Question about Frigidaire Air Purifiers
Freezer too cold, fresh food section too warm
I have my Fridge set to -18C / 4C and this morning when I woke up, it was actually at -25C / 13C. However, the set points never changed. I took the air filter housing off to inspect the damper door to see if it was blocked and I noticed frost on the air filter housing vents. I also noticed that the damper was wide-open. I decided to put everything back together and see if the problem corrects itself, and, it did. The fridge is now at -18C / 4C and working properly. Do you think the Fridge was just defrosting itself? Or, is there an issue. (FYI, it is 2 yrs old and has worked perfectly up until now). Thanks the help.
SOURCE: red light wont change back to green after cleaning
I did the same thing and now I need to replace the cell collector. You need to replace it to if the wire is broken. Please let me know the outcome of your problem.
Where to find the part is hard to get.
animallover2
Posted on Nov 09, 2008
SOURCE: Front display controls don't work
Sounds like the same problem I had with mine. I had to call and get an RMA number and they replaced the key pad, lcd display, and main board. This repair was covered under warranty. (Under 3 years old) They had it repaired and returned in about a week.
Posted on Sep 10, 2009
  • 19 Answers
SOURCE: foul air smell
it needs new plate (s)
Posted on Apr 03, 2010
ginko
  • 19396 Answers
SOURCE: I have a Fresh Air
Hi.
The RCI Cell must probably be replaced, this must be done about every three years.
The part costs about $90, parts available here.
Replacement is explain at page 15 in manual available here.
There is also a debate on health concerns related to ionized air purifiers. Here Ecoquest answer, stating the product is safe.
On the other hand:
The Dangers of Ionic Air Purifiers
Ionic Air Cleaners
Please read also this article.
Before replacing any part I suggest to read the articles. Ozone related concerns have caused the recall of other similar devices.
Regards.
Ginko.
Posted on Sep 23, 2010
  • 670 Answers
SOURCE: We replaced the ozone plate
Check the plate contacts and wiring. Make sure that the contacts are clean and make a good contact with the wiring. You can clean the contacts with a old toothbrush with some amonia and water solution. Make sure that the contacts themselves make contact with the metal grid on the purification plate. Hope this helps.
Posted on Oct 07, 2010
This morning, my Frigidaire FFHS2322MS refrigerator had a pond of water in front, the compressor was clearly off and the lights inside were on. No error code of the displays, they were just bla
Have a technician test the start capacitor on the compressor. When they go bad the motor will draw excessive current which trips the thermal overload switch on the compressor. It usually resets itself once the compressor case has cooled down.
Nov 15, 2015 | Frigidaire FFHS2322MS 22.6 cu. ft. Side by...
I have a frigidaire pro FPHS2386L and the freezer is too cold. Any ideas?
George makes a good point but I'd like to add that there is generally a fan that blows the air between the freezer into the fridge area. If there is no obstruction, the fan most likely needs to be replaced. On a few models this can be done with a little patience and a screw driver and the fan part. Check with a Sears Parts distribution store avaiable around the country for the part if the model is carried by Sears. If not, Google the fridge make and model number with Freezer Fan Replacement.
Nov 23, 2014 | Frigidaire FPHS2386L Stainless Steel...
Little 'fridge no power.
Where is the cold control set at? They have an off position.
Jan 18, 2012 | Air Purifiers
I need to send my Ecoquest Fresh Air Air Purifier to a repair shop. I need to find one near Mobile, AL. Can anybody help?
I would google one, Vollarra uses independent repair shops all over. You could call them too. Tennessee doesn't do much actual "repair" nowadays.
Jun 27, 2011 | Ecoquest Fresh Air Air Purifier
Do I soak the rci target plate in ammonia with the purification plate?
No, just rinse the RCI target with warm water. Allow it as well as the purification plate to dry completely before reinstalling into the purifier. You can speed up the drying process using a hair dryer at a low heat setting. Hope this helps you.
Feb 11, 2011 | Ecoquest Fresh Air Air Purifier
HELLO AND GOOD MORNING I HAVE A FLAIR AIR
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Mar 18, 2010 | Ecoquest Flair Air Purifier
The fridge fan is whining
The bearings in the fan motor are probably going bad. A new motor will solve the problem.
Nov 08, 2009 | Air Purifiers
Water drips down from Freezer. The water is coming
Since you said the water supply is shut off, the likely culprit is a clogged drain tube that connects the defrost tray to the water collection pan for evaporation at the bottom of the fridge.
The source of the clog is usually either mold growth or more likely, ice build up. Regardless of which, if you access the defrost heater in the freezer section, you can thaw ice that has collected in the tray and if needed, use a turkey baster to direct a hot stream of water at the point the hose attaches to the tray and treat the hose for mold, below.
Once cleared of ice, mix a small amount (5 or 6 oz) of water and 1/2 to 1 ounce of bleach and direct down the tube to kill any mold / growth. Be careful not to use to much or overflow, as clean up will be difficult due to the bleach mixture.
The next thing to do (if icing up) is to determine why. A careful check of the defrost circuit should be done. Otherwise, you'll be doing this over - and it may start to affect the temperatures in the frozen and fresh food sections of the fridge.
I hope this helps!
Nov 05, 2009 | Air Purifiers
Fresh air 2.0: Unit cycles on and off.
The problem is dust or moisture on one or more of the circuit boards, in the bottom of the unit. The problem is usually caused by resetting the cleaning reminder without actually cleaning the machine. ;-) It hasn't been difficult for me to solve so far. Remove the filter. Remove the two screws that hold on the plate where the rear switch is located. The wires are long enough that they don't need to be removed from the switch. Use a blow dryer or dry compressed air to blow off the circuit boards. ****Keep your face out of the way!!! Be sure not to get the blow dryer too close or too hot. If you have a Warm setting, use that. Good luck!
Sep 30, 2008 | Ecoquest Fresh Air Air Purifier
Air Purifiers Logo
87 people viewed this question
Top Frigidaire Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Frigidaire Air Purifier Expert? Answer questions, earn points and help others
