Question about Acer PD113 Multimedia Projector
Need driver for acer pd 113
My projector will not connect properly tomy laptop. i cannot find my disk. i need the driver to make it work with my laptop which is on vista and cannot find it anywhere, the acer website only has the user guide which is useless.
  • Anonymous Apr 19, 2009
    my driver disk in broken
  • phfpaisuf Nov 15, 2009
    me too ne1 found ne link to solve it plz inform plz
SOURCE: Driver for Acer Aspire 5100 optical drive
Hey...I have a acer aspire 5100..but I havve downloaded ever realtek version but none can be installed on my laptop what do I have to do?
Posted on Mar 12, 2008
SOURCE: Drivers for my acer aspire 4720z
acer.com eneter your model in dl vista drivers all to folder on hd ok
airbala
  • 4 Answers
SOURCE: acer pd 112 projector
Please reset lamp hours to zero and clean its air filter located to its bacside (Bottom)
Posted on Mar 17, 2008
SOURCE: wireless connection problems
Yes!! I finally have a solution. On my wireless Acer Aspire 5720z. (From vista to XP) What I do? Ok. I download the vista-7.1.0.90-whql from the .ck page. With this one the Acer recognice the wireless but have problem with the installed driver. Then I download the xp32-7.6.0.239-whql, go to My Computer rigth click to properties, hardware tap, Click devive manager, on network adapter right click, Update driver and update with the xp32-7.6.0.239. That is all. Sorry for my bad English. Puerto Rico lo hace mejor!!!! Maury
Si finalmente encontre como resolver el problema de wireless the mi maquina Acer Aspire 5720Z. (de Vista a XP) que fue lo que hice. Fuy a la paguina que algunos hablan .ck y baje el programa comprimido vista-7.1.0.90-whql con este ella pudo ver el wireless pero tenia problemas con el driver entonces baje el xp32-7.6.0.239 le di update al driver y resuelto el problema. Gracias a todos los que alludaron de alguna manera o otra!!!
Posted on Nov 05, 2008
jay_win2002
  • 16 Answers
SOURCE: Wireless mouse doesn't work.
dose the mose use a battry''' and is the keybourd and mose a set did they come together''as a set'? if not they will not work'''let me know my name is jame '' e-mail me at '' jay_win2002@yahoo.com .
Posted on Jan 30, 2009
I'm using an acer aspire laptop and a viewsonic projector. projector colors and disply works fine with an xbox bt when i se my laptop, the projector screen goes red. is it the settings on the comp
Make sure you have all drivers and software necessary for the projector installed on your laptop. You can find them on viewsonic's website. Also go to Control Panel>Display>Connect to a Projector and insure all settings are correct. Let me know if you run into problems.
Jun 13, 2012 | Acer Aspire 5100 (5100-5674) PC Notebook
When I connect a projector to my easynote LJ75 I cannot make it operate. I've tried toggling the FnF4 but it only shows the computer icon. I know everything else operates because it functions properly...
make sure if you have the options to enable and disable fn key on system setup. it might be disabled or need driver for your hot keys to work properly
May 26, 2011 | Acer Computers & Internet
I am trying to use acer projector pd 113p with laptop OS window 7.... usb not recognised
change resolution from the screen, decrease him. the projector don?£t suport high resolution
May 17, 2011 | Acer PD113 Multimedia Projector
No LCD connectivity
Hello, I am using a Viewsonic lcd projector with my new Acer Aspire One. I did not have connectivity off the bat. Here's what I did: 1. Downloaded driver (unsigned, not the signed version worked - ie not os-specific) for the lcd projector to the Acer. Restart Acer. 2. With lcd projector connected to Acer, toggle function key & F5. But then, continue holding down the function key. A screen pops up with icons for laptop, laptop/monitor, dual monitor, and lcd projector. You continue to hold down the function key and then press the F5 key to move to the desired device. I had to repeat the same process to restore my Acer screen to the original proportion when not using lcd projector. I'm not sure if both steps 1 and 2 are necessary, but I did it simultaneously, so I'm not sure of the origin of success.
May 22, 2009 | Acer Aspire One PC Notebook
I'm using acer aspire one. My SD port is not working. It can not recognize the memory card. Also when I connected my laptop with LCD multimedia projector, it did not work too. Oh my God, anybody there who...
ok ... try this, switch on your aspire laptop, then u switch on your LCD multimedia projector... then u press the F5 key on your keypad(on your aspire) , HP, and many other manufacturers uses that key for the LCD,CRT,projector extension slot while other laptop manufacturers like Gateway e.t.c uses the F4 key for the extension... after you have done that... your aspire screen goes dim then it should show on your LCD...but if not then switch off your laptop with your LCD multimedia projector ON then swicth on your laptop it will automatically work with it ok.....
this applies to other laptops and projectors or LCD s ...
Mar 27, 2009 | Acer Aspire One PC Notebook
Unable to transmit image to projector
Usually you can use a VGA connection cable to connect your computer with a projector. They also have inputs for s-video and RGB but these are much rarer on computers. Once you have connected the projector press the key on your keyboard that looks like a square with two lines on either side (mine is FN+F4) This will shuffle through different setups (mirrored to screen, extended to screen and back to normal) if this doesn't work try plugging in the vga cable and restarting the computer with the projector on.
Jan 06, 2009 | HP Pavilion dv4000 Notebook
Acer data projector
you have noy correctly loaded the the mother board driver
so again load the mother board driver for access, if not then reformat the laptop using original o.s disk.
Feb 07, 2008 | Computers & Internet
Acer PD113 Multimedia Projector Logo
475 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
