Question about Refrigerators
Fridge not working properly
This is a used fridge which was supposed to be working fully OK but was mistakenly laid flat during transportation and would not run when switched on afterwards. However, it did start working again after being left standing fully upright for several days. Due to events it was left uninstalled and switched off for several months and, just prior to installing, have discovered it is now not working properly. If left in upright position it now doesn't run (doesn't cool and compressor not running). If stood leaning forward by about 30 degrees from vertical it starts running OK and cools OK but stops when placed fully upright again. A second query is how can I remove the thermostat knob and cover ? Although not likely to be the cause of above problem I thought to check it out anyway but there are no obvious screw fixings so cannot open and access and do not want to risk forcing and breaking anything. Your advice re both problems will be much appreciated.
  • 1 more comment
  • Bill Corner Jan 06, 2013
    Am unable to think of additional information to further explain problem except to clarify that I am asking if anyone can advise what could be the cause of this rather strange problem. i.e. what could be the reason that it will not run when stood upright but working when placed in a position sloping forward by about 30 to 45 degrees.
  • Bill Corner Jan 09, 2013
    Further information addition - stopped responding when tilted fowards by 30 to 45 degress but started up again when tilted backwards similiarly. Could a shortage of gas cause this strange behaviour ? Note that when failing to work, not cooling, the compressor does not run at all but does run when it decides to start working.
  • Bill Corner Jan 16, 2013
    No suggestions so far which rather disappointing. Have realised that I omitted the fridge data previously and maybe this might help - it is a Neff (integral) fridge model K5624XOGB/31
SOURCE: Freezer is staying cold (below 0), but Fridge won't cool
Failure to stay cold
Posted on Jul 23, 2008
  • 1462 Answers
SOURCE: Liebherr larder fridge not working in normal mode
thermostat is faulty - supercool just bypasses the stat
Posted on Sep 24, 2008
  • 159 Answers
SOURCE: Stops cooling, need to unplug, plug back in and it works for a little while
if the motor runs it cant be the thermostat then it is low gas inside the system and it must be cold after 30min
Posted on May 22, 2009
Sea Breeze
  • 4655 Answers
SOURCE: refrigerator not cooling
You model if the ARB1950C has a defrost timer inside the fresh food compartment and behind the temperature control panel. Need to see if you can manualy turn the timer clockwise until the compressor stops. During that time of 25 minutes the freezer should be in defrost. I believe your timer needs replaced based on how you explained what is happening. The part number for your timer is 67001036 and can be found at the links below. If it stays longer that 25 minutes then it's sticking in the defrost section of the defrost timer and will need to be replaced. If your refrigerator does not restart after about 25 minutes then slowly turn the timer through the opening in the plastic cover. There may be a plug covering the hole to make the hole not so visible. If you should have problems fell free to let me know, Thanks Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Posted on Aug 17, 2009
Macmarkus
  • 2605 Answers
SOURCE: I have amana bottem freezer,1 month ago i
Hello, Unfortunately the compressor likely is seized now. There are a couple of reasons that the original start device failed, 1) faulty connection. 2) poor quality part. 3) compressor was running non-stop due to other deficiencies in the unit or 4) the compressor was failing to begin with. The compressor may indeed check out ok as far as electrically ( windings ) but the mechanical component ( rotor ) has locked/seized up. You can determine whether it is the windings by checking the ohm value between common to start, common to run and run to start ( c-s, c-r, r-s ) and look for values similar to 6ohms, 3ohms, & 9ohms. Then check the start and run & common windings against the compressor casing to see if windings are shorted. In order to double check the mechanical component you'd need another hard start, ( or a test cord direct to 120vac, but that should only be done by an experienced tech ). nothing else will start it at this point obviously or you wouldn't be using a hard start already. The other unfortunate issue is this, many of these compressor's have a 10yr. parts only warranty but that was voided as soon as the 3in1 hard start was installed. In the end I'm likely not telling you anything you didn't already suspect or know in fact, but it is likely the compressor. I sympathsize, seized compressors **** ! Hope this answers your question and moves you forward. good luck macmarkus :)
Posted on May 08, 2010
KitchenAid KBRA22KL Moved houses and now fridge and freezer will not cool. Lights work. Here fridge has power but not kicking in the condenser. Is there a reset somewhere or is it fried. Pls help!
you must have laid the refrigerator down during transport. compressor oil is now blocking the capillary tube. just keep trying by plugging in for a few minutes every couple hours until the oil finally clears the capillary tube
APPLIANCE 911
Jul 24, 2016 | KitchenAid Refrigerators
The top section, fridge, is freezing up, we only had it 3 days
Read somewhere that refrigerators are not supposed to be transported on their sides - that they are supposed to be moved in an upright position and that if you have transported it like that you are supposed to let it stand upright for about 8 hours before using it.
Mar 17, 2015 | Electra GENUINE Refrigerator Fridge...
Fridge Freezer been laid on its back now freezer struggling to freeze
Although there is a lot of confusion out there on this subject, most manufacturer advice is to allow a fridge to stand for at least 24 hrs after being laid down. So unplug the unit and allow it to do that.
One manufacturer advises that a fridge treated in this way may then take up to 72 hrs running before it can recover fully.
Sep 19, 2013 | Refrigerators
Can this fridge be laid down for transporting without damaging it? If it can does it have to be placed on a certain side?
You can lay a fridge down if you do it right...this tip will tell you how to do it so that it will work again when you get it moved and set it back up.
Moving a Refrigerator What is the best way
heatman101
Jan 25, 2011 | Refrigerators
Model N325T. No cold air in fridge or freezer.
Hopefully you read my tip frist and transported it the right way, but since your having trouble probably not.... If you laid it down on its side you have oil in the system where it cannot get out and is plugging the pipes so the compressor cannot run...
Try to let it off ofr about 12 hours before trying to plug it in again...then if it runs... only let it run a few minutes and then unplug it for an hour or two...do this a couple of times and then it will be okay..
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
http://www.fixya.com/support/r4020581-moving_refrigerator_best_way
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4326839-refrigerator_maintenance_tips
heatman101
Apr 18, 2010 | Refrigerators
What causes my fridge to run hot? It thinks its an oven! It was working fine prior to transportation, after which it was left for three hour prior to switching on when it ran hot.
I believe it may have been laid down during transport. Leave it unplugged for another 24 hours and allow the compressor oil to return back down to the compressor. This is a very common problem if laid down on side during transport. After this time replug the power cord and listen and feel to insure warm air blows from bottom of refrigerator and cold air in freezer. The oil is to thick and heavy to be pushed through the capillary tube. Just be patient and not try to push the time getting it to cool again as the compressor will continue to overheat if oil remains in the cap tube. Thanks Sea Breeze
Mar 12, 2010 | Maytag MSD2454G Side by Side Refrigerator
Frigidaire side by side making a vibrating/humming sort of sound
When a fridge is first installed it is important it is adjusted to stand level and firm. If it was transported upright and hadn't been laid down it could then be switched on but if it had been laid down during transit or during installation it should be left to stand before switching on - some authorities say four hours and others say longer.
Failure to do either of these things can cause accelerated wear of the compressor and that could be the reason for the humming noise and vibration.
A friend has the same problem with his fridge and he freely admits it was never properly levelled. It began vibrating years ago for a short time when it starts but apart from that it continues to work quite well.
Just to be on the safe side of fairly sure, it would be a good idea to check the security of the compressor and fixings...
Apr 18, 2017 | Frigidaire FRS26H5AS Side by Side...
New refrig deliverd today told not to turn on for 2 hrs to let gas settle as it reduces the lifespan. true or false.?
False . If it was delivered laying on its' side , back , or front , 24 hrs is necessary . If delivered standing up , no need to wait .
Nov 13, 2009 | Belling BE808 Compact Refrigerator
Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Oct 03, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
