion dv1000 Notebook
121 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
