Panasonic tv ct-27g23w vertical problems - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,571 Answers
What is the problem you faces with this TV. Provide more details please.
Posted on Jan 04, 2013
4 Suggested Answers
  • 65 Answers
SOURCE: Panasonic CT-32hX41 vertical picture problem (hourglass)
this product has a pincushion problem and requires servicing but unfortunatley it is what we call in the business NECO
Posted on Dec 09, 2006
  • 236 Answers
SOURCE: Buzzing sound, no picture on my Panasonic TV
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit. The buzzing sound that you're hearing is the power supply overloaded. Stargazer
Posted on Apr 23, 2007
  • 17 Answers
SOURCE: Dead TV Panasonic CT 36HL42CF
have a visitation and bury the next day.
Posted on Jul 15, 2009
Panasonic CT-36G34 TV vertical deflection circuit
there is a single ic you need to find, usually location ic301 or 401---it will have between 7 and 13 pins in a single straight row---a generic number is printed on the front---usually begins with a LA but can be different
Locate the chip and gain access to the bottom of the board, the pins on the chip break loose from heat==SOLDER ALL THE PINS BACK AND YOU SHOULD BE GOOD TO GO---its a very common problem in these sets.
12_19_2012_7_41_26_pm.jpgsomething like this with more pins possible--will be attached to metal of some sort to keep it cool.
Dec 19, 2012 | Panasonic CT-36G34 36" TV
Horizontal lines across TV screen Pansonic CT 35g25
Check its vertical output section circuit for any component damage or loose soldering terminals. Check the solder terminals of the vertical output IC. Resolder all the suspected solder terminals by applying al little more fresh solder, without making any solder bridge short in between adjacent solder terminals.
If this do not help you, replace the vertical output IC. Lose of Vertical Scan is the problem of your TV.
Aug 04, 2012 | Panasonic CT-35G25 TV
Our tv, a Panasonic # CT-36D11E/CT-36D11 only shows a horizontal thin line across the screen. The sound is fine - any ideas? Is it time to replace or could it be repaired cheaply?
Resolder the vertical IC and replace those capacitors near and next to your vertical IC. If the horizontal line still appears, you may have to replace the IC. Thanks for asking and be caredful!
Jun 18, 2010 | Panasonic CT-36D11 36" TV
Panasonic CT-27SL15 has scan lines on top 4 inches of screen, what is problem and how to fix?
Nov 2011 - Comment
Have similar problem on a Panasonic Tau model CT-27SL15.
It's a 27" CRT TV manufactured around 2005.
Other posts / solutions on this problem say possibly a capacitor going bad in the vertical circuitry / near the vertical IC / vertical blanking circuitry. Telephone call to a TV repair person mentioned something similar - "possibly a bad capacitor in the vertical circuitry".
Found a service manual online w/schematics and board layouts.
Panasonic Service Manual
http://dl.dropbox.com/u/35219914/PANASONIC%20CT27SL15.pdf
See pg 25 (of 42) - Deflection Schematic Diagram (Main PCB)
Shows: V Output IC - IC401
Finding the actual bad component(s) may not be so easy.
Anyway ... just wanted to add this comment.
Feb 11, 2010 | Panasonic CT-27SL15 27" TV
Tv vertical
It sonds like bad solder connections on the vertical IC.IF you remove the back flip up the p.c.board and inspect it you should be able to locate the problem resolder it and save repair cost.Becareful of wires and plugs if you have to mark them.
Apr 01, 2009 | Panasonic CT-36G24 36" TV
Picture shrinks horizontally every few seconds.
You are changing parts in the wrong circuit. The problem is in the vertical circuit. Look for the vertical IC and resolder the pins first. It should be an LA7837 or something similar. Also, check the 100ufd and 47ufd caps in the same circuit.
Keep us posted.
Dan
Jan 19, 2009 | Panasonic CT-20G11 TV
PANASONIC CT-27D30B
Maybe the vertical IC output are damaged you need to replace him
Sep 19, 2008 | Panasonic CT-27G14 27" TV
Apr 22, 2007 | Panasonic CT-27G23 27" TV
Dec 05, 2006 | Panasonic CT-27HL14 27" TV
Televison & Video Logo
Top Televison & Video Experts
