Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My garage door craftman 1/2 HP model 139.18458 DM will sometimes open and stop while opening. If I just hit the opener lightly it will come back on and work sometimes I will have to hit more than once
Craftman door opener remote 1/2 HP 315 mhz model 139.18458. Almost seems like there is a loose connection inside the open. Not sure ???
SOURCE: Garage door won't close
your door travel screw is set to go too far on the downward travel. you need to set the down travel. It is set to go too far down. find the screw adjustment on the unit that says close and back off the screw a full turn until door stops short of floor. then start turning screw other way until door just touvhes floor.
Posted on Mar 06, 2008
  • 11 Answers
SOURCE: Sears Craftsman Garage Door Opener Wireless Keypad Model and a LiftMaster Chamberlain Professional Garage Door
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps!
Gail
For possible future reference:
How to change an existing, known PIN
(Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
Posted on Jun 24, 2008
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Posted on Jul 25, 2008
  • 3197 Answers
SOURCE: Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Posted on Jun 01, 2009
  • 3197 Answers
SOURCE: Sears Craftman Garage door opener model # 41A3493-1
That isn't the model number you give it is the part number for the logic board. The model number is on the opposite end of the motor unit and starts with 139. If you are asking if the opener should reverse when it hits an obstacle the answer is yes. If it doesn't it is not adjusted correctly or is faulty.
Posted on Dec 01, 2009
Engine won't program a new remote
Please clarify your question ! What do you mean by engine? The remote sends a signal to the logic board that syncs up with it, make shure they are the same frequency so if the logic board is 315 MHz the receiving board should be the same , don,t think because they look alike that they are , please check the data tag on the opener and on the garage door opener to make shure that the frequency is the same !
Jul 07, 2014 | liftmaster Garage Door 1/2 Hp
Craftsman 1/s HP 315 MHz garage door opener (Model 139-18470DM). The temperature here is currently 34 degrees celsius with the windchill. When trying to close the garage door from the main switch, the...
Check for some obstacle in the path of the light beam sensor that (should) be installed across the width of the door opening about 3-4 inches off the ground.
Jan 30, 2011 | Sears Craftsman LiftMaster Chamberlain...
In December 2009 I had a new garage door opener installed. I have 2 remotes for this unit. One just quit working. How did I fix it? It is a Sears model - Craftman 315 #139.18191. It is not the battery...
I don't trust batteries even when they are new. Try taking the battery out of the remote that is working and install it in the remote that isn't. If that doesn't work you need to purchase a new remote.
Nov 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
I can't get my old remote to work with my new garage door opener
buy new remotes. New opener is 315 mhz, old are 390 and not compatible,
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
415 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
