Question about Linksys Wireless-G Broadband Router
Lost my Linksys Wireless-G Pass word
Don"t remember my pass word. How can I find it?
  • mrgoose50 Jan 20, 2009
    Thanks with your help I got it going.
  • solutions4u May 11, 2010
    Are you able to access the router's main menu through your browser? If you can but the menu fails to show you the password because it only provides you with **** then you may be able to completely reset the hardware and reset your password. Please clarify.
Be sure to leave the username blank or to say it another way skip the username field and go directly to the password field.
If you have not changed the default password, then it is "admin".
Posted on Jan 19, 2009
I don't remember my passcode
call them and tell them you don't remember your pass word and they can reset it for you
Jan 14, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Setting a password to my wireless router
just click on your wireless setting at the bottom right of your computer it might be under hidden click on to your wireless settings in there it says set your security pass word put a pass word in and remember it and thats it
Dec 13, 2011 | Linksys Wireless-G WRT54G Router
I'm trying to get online with Linksys-G wireless router but am kept from it by the request for PASSWORD. "Admin" doesn't work and my own passwords don't either even though...
If you have not did any modification alerady in the router the original name and pass word are Name : admin PW : admin
If the router has alerady been modified and you do not know or remember the pass word you will have to reset it by pressing with a sharp object in a little hoen in the back of the router mentionned "RESET" hold it pressed for 15 to 30 sec while the modem is OPEN you should see the loght flashing when it will reste once resetted the name and password will be like mentionned earlyer
Jul 25, 2011 | Linksys Wireless-G WRT54G Router
May i have a quuestion to you regarding my problem on how to set up the linksys broadband router 2.4 ghz 54 mbps through my loptop? pls answer me asas pls.!!!!
you need to configure your linksys router. to do this
connect to the router with a cat5 cable in any of the lan ports.
open internet explorer and go to the http://192.168.1.1
the default login/pass login : blank pass: admin
if you had changed this before please use that login/pass. or reset the router if you can't login by holding the reset button for 30 secs.
once you login go to the wireless button.
there you can set the SSID of your wireless network. this will be the name of your wireless network.
then go to wireless security to set the security to WPA.
choose a good passphase that you can remember.
apply the settings you had made.
on your laptop unplug from the router and search for a wireless network. you should see the ssid name that you made.
connect to it and it will prompt you to input a wireless password.
put the passphase that you setup for your wifi.
you should now be able to surf the internet wirelessly.
Mar 28, 2011 | Linksys Wireless-G Broadband Router
Pass pharse
Log on to the router, go to wireless security.
I would choose WPA ( you choose the password)
WEP is much weaker, try not to use WEP ( It gives you a pass phrase/key)
Jul 22, 2010 | Linksys WRT160N Wireless Router
I lost the pass word for my Linksys. how do I get
You will have to reset the router itself. On the back of the router is a reset button, it will return the router to its factory original settings. You will have to reconfigure it according to your previous settings.
Jan 17, 2010 | Linksys Wireless-G WRT54G Router
Hi i hope you can help me i nead to know how to reset the pass word for a linksys wireless n broadband router model wrt160n v2 my laptop had a virrious and i lost everything i do not remember the pass word...
Ok, on the bottom of the router there is a reset button you need something small to push in. Once you press this the router will go back to fatory settings and you can set it up again with a new password and settings.
Nov 05, 2009 | Linksys WRT160N Wireless Router
I have internet with time warner so have linksys router wireless'but when a try to connect to other computer don,t work
First, check to make sure that you can get Internet through a wired connection, if you can't then wireless won't work either. Second, if you can, then try connecting to the wireless without using WEP or any security. You can turn this off by going to 192.168.1.1 in your web browser while wired to the router from your PC and go under wireless security. If you can connect from an unsecured access point then set up a WEP key with a pass-phrase and when you are asked for the pass-phrase from the PC use the the hex key 1 that is generated by the router instead of the pass-phrase. You should have no problem connecting. Thye wizard that comes on the configuration CD will not set up your wireless correctly, you really have to configure the system using the IP.
Oct 01, 2009 | Linksys Wireless-G Broadband Router
Need to setup Laptop wirelessly thru Linksys WRT54G
The default password of Linksys device is admin without username.
Jun 06, 2009 | Linksys Wireless-G WRT54G Router
I dont remember password
In order to know your password you have to:
1) Use some program to reveal the pass
2) Get access to your router
To get access to your router do this
1) Open your browser
Type .......
http://192.168.0.1
user = admin
pass= (blank) no password
hit enter
Once inside go to Wireless and see which is your WEP password
That's it
If your wireless router have a different pass than default you need to reset the router
Oct 29, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
140 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
