Question about Canon PowerShot S3 IS Digital Camera
Card locked appears on screen
I cannot take any photos because "card locked" appears on the screen. How do I unlock it?
  • catsatterwhi
    catsatterwhi Jan 04, 2013
    OMG! Thank you so much... we usually video the kids coming down the stairs for their prezzies christmas morning. That's when I noticed the lock. Now that the holidays are over I've finally looked into a solution.I could hug you right now! () THX! >^.^<
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Jan 04, 2013
4 Suggested Answers
LongPockets
  • 1177 Answers
SOURCE: Shot A 530, and it
I guess that your memory card is an SD type. These cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Posted on Nov 19, 2010
  • 102366 Answers
SOURCE: Camera states on screen that "card locked". How do
Posted on Sep 20, 2011
lock123
  • 6831 Answers
SOURCE: My camera screen is saying the "Card is Locked".
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Dec 08, 2010
Testimonial: "Brilliant! Thanks for an instant solution."
Camera reads card lock when trying to take a photo
Since you neglected to specify the make and model of your camera, I'm going to assume it uses SD/SDHC cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 17, 2012 | Cameras
Tip
How to enter unlocked code in BLACKBERRY phone?
<br /><br /><br /> TIPS on HOW to UNLOCK<br />BlackBerry HOW TO ENTER NETWORK UNLOCK CODES<br /><br /><br /><br />Blackberry Curve, 8800, 8300 8520<br /><br />Unlocking can be done without SIM card inserted<br />Turn wireless mode off<br />While on the home screen click the "Settings" icon<br />Go to "Options" menu and select "Advanced options"<br />Select "SIM card"<br />Hold the ALT key while typing MEPE. You will not see text appear on screen while typing<br />You should be presented with a prompt "Enter Network MEP Code"<br />Enter supplied unlock code<br /><br />8700c<br />To enter codes:<br /><br />-Go to options<br />-Advanced options<br />-Simcard<br />-type MEPD<br />-type MEP press"alt tab" type 2<br />-enter readed mep code<br /><br />7290<br /><br />Entering unlocking codes:<br />1 - Using the menu go to Settings Menu -&gt; SIM card press select.<br />2 - While holding the SHIFT key, type "MEPD"kanan<br />3 - You should now see the five locking categories listed.<br />4 - While holding the ALT KEY, type "MEP2" kaliwa<br />5 - Release the alt key.<br />6 - You are now prompted to enter the Network MEP code (will also state how many attempts left)<br />7 - Enter the code<br />8 - Enter Return/Enter<br />9 - The device should then be unlocked<br /><br />7100g<br /><br />go to settings , options , sim card , ten<br />Type 'MEPD' respectively 'MEPPD' in case phone is 7100<br />Usually u should see active NET lock. Now in order to disable this lock type 'MEP2' respectively 'MEPP2' if<br /><br />phone is 7100 and will appear a dialog asking for code<br /><br /><br /><br /><br /><br />Blackberry<br />5xxx, 6xxx, 7xxx Series (except for BB 7100 and 7130)<br />Turn wireless mode off<br />Go to "Options" menu<br />Go to "SIM card"then press the jogdial to select it<br />Type MEPD (not case sensitive). You will not see text appear on screen while typing<br />It will say "Network active"<br />Press and hold the ALT key (half moon looking key on the lower left side)<br />While holding the ALT key type in MEPE (not case sensitive). You will not see text appear on screen while<br /><br />typing<br />When prompted enter supplied unlock code<br />After entering the code press the jog dial<br />Your phone is unlocked<br /><br />Blackberry 7100, 7130<br />Turn wireless mode off<br />While on the home screen click the "Tools" icon<br />Go to "Options" menu<br />Select "Settings"<br />Go to "SIM card" then press the jogdial to select it. You should see the phone number and the SIM ID number<br />Type MEPP2 (not case sensitive). You will not see text appear on screen while typing.<br />Press ALT and 2 simultaneously to get number 2.<br />Enter supplied unlock code<br />After entering the code press the jog dial<br />Your phone is unlocked<br /><br />Blackberry 8100 Pearl<br />Unlocking can be done without SIM card inserted<br />Turn wireless mode off<br />While on the home screen click the "Settings" icon<br />Go to "Options" menu<br />Select "Advanced options"<br />Go to "SIM card" then press the jogdial to select it<br />Type MEPP2. You will not see text appear on screen while typing<br />Press ALT and 2 simultaneously to get number 2.<br />Enter supplied unlock code<br />After entering the code press the trackball once<br />Your phone is unlocked<br />If the unlocking code is entered incorrectly the next attempt to unlock the device will be delayed for 10<br /><br />seconds increments. The number of unlocking attempts is limited. When this number is reached the phone will<br /><br />be permanently blocked.<br /><br />alternative instructions<br /><br />Insert SIM card into the device<br />Power on the phone and turn Wireless Off<br />Go to "Settings" then "Options" menu and select "Advanced options"<br />Go to "SIM card" then press the jogdial to select it<br />Type MEPPD. Please note that you will not see what you type on the screen.<br />Type MEPP2. You will not see text appear on screen while typing<br />Press ALT and 2 simultaneously to get number 2.<br />Enter supplied unlock code<br />After entering the code press the trackball once<br />Your phone is unlocked<br /><br />alternative instructions for some Vodafone Blackberry 8100<br /><br />Insert non original SIM card into the device<br />Power on the phone and turn Wireless Off<br />Go to "Settings" then "Advanced options"<br />Go to "SIM card" then press the jogdial to select it<br />Type MEPP2 while holding Alt, multitap enabled (hold [Alt], type [M] [ER] [OP] [OP] [TY]. Please note that<br /><br />you will not see what you type on the screen.<br />When prompted with "Enter Network MEP code (255 left)" on the screen, enter the 16-digit network unlock code<br /><br />provided for your phone, then press Enter<br />Pull the battery out of the phone<br />Switch the phone on and the phone will be automatically unlocked<br />If the unlocking code is entered incorrectly the next attempt to unlock the device will be delayed for 10<br /><br />seconds increments. The number of unlocking attempts is limited. When this number is reached the phone will<br /><br />be permanently blocked.<br />To unblock such phone, it must be taken to a RIM service centre. No outgoing calls including emergency call<br /><br />is possible when the phone is blocked.<br /><br />Blackberry Curve, 8800, 8300<br /><br />Unlocking can be done without SIM card inserted<br />Turn wireless mode off<br />While on the home screen click the "Settings" icon<br />Go to "Options" menu and select "Advanced options"<br />Select "SIM card"<br />Hold the ALT key while typing MEPE. You will not see text appear on screen while typing<br />You should be presented with a prompt "Enter Network MEP Code"<br />Enter supplied unlock code<br />After entering the code press the trackball once<br />Your phone is unlocked<br />If the unlocking code is entered incorrectly the next attempt to unlock the device will be delayed for 10<br /><br />seconds increments. The number of unlocking attempts is limited. When this number is reached the phone will<br /><br />be permanently blocked.<br />To unblock such phone, it must be taken to a RIM service centre. No outgoing calls including emergency call<br /><br />is possible when the phone is blocked.<br /><br />alternative instructions<br /><br />Turn wireless mode off<br />While on the home screen click the "Settings" icon<br />Go to "Options" menu and select "Advanced options"<br />Select "SIM card"<br />While holding the ALT key type MEPD. You will not see text appear on screen while typing<br />While holding the ALT key type MEPE. You will not see text appear on screen while typing<br />You should be presented with a prompt "Enter Network MEP Code"<br />Enter supplied unlock code<br />After entering the code press the trackball once<br />Your phone is unlocked<br /><br />Blackberry 8700, 8700c, 8707<br /><br />Unlocking of these models requires a SIM card inserted (active or inactive)<br />Turn wireless mode off<br />While on the home screen click the "Settings" icon<br />Go to "Options" menu and select "Advanced options"<br />Select "SIM card"<br />Hold the ALT key while typing MEPE. You will not see text appear on screen while typing<br />You should be presented with a prompt "Enter Network MEP Code"<br />Enter supplied unlock code<br />After entering the code press the trackball once<br />Your phone is unlocked<br /><br />Blackberry 8230 Curve<br />Press the "menu" key<br />Scroll and select "Manage connections"<br />Select "Turn all connections off"<br />Press "Escape" to go back to the "Home" screen<br />Go to "Options" menu and select "Advanced options"<br />Select "SIM card"<br />Hold the ALT key while typing MEPD. You will not see text appear on screen while typing. This opens up a<br /><br />personalization menu<br />Hold the ALT key while typing MEP2. You will not see text appear on screen while typing<br />Press ALT and 2 simultaneously to get number 2.<br />You should be presented with a prompt "Enter Network MEP Code"<br />Enter supplied unlock code<br />After entering the code press the trackball once<br />Restart your phone and restore connections by following the first two steps<br />Your phone is unlocked<br /><br />Blackberry 9000, 9500, 9530 Storm<br /><br />Insert any sim card<br />Scroll and select "Manage connections"<br />Select "Turn all connections off"<br />Press "Escape" to go back to the "Home" screen<br />Go to "Options" menu and select "Advanced options"<br />Select "SIM card"<br />Select "Show keyboard"<br />Hold the ALT key while typing MEPD. You will not see text appear on screen while typing. This opens up a<br /><br />personalization menu<br />Hold the ALT key while typing MEP2. You will not see text appear on screen while typing<br />Press ALT and 2 simultaneously to get number 2.<br />You should be presented with a prompt "Enter Network MEP Code"<br />Enter supplied unlock code<br />After entering the code press the trackball once<br />Restart your phone and restore connections by following the first two steps<br />Your phone is unlocked<br /><br /><br /><br /><br /><br /><br />8310<br /><br />how<br /><br />Go to "Options" menu and select "Advanced options"<br />Select "SIM card"<br />While holding the ALT key type MEPD. You will not see text appear on screen while typing<br />While holding the ALT key type MEPE. You will not see text appear on screen while typing<br /><br /><br />8830<br />How to enter codes in BlackBerry<br />1. Insert any sim card<br />2. Turn off all of the wireless connections<br />3. Go to Options<br />4. Select Advanced Options<br />5. Select SIM Card<br />6. Hit menu select show keyboard (where needed)<br />7. Type MEPPD or MEPD (you will not be able to see the typed info)<br />8. Enter ALT MEP2 or MEPP2<br />9. Now it will say enter network mep code<br /><br />
on Feb 12, 2011 | Cell Phones
I want to take some photos but the write on the screen " the card is protected" how could i remove the protection and use the camera?
is there a small switch on the side of your memory card? if so, check its position. if it's locked, simply slide it to unlock it. Good luck.
May 25, 2012 | Samsung TL100 / ST50 Digital Camera
Screen reads "memory card is
Jul 24, 2011 | Nikon COOLPIX L18 Digital Camera
Sdcard protect: when I plugg on camera an error message appears on screen " SDcard is protected " I tried to change SDcard and the same message related to sdcard appears . I can not unprotect...
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 25, 2011 | Intova CP8 Digital Camera
"this memory card is locked" appears on screen
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If that doesn't do it, try another card and see what happens with that one.
May 13, 2011 | Panasonic Cameras
Screen displays "card locked" and
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 29, 2011 | Samsung S860 Digital Camera
I pressed the "on" button
Move the slide switch on the side of the card.
Feb 01, 2011 | Cameras
Good day.. After uploading photos to my PC using USB connection of my GE X5 camera " Write protect error " always appears when taking shots.. Please help.. Thank you very much. -TeR-
Nov 23, 2010 | GE X5 Digital Camera
Hi, I can view photos I have taken but can no longer take photos because of a 'card is locked' problem message that appears on the screen. How do I unlock the card? The camera in question is the Casio...
there is a locking mechanism on the side of the card, shift it down or up to unlock mode. Your card can also be full and you may need to download some photos and remove them from the card so that you may be able to reuse the card. Otherwise buy a new card
Dec 07, 2009 | Casio EXILIM Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
61 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
