Question about Brother MFC-8370DN Laser Multifunction Printer 40567
We bought laserprinter brother mfc-8370dn from germany but we can't change the language.
Normally we must choose land and language in the beginnig but we dont received message on the screen for land and language.
SOURCE: How to change Brother MFC 5890CN Language
Please follow the instructions below to change the language to English.
1. Turn off the machine
2. Hold in the MENU button.
3. Turn on the machine while holding the menu button
4. Maintenance should come up onscreen and the lights should flash.
5. Key in the numbers 74 and press Mono Start button.
6. Key in 0004 and press Mono Start button.
7. "MAINTENANCE" appears again on the display.
8. Key in 99 at the maintenance prompt to exit to the date and time
It should be now in English.
Posted on Jul 06, 2010
SOURCE: Change Language on Brother MFC-215C
PLEASE, can anyone be sure of the eeprom code for GB before I start the procedure, I tried to contact the hotline but I'm not sure of their phone number either.
Thanks for ur help
Posted on Jun 02, 2008
jonags3
  • 83 Answers
SOURCE: change LCD language to English on Brother MFC-3240C
Gud Day!
Power on your printer. Press the menu of your printer then sect the arrow down or up to select the language menu. press ok if u have seen language then go to option select from german to english.
Please rate the solution after you have tried it so that I can assess you more on this problem.
Jonags
Posted on Dec 11, 2008
benwabnick
  • 2404 Answers
SOURCE: how can I change the language?
Go to the Brothers website and download the latest software for your machine. In the process it will ask you what language you prefer, choose English and then your menus from that point on should be in English.
Posted on Feb 08, 2009
SOURCE: brother mfc- 665cw, receiving faxes
From the Brother web site.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
Posted on Apr 28, 2010
NO NETWORK SETTING SHOW IN LCD PANEL IN BROTHER 8370DN AFTER RESET THE PF KIT 1 MESSAGE.
Hi gurjit: try this..
Reconnect the LAN cable to the hub to verify
that the cable and network connections are good. If possible, try connecting the
machine to a different port on your hub using a different cable. If the connections
are good, the lower LED of the back panel of the machine will be green.
sends me the result.
Nov 26, 2014 | Brother MFC-8370DN Laser Multifunction...
How To Change Language From Germany To English
Enter maintenance mode - Press menu & *2864 in this manner
Wait for the machine to display "IIIIIIMAINTENANCEIIIIII " on the LCD. Press 74, follow by 0003 (Germany), press MONO START, wait for IIIIIImaintenanceIIIIII on display. Press 99 to exit.
Oct 14, 2014 | Brother MFC-J5910DW Color Inkjet...
Change language in LCD display. germany to english in printer brother MFC 4510DW
Unfortunately none of the provided solution works, the last firm updated printer does not appear in settings no possibility of language change
Oct 30, 2013 | Brother MFC Office Equipment & Supplies
Select language
go to initial set up and choose local language, then check the English lalanguage. if no English then you have to update the firmware.
Apr 19, 2013 | Brother Office Equipment & Supplies
How to change language
Press; menu- 203 or, menu- 201 to go in the setup and use arrow up/down key to scroll to language settings.
Jan 06, 2013 | Brother MFC-8370DN Laser Multifunction...
Mfc-j5910DW can I change the language to english.? How do I do it?
there does not seem to be anything about language in the settings
what words might be useful ..in german ?
Dec 31, 2012 | Brother MFC-210C All-In-One Printer
I have purchased a MFC 6490CW printer in Germany. can I change the language in LCD screen from german to english on MFC - 6490CW?
Yes under settings there will be a language option, just have to go through the process in the German Language
May 22, 2011 | Brother MFC 6490CW InkJet Printer
How can I change the language?
if you go to the brother web site update your drivers and select the language you want in the process
Feb 08, 2009 | Brother MFC 9050 All-In-One Laser Printer
Changing the language on LCD
According to the manual the command is 0 then 0. You can choose your language there.
Here is the page for your printer. Click here.
NOTE::: These instructions are for the printer made in NA, not Overseas.\
Dec 02, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC-8370DN Laser Multifunction Printer 40567 Logo
96 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
