Question about GE 15" Laundry Pedestal for Horizontal Axis Washers and Dryers - White-on-White
No water Im not getting any water into my dishwasher?
    Scholar:
  • 55 Answers
Water supply hooked up?could be water valve.
Posted on Aug 17, 2009
Dishwasher will not drain
have you checked to see if the piston valve is not worn out this allows the water to get drained. they are situated in the back of most dishwasher do you have a manuel to check where this part is located in your washer as im replacing mine and that is why mine did not drian
Feb 23, 2013 | Maytag MDB6769AWS Stainless Steel Builtin...
There is water on the bottom,is there a way to drain it? im not sure why there is water there,its never happened
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 19, 2011 | Hotpoint Dishwashers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Aug 31, 2010 | Maytag 24 in. MDB4000 Built-in Dishwasher
No water enters the dishwasher when its turned on
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 23, 2010 | Bosch SHV46C03 Built-in Dishwasher
I have a question..... i wanna install my nes dishwasher, but im not sure i sould put the hot water or cold water
I always just use cold...why heat up water twice? IF it will work either way... then, cold.
Feb 21, 2010 | Samsung 24 in. DB3710D Dishwasher
My whisper quiet dishwasher is not cleaning the top rack dishes
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Sep 07, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Not emptying or filling
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Nov 19, 2008 | Smeg Dishwashers
Dishwasher
Im shocked this washer lasted this long.Check for voltage at the water valve ,should have about 120V.
May 24, 2008 | Indesit 24 in. D63 Free-standing...
Dishwasher temp.
you probably have guessed right all you have to do is test the voltage to match the original specs.
Nov 20, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
GE 15" Laundry Pedestal for  Horizontal Axis Washers and Dryers - White-on-White Logo
71 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
