Question about Watts Up net Electric Meter Remote Internet Monitoring
Buzzing noise from electricity meter
Have had a buzzing noise from the electricity meter and blows lights in hall circuit and livingroom circuit.
How can I get the dryer to turn on.The button makes a buzzing noise when I push it, but .the dryer doesn't start
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Mar 30, 2015 | Kenmore 24" Laundry Center w/ Electric...
Replace 15 amp fuse to a 30
NO,NO,NO ! Fuses are electrical protection for the cars wiring installing a higher amp-age fuse takes longer to blow so your wiring gets hotter and starts to melt the insulation and shorts to other wires eventually burning up the harness. With a amp meter test the circuit to see how much power is needed to keep the circuit going if over rated (15 amp circuit taking 20 amps) then install a cycling circuit breaker 10 amp this will blow and cool and blow again continually then with a magnetic amp meter (Gauss meter) you can locate your short the source voltage causes the amp meter to jump as the fault occurs when you pass it meter will stop working.
Apr 22, 2014 | 2002 Ford Escape
I have a 2006 safair simba gas on a ford chassie and the 12v recpticals on the dash board do not work as well as the one on the passenger side livingroom. i can not locate any fuses that are used for...
the case for the 12 volt recepticals have an internal fuse. T?est with an ohm meter to see if the case is shorted out. If so replace the case.
The tow/haul button does not come out to be serviced Most likely that will be at fault. Check that also with the ohm meter to see if continuity is there.
Sep 14, 2011 | Ford F-450 Cars & Trucks
Hotub clicks and then makes buzzing noise when turned on.
does it blow a breaker? check to see what is going on by unplugging all the pumps, blowers lights and anything else plugged into the circuit board (heater too)
turn the breaker on once everything is unplugged and then proceed to turn the spa off, plug one item back in and turn the breaker back on.
Do this until you find the buzzing....
You may actually have a back relay on the circuit board causing the buzzing by not latching in when the pump or something is trying to come on.
Rod
Aug 23, 2011 | Home
Kenmore 600 series dryer.model # 110.67622600. wont start. light goes on & off when i push and release the door switch. when i push the starter switch it make a clicking buzzing sound. more noise when...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Kenmore 67632 Electric Dryer
I have a new Hunter Fan that is making a buzzing noise and the lights are flashing when I turn it on. I have four others that are fine.
Right off hand, I'd say, there's some loose wiring somewhere in the fan's electrical connections to the light fixture Removing the light fixture will give you access to that wiring. Be sure the wall switch for that fan is OFF, as well as the circuit breaker for the wall switch.
Hope this helps you to troubleshoot and solve the problem.
Jun 23, 2011 | Hunter Heating & Cooling
BLOWES FUES TO RADIO/INTERIOR LIGHT/ETC
use a voltage meter to check the circuits for cotinuity if they are grounded out you may end up with even worse problems down the line. volt meter should read no load.
Nov 10, 2009 | 1998 Jeep Cherokee
My RCA projection tv makes a loud buzzing, humming noise. Does as soon as turned on even before picture comes on, does not stop till tv is turned off.
buzzing noise is cause by small electrical arc inside the unit or a problem in your audio circuit.if you can open the unit up and check if its an electrical arc.
Jun 21, 2009 | RCA HD52W59 HDTV Projection Television
My central ac unit is blowing air that is cool but not cold
Ek chiz sukha ho to 2kg gila ho to 1kg and jal jaye to 3kg its urgent please
May 18, 2009 | Heating & Cooling
The drum doesn't rotate and a strange buzzing noise occurs
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE;
Aug 22, 2008 | Zanussi Dryers
Watts Up net Electric Meter Remote Internet Monitoring Logo
99 people viewed this question
Top Watts Home Security Experts
Lawrence Oravetz
Are you a Watts Home Security Expert? Answer questions, earn points and help others
