Question about Kodak EasyShare DX6490 Digital Camera
Help! I've dropped my Kodak dx6490. All modes on the mode dial flash. None of the modes work and camera won't turn off unless I take out the battery. BGS
    Problem Solver:
  • 4 Answers
Sounds like you will need to send it in for service. Get an estimate as it might be a better spend of your money to just buy a newer camera.
Posted on Jan 19, 2009
I dropped my camera and it won't turn on unless plugged in
Sadly there is nothing FIXYA can do for you here . we all have had accidents that turn out costly
Oct 10, 2017 | Kodak Cameras
When I turn the camera on, the indicator next to the mode dial flashes and nothing else works, the lens does not pop out and I cant access any menu data or any other function, The only way to stop the...
I suspect your SD/SDHC card could be faulty. If you can checkdisk it in a PDA, and then put it back, the camera should start. If not, you've at least ruled out the card as a cause.
Aug 31, 2011 | Kodak EasyShare Z980 Digital Camera
My Kodak Easy Share DX6490 will not turn on. When I place it on the charging dock, the lights flash like it is transferring photos to my computer and the flashing won't stop even if I remove the camera...
Hello, sounds like you have a faulty battery,if the battery is several years old it will lose the capacity to boot the camera and the dock is trying to charge a defective battery,if you get a new battery, charge it for at least 6 hours or more.Hope this solves your problem.
Regards,Russell
Aug 16, 2010 | Kodak EasyShare DX6490 Digital Camera
I have a Kodak Easy Share DX6490. The function
if you use electrical switch cleaner it wont hurt the camera and it has a lube in it as well much like an oil but its not oil its an electrical oil,,,this will work on any switch or fuse box or volume control that crackles when moved its handy stuff to have around
Nov 16, 2009 | Kodak EasyShare DX6490 Digital Camera
Dropped my kodak dx 6490. Lights flash and lens won't retract.
Drop it agin, in the trash can. It is not worth getting repaired, you would be better off getting a new camera...
Jun 15, 2009 | Kodak EasyShare DX6490 Digital Camera
Mode dial on my Kodak DX6490 camera is hard to turn!
dissmantle the back case (watch for 1 hidden screw under rubber covers), lift plate on back of lcd screen, remove screw on back of dial, clean where it sits on both sides (most probably from a liquid spill...tea, coffee...) , apply some lube with a cottonbud ore a bit of tisue and rebuild.
hope this helps
stewart
Apr 04, 2009 | Kodak EasyShare DX6490 Digital Camera
MY KODAK CAMERA WON'T FLASH WHEN IT IS SET ON THAT!
As a first step, make sure the batteries are fully charged and check in the Shooting menu if you have switched the flash to 'off' mode. Then check the shooting mode. In some shooting modes (like landscape), some cameras do not fire the flash. To check if the flash is working properly, change the mode to 'Night Portrait' and try to shoot. This mode is sure to fire the flash if everything is well with the camera. If still the flash is not working, take it to the nearest authorized service center.
Jan 28, 2009 | Kodak EasyShare One Digital Camera
DX6490 won't work on battery only
I presume the camera is out of warranty?
There are many possible problems..
would the old battery charge on the fast charger at all or did it do strange things (dont do it now to try), If the battery was shorted, and you tried to charge it on the dock it may have damaged the cameras internal power supply, which is quite a complicated device, there are fuses but they are absolutely tiny and you need special equipment to fit them properly.
Also the flash capacitor lives on the power board which can keep its charge for quite some time at up to 300v at a substantial current and will make you drop the camera (at least) if it bites you.. :) so from the safety angle if you don't have at least some electronic training I cant recommend opening the camera..
The only possible suggestion that is a relitively easy fix is that the battery contacts may be bent or dirty.
Beyond that as I currently don't have my test dx6490 (used for checking voltages with units in for repair etc..) .. the next try is the dc socket, it may be damaged, or contaminated. try inserting and removing quite a few times and maybe using a VERY small amount of electrical switch cleaner.
Unfortunately to get to the socket if it is broken requires the whole camera be striped down as its just about the first board you fit when re assembling.
If you are adventurous, probably the easiest route to getting a camera back up would be to buy a faulty one from ebay. One with a broken screen or mode switch would be the easiest fix as you only need to remove the back and disconect and reconnect three ribbon cables.
Next would be a lens swap for one with a broken lens but requires quite a significant amount more work.
although the most difficult bit in both procedures is getting the diopter knob (eyepiece focus) on and off which in most cases means a small amount of damage will be done to the eye piece but nothing really bad, just cosmetic (kodak would replace the bit)...
If i can be any more help drop me a line....
best of luck
Jun 01, 2008 | Kodak EasyShare DX6490 Digital Camera
Want to buy a dx6490 outer lens
if you cant swap one yourself from a dead camera it would be beyond economical repair.
If you are adventurous you could buy a faulty one of ebay and swap the lens or if the faulty one has a broken screen or mode dial swap yours over to the faulty one..
there are a couple of "tricks" do getting this camera open drop me a line if you decide to proceed...
best of luck
Apr 10, 2008 | Kodak EasyShare DX6490 Digital Camera
Flash won't work - possible bulb failure?
Check Kodak for repair quotes likely hood not economical though
Aug 07, 2007 | Kodak EasyShare DX6490 Digital Camera
Kodak EasyShare DX6490 Digital Camera Logo
89 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
