Question about Sewing Machines
Cannot wind bobbin as pushing switch to left does not make the bobbin winder rotate
The bobbin does not turn when foot pedal is pressed even if switch is pushed to left.cannot wind a bobbin.
  • Sewing Machines Master
  • 7,365 Answers
You might check with the place you bought the machine from and
ask them why your having a problem with the bobbin winder spindle
also ask if this is a common problem with the machine, you might
want to return the machine and get a different one or even a different
brand sewing machine
Posted on Jan 04, 2013
SOURCE: Singer CE200 bobbin winder
I fixed it by going to the free web site. Thank you so much
Joe Varnum
Posted on Aug 15, 2008
textile
  • 10 Answers
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Posted on Aug 19, 2008
RickE1
  • 202 Answers
SOURCE: Bobbin winder will not turn..
Without knowing what type of machine you have its hard to determine if the problem is mechanical or electronic. If the bobbinwinder has its own motor than its probably electronic and it could be a bad motor or circuitboard. Sounds like this could be it.
The minimum service charge could be about 50.00 but this won't include the more expensive part. You might look up Sidewinder bobbinwinders which is a small separate unit you can purchase in most fabric stores or online for about 20.00 and just wind bobbins separate from the machine.
Good luck.
Posted on Dec 20, 2008
bargainbox
  • 1388 Answers
SOURCE: bobbin spindle won't spin
Check the bobbin winder rubber, it may be worn or broken and insufficient friction against handwheel to turn.........or a thread jam around spindle is stopping the spin. In this case, carefully unwind, DO NOT cut thread.
Posted on Sep 01, 2009
  • 4 Answers
SOURCE: Tiny Tailor bobbin won't wind
I don't know the solution but you can find the manual here:
http://www.singerco.com/accessories/manuals.html
Do search for TT600 when given the model number (do NOT use TT600X since it wll say not found). It's a very nice manual that is in PDF format.
Posted on May 31, 2010
How to wind bobbin
1. LOOSEN THE HAND WHEEL. 2, PLACE BOBBIN ON BOBBIN WINDER AND PUSH TOWARDS INNER WHEEL TO LOCK. 3. RUN THREAD FROM THREAD HOLDER TO LITTLE METAL WHEEL ON LEFT OF MACHINE. 4.RUN THE THREAD AROUND THIS WHEEL AND TO THE BOBBIN. 5. ATTACH THE THREAD TO THE BOBBIN. 6. PUSH THE FOOT PEDAL.
7. WIND THE BOBBIN EVENLY AND STOP AT TWO THIRDS.
Nov 16, 2014 | Sewing Machines
Needle is not moving
Of course I have to guess here--not seeing the machine, but it appears that your motor is working fine. That would leave two possibilities, I think. The first is a defective foot pedal. The second is, when you push the bobbin winder, it engages a clutch that diverts power from the needle shaft to the winder. It is possible that the clutch is stuck. To find out, disengage the bobbin winder and press the foot pedal, and see if the bobbin winder spindle is still spinning.
Jan 02, 2014 | Singer Inspiration 4206
Machine will not go forward when pressing the foot pedal. Manual says something about checking bobbin winder indent. What is a "Bobbin winder indent."
bobbin winder is the little spindle on top usually right side above the flywheel. you need to move it left away from the stop as this engages the bobbin winder and disengages the needle movement. your manual should show this under Winding a bobbin. these machines dont have a clutch on the flywheel, just moving the bobbin spindle declutches
Sep 18, 2011 | Singer 6038 Mechanical Sewing Machine
Need to know how to thread bobbin
manuals can be purchased @ janome. com. your machine should have a bobbin winder. Set empty bobbin on the bobbin winder pin. Thread spool of thread though guide(or tension wheel on the top of the machine;NOT the stitching tension.) wrap thread around bobbin to start, and push bobbin toward the flywheel. slowly press foot pedal and bobbin should begin to turn. apply more pressure to foot pedal to increase speed.When full, bobbin winder should kick back to stop.
May 29, 2010 | Janome 2049LX Mechanical Sewing Machine
I have a Necchi sub 22 sewing machine and I cannot get the automatic bobbin winder to work and there is hardly any notes in the manual. I am threading up the winder the way it say but when I press the foot...
When you put the bobbin on the winding pin, you need to push the bobbin toward the other round pin next to it. That activates the bobbin winder. If you look closely at the picture in the manual, there is an arrow showing to push the bobbin over.
Feb 13, 2018 | Necchi Sewing Machines
Kenmore by sears model 1581457180 need a manual or a how to thread the bobbin
hi there,
on my manual 1581 kenmore show figure on how you thread your bobbins and upper thread.
to thread bobbin insert the thread on one hole of winder holding thread and rotate thread on counter clockwise rotation several times, loop the thread on tension thread and insert bobbins winder on winder shaftat top of your sewing machine push the latch to lock bobbin winder
pull the handwheel to disengage the clutch and to move the winder free rotation.
press the foot pedal to run your winder and thread your bobbins be sure on counterclock wise rotation.
if winder is full of thread this will automatically disengage the shafting winder from clutch.
4843169.jpginsert winder as in fig. check the thread direction
5d74924.jpg 153629c.jpg on figure hold and insert bobbins on shuttle race assymble.
on figure show upper threading.
3cba620.jpg follow the red thread on figure.
you can also check your manual on internet
search box type www.kenmore 1581
have a nice day,rate my fix,thank's a lot
Jun 12, 2009 | Sewing Machines
Need to thread machine-no manuel
most common machine have in threading process,I ve holding different brand sewing machine they only differ is in design but the process are commonly same,start bobbins winder to wind threads
  • pull thread from spool on top of machine insert bobbins winder disc then rotate on bobbins winder 4 to 6 times manualy put it on the shaft winder locate at top of machine near handwheel,push the latch against to bobbins winder to fit,then release clutch handwheel by pulling handwheel to disengage motio only winder will rotate when you press foot pedal and start winding thread on clockwise rotation.if this filled insert bobbins winder to bobbins case and pull the end of thread inserting to the slot of bobbins case observe should have tension on this.e5b8d97.jpgas shown and dirction of thread.inset this on the shuttle case.then start looping thread on top of machine as shown22d0eb9.jpgthen start adjusting tension on tension dial you can see in fig.Set dial at # 3 at start of set up ,Stich adjustment at #8 to 12 adjust gradually.
the hook up the lower thread bobbins from lower shuttle by threads on needle then insert cotton fabrics manualy rotate handwheel until needle the fabrics freely don't apply foot pedal let it shown if the neele sew freely w/o looping under bobbins let sew manualy until it appears stiches on fabrics,if ok continue now aply foot pedal
gradually until you familiarize again the sewing.
Mar 14, 2009 | Bernina Sewing Machines
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Jun 05, 2008 | Kenmore Sewing Machines
Sewing Machines Logo
70 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
