Question about Nokia E5 Cell Phone
My nokia e5 does not get connected to my wifi at home
I have bsnl's wifi broadband at home, to which I am able to connect our 3 laptops easily. I am able to connect out Lumia 510 phone too, without any difficulty. But I am not able to connect thru my e5. The network authentication I have set is 'mixed wpa2-wpa-psk' and WPA encryption is AES. My e5 phone shows that the wlan is available, but when I try to connect after giving the psk, it gives a message "Wlan not found". It is very frustrating! When I try thru Nokia Asha 305, the system rejects saying: "invalid key", though I enter the correct key. Finally, only Lumia 510 works - not e5, not asha 311! Please help!
Bsnl broadband modem
Indian Telecom gaint Bharat Sanchar Nigam Limited (BSNL) has introduced 4 types of ADSL Broadband Modems(ADSL Basic Modem(CPE), ADSL WiFi Modem, ADSL WiFi-TA Modem & VDSL WiFi Modem) with Ethernet, Wi-Fi , USB, and Terminal Adapter port.
Which version have you got?
Feb 10, 2014 | Acer Computers & Internet
NSN 1600, restored to factory settings, no internet access, internet light blinking fine, help
Some people find configuring Nokia Siemens Residential Router 1600 with BSNL is a little difficult. So I would like to present a tutorial to setup Internet connection with BSNL using Nokia Siemens Residential Router 1600. Just like other BSNL modem/ router models, we do not need any setup disc to configure Nokia Siemens Residential Router 1600. All we need is to follow some simple steps and adding some values. We can also setup wireless and wireless security from the web based setup page Configure Nokia Siemens Residential Router 1600 In order to configure Nokia Siemens Residential Router 1600 with BSNL follow the steps below.
1. Connect Nokia Siemens Residential Router 1600 to computer using Ethernet cable
2. Power on Nokia Siemens Residential Router 1600
3. Type on address bar of Internet Explorer and press enter
USER Name: admin
Password : admin
Now you can access the web based setup page of Nokia Siemens Residential Router 1600.
Apr 09, 2013 | Computers & Internet
Well you shouldn't be using ADSL + a modem. You should have just a broadband modem and there shouldn't be any "dialing" with a broadband modem.
Dec 03, 2011 | Computers & Internet
I have bsnl broadband connection; i am using a desktop to connect the internet,but i cant able to connect other laptop with wifi. i need bellow things with step by step instruction: 1.connecting one...
Your router has an lan address or IP. Something like This is what you must connect to. Each of the machines you want to connect must have (in this example) an IP number between and As long as your machines all have a unique IP they should all connect to your router. Your modem will have a gateway and typically this will be something like So setup for one machine may look like this [ subnet
To find these setting, click on your lan connection, select "properties" and choose "Internet Protocol TCP/IP". Here you will see these settings. Your router guide will give you these settings, make sure you get them from your router guide.
Mar 11, 2010 | Computers & Internet
Non connectivity with thomson tg585 v7 modem with bsnl broadband.
what is bsnl broadband if you have thomson to acsess the setup and all it freater just type speedtouch.lan in your browser this may help you
i think
Jul 02, 2009 | Thomson RCA DCM245R Modem
I cannot connect to by bsnl broadband modem with laptop
Please check your DNS settings. If you dont know your DNS settings you shall use the global DNS server
Jun 04, 2009 | Computers & Internet
well that was easy, you havent detailed any problems to rectify.
assuming there is a connectivity problem sharing the broadband connection,
buy a cheap router, or switch, and install between the cable modem and all 4 pcs
Jun 28, 2008 | Intel Motherboard
Nokia E5 Cell Phone Logo
66 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
