Question about Sony Ta-sa100wr S-air Surround Amplifier Ezw-rt10a Wireless Transmitter
Not switching on TA-SA100WR. LED never comes ON even Connceted to Power Source!
TA-SA100WR (S-Sir) LED Switch off after a second even when the Power connected. No Sound. What could be the Problem?
5 Suggested Answers
CompuGuy44
  • 432 Answers
SOURCE: power on problem
Many of the later model Sony TV?s have a built in self-diagnosis function. AKB circuit (automatic kine bias), the timer/standby indicator blinks 5 times for about 30 seconds then goes to the self-diagnosis function. In other words, the IC chips on the Cboard are burned out. This repair is not one that should be attempted by the end user. This repair will need special test equipment. You will need to take it in for repair. It shouldn't cost more than $170-$200. This is cheaper than a new TV set.
Posted on Jun 23, 2007
localwonder
  • 6784 Answers
SOURCE: TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
Posted on May 21, 2009
  • 733 Answers
SOURCE: Sony vaio pcg-k33p Won't power up
I had one with the same symptoms, the way i fixed it is by taking it all apart and resolder the system chasis grounds on the mother board, then reseting the motherboard's memory battery. A bit complicated for those with little knowledge on computer repair. You may have to take it to a computer shop, or try fixing it yourself. It took a while to figure it out.
Posted on Feb 11, 2010
Testimonial: "This solution re a firms what others have said about resetting or checking the bios battery, which is the next thing I will try. Thx for the response."
  • 1139 Answers
SOURCE: Hello,when I turn on my
Hello, what you are describing is unfortunately called the Yellow Light Of Death (YLOD). Although you have not technically got the yellow light as the console manages to stay on for a minute or so it is still exactly the same problem. When the PS3 was originally made Sony used lead free solder in their consoles. Lead free solder is not as flexible as normal leaded solder and over time due to expansion and contraction because of heat given off by the console's components hairline cracks formed in the solder joints between the CPU and GPU and lots of PS3's failed. You have got a couple of options, you can either have the console professionally repaired which is going to cost around £50. If the console is out of warranty Sony will only replace it for a cost of around £130. As a last resort if you are good with electrical items you might want to have a go at repairing it yourself. If you google YLOD you will find plenty of guides that will instruct you on how you can repair it yourself.
Please bear in mind that once a console has the YLOD there is NO guarantee as to how long a repair will last, it could be a couple of hours to a couple of years
Hope this helps
Posted on Feb 05, 2011
Sir, Iam using the ZED-10FX Allen & Heath mixer. Iam not getting the 48V phanthom power and AUX out from the mixer both Green and RED LED on Phanthom power is not glowing. Iam getting the LED VU m
sOMEHOW YOU BLEW THE 48 v PHANTOM SUPPLY.
Open it up and check power board voltages.
Replace regulator circuit and check for shorts on your mic cables.
PEACE---
Feb 09, 2015 | Allen & Heath ZED-10FX Sound Mixer
My lg studiowork 700s has stopped working
look listen and dance not matter how you performance keep it calp and trust it
Feb 20, 2014 | LG Studioworks 700S 17" CRT Monitor
Hi, my sony ta-fe370 has stopped working. All fuses seem fine and there is no obvious visual problems inside. The red led next to the power button comes on but then goes out again. The source selection...
What power are you meaning that Also, all of the other decks connected to this also have lost power Is this mains power If so check the power on the switch
Oct 12, 2013 | Sony TA-FE370 2-Channel Amplifier
I have a Sony power amp TA-N9000es there is no sound do you need a remote or is there a volume control inside the case. Have tried every input every speaker connect there is just no sound. what can i do...
It's just a big amp with no controls you would change during normal operation. There's no remote. You don't name any source or if you even HAVE one attached. THAT would be a good place to look for missing sound.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/sony/sony_ta_tan9000es.html
http://dl.owneriq.net/f/fede44fb-b9ba-4e03-87bb-d0f3e29e22ef.pdf
Set the BTL/Normal switch on the back to Normal. In fact, any switch or knob with BTL, set it to whatever choice is NOT BTL.
Mar 24, 2011 | Sony TA-N9000ES 5-Channel Amplifier
Cannot wake up kindle even after sliding power switch
Try to slide and hold the power switch for about five seconds, until after the power LED behind the power switch blinks three times.
Dec 31, 2010 | Amazon Kindle Wireless Reading Device
Power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Sep 26, 2007 | RCA 32F531T 32" TV
Stays on even if HU (CDA-9833) is off
It is possible that the SIR unit stays powered as long as the red wire is powered, since it is normally connected to a switched source. To test this, disconnect the red wire or move it to a switched source (you could even add a switch on the wire and flip it manually). If the battery stays healthy after that, then the red wire being constantly powered is the problem. Otherwise, it is possible there is a problem with the Ai-NET cable connected to the SIR unit.
Sep 26, 2006 | Sirius Satellite Radio Sirius SIR-ALP1...
Sony Ta-sa100wr S-air Surround Amplifier Ezw-rt10a Wireless Transmitter Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
