Question about Inverter Yaskawa F7 Drive
Yaskawa F7 vvvf drive's user manual
I have no full user manual to operate elevator smoothly.so there is little problem like, lift is not smooth in slowing speed and also in stopping. How to set parameter perfectly and also operate lift smoothly. Thank you
4 Suggested Answers
protek480
  • 1723 Answers
SOURCE: i have a fault code on a yaskawa varispeed f7 drive
Go to this link for manual.
http://www.e-mechatronics.com/en/product/inverter/f7/catalog.html
Posted on Jun 26, 2009
SOURCE: can you sand me yaskawa F7 VFD manual
f7a43pa instalation manual
Posted on Apr 07, 2011
SOURCE: I NEED YASKAWA MANUAL IN PDF MODEL NO: CIMR F7
http://www.yaskawa.com/site/DMDrive.nsf/536df907f9fe9d5586256c4e0056b851/86256ec30069e43286256cd700570246/$FILE/TM.F7.01.pdf
Best regards
Posted on Jul 13, 2011
Machine slows down and sometimes stops while sewing a seam then speed control becomes erratic
check for thread build up jamming the shafts
may be a service will be the answer
May 22, 2015 | Sewing Machines
Why doe;s my 97 Ford expedition stall only when turning into a parking place or my drive way?
there is a sensor that will increase engine revs when turning at slow speed , i expect this is the issue, to check get the OBD codes read to confirm
Oct 23, 2014 | Ford Expedition Cars & Trucks
My treadmill runs for 9 secons and stops and shows E1
Ok. So the first thing to try is to calibrate the speed.
You do this by doing the following:
  • With the SAFETY KEY in place, hold the ELEVATION UP and SPEED DOWN buttons for five seconds. The console will beep twice, "ENG0" will appear in the Distance window, and a number will appear in the Elevation window.
  • Press SELECT until "ENG3" appears; this is for Auto-Calibration.
  • Press START to Auto-Calibrate.
  • The treadmill will calibrate minimum and maximum speed, and minimum and maximum elevation. When Auto-Calibration is complete, the treadmill will reset to User's start screen. This process takes three to five minutes.
Make sure there are no errors. . .and that the speed goes from super slow to super fast and then stops. . .. if it stays slow. . or stays fast. .or error code appears during calibration, there is a problem.
If after a good calibration sequence, if it still does the stopping and E-1 after 10 seconds. ., then you need to (Power off and disconnect treadmill). . .then unplug the speed sensor from the lower power board, blow into the connector on the wire, and add a little contact cleaner spray to the connector on the board.
Recap: If it actually runs. . .but stops after a few seconds. . but the calibration runs and passes fine. .. .more than likely it is a speed sensor misread or a faulty speed sensor.
Sep 30, 2014 | Triumph 400T Treadmill
Setting the rpm
To identify the idle screw adjustment push in and and out with the gas throttle handle and look at the carburetor for a little finger that moves in unison with your movements. That finger comes to rest against a tapered screw - the latter is the idle adjustment. Clockwise increases the speed and vice versa. Adjust so unit runs smoothly at low speed - too slow and it will stall. Experiment.
Nov 22, 2013 | Craftsman 25cc Gas Line Trimmer
When i drag an application around it skips or roll around the screen slow, its not like that smooth drag.
The "smoothness" depends on the speed of your CPU (Central Processor Unit), the speed and memory-capacity of your video-card, and what other "background" processes are competing for CPU cycles.
If you have a desktop computer, install a better/faster video-card.
Jul 19, 2010 | Microsoft Windows XP Professional
My Tunturi Treadmill ramp is stuck in the top elevation position and will not run. I get a "Auto Syncing" message, but the machine will not run. Have tried unplugging etc, but it will not exit the mode...
Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
LED scanning mode for verifying display functionality Press ‘ENTER’ to scan DATA LINES to verify display functionality Press ‘ENTER’ to scan SACN LINES to verify display functionality Press ‘ENTER’ to scan LED’s to verify display functionality After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
The lift motor calibration is done manually by following the following steps: 1. Drive the lift motor to 0% from user interface (inclination display must be 0%) 2. Switch off the treadmill and unplug the power cable 3. Remove motor cover 4. Fold up the running deck 5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame 6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the lift motor frame Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
Jun 11, 2010 | Tunturi T30 Programmable Treadmill
I seem to be going through a lot of gas in a short period of time. I have 3 adjustment screws on my Homelite XL 10515A chainsaw. which one controls the fuel flow and which one the idle speed
Two of the screws are fuel related: H = high speed and L = slow speed. The third is idle speed and is a limit stop for the throttle lever. Turn both mixture screws in CW to stop (lightly), and back out CCW 1-1/2 turns each. Start with H needle after engine warm-up. Open the throttle full and adjust CW until you reach highest speed with 4-stroking, but smooths out when cutting lightly. Allow to idle, and adjust L needle CW for smooth idle, but rich enough to allow engine to follow the throttle. Adjust idle speed screw to allow the chain to stop turning. Make sure to clean the air cleaner before this procedure.
Aug 16, 2009 | Garden
Proper way to dive 2000 mazda mpv
I don't have this problem,  but to slow the jackrabbit start of this machine   place the gear selector in [2] position and you will be rewarded with a very smoth if slow start off the line.  Excellent  for  very slipper conditions.   Don't forget to upshift after you are up to speed.
Apr 17, 2009 | 2000 Mazda MPV
Inverter Yaskawa F7 Drive Logo
48 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
George Scott
George Scott
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
