Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
Samsung LE32R73BDX/XEU Sound no picture and it happened when the screen colour went all wierd with lines then the screen went blank What part do I need replacing??? thanks
Coldcut
  • 1554 Answers
SOURCE: Static lines one screen
as the top is ok and the bottom has this issue.
It looks like the circuit board has a bad connection to your screen.
it is not repairable by you and not an adjustment.
you need to have it repaired.
don't you miss the old wack on the side fix?
Posted on Feb 17, 2008
SOURCE: Samsung LE46M5 46 in" LCD TV
had same problem same amount of time sent it away came back as a dry solder joint on board cn701
Posted on Mar 22, 2008
Shuttle83
  • 1139 Answers
SOURCE: samsung plasma ppm42s3 , picture wobbling,sometimes screen goes blank
Hello arunaik_6,
This looks as if a component has become thermally sensitive. The best way to find this is to use component cooling spray. It looks as if the problem is localized to the tuner section. Take the back off of the TV and turn the TV on, wait until the problem occurs and lightly spray the tuner section with the component cooling spray watch for any reaction, then if this does not work spray the Microprocessor and the LVDS section and watch for a reaction. The set should go back to normal when it does that section is the problem, try to localize the problem to one component. Then replace that component.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 16, 2008
SOURCE: Samsung LCD Tv has no picture but sound
I took it back and got a full refund.
Posted on Feb 06, 2009
SOURCE: SAMSUNG 32 IN LCD LE32R73BDX (MASTER RESET)
* With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
* The TV will turn On with the Service Menu displayed.
go to reset
* Press the {POWER} button to exit the Service Menu.
Posted on Mar 28, 2009
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
My samsung le32r73bdx/xeu has sound but only a very low white rastor on the screen. Is this a backlight/inverter problem? the set is about 5 years old. thanks.
fran_red09, Pay very close attention to the video clips that you find on YOUTUBE and you may be able to make decision on repair/refurbish or just buy a new unit! If you open your unit and happen to find bad (swollen, leaky) electrolytic filter capacitors on the "switch-mode-power-supply-board" please moke note of brand name printed on the "heat-shrink tubing that covers the now swollen aluminum "can" housing!! Yes, it could be a SMPS/INVERTER problem!! Do your research here at fixya. LCD computer monitors use same basic lcd display technology and mode of operation!!! Only they don't have a tv tuner and lots of input selection capability!!! Report back here if you need some assistance and do a comment and rate this response if you feel it has been of some use to you. Bye for now. 12fixlouie
Aug 03, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Re: Samsung : LE32R73BD
hi yes there is, put the tv in standby, on the remote control press info, menu, mute, power the tv will come on with service menu just select reset,, if this don't work you will need to replace the maniboard thanks
shaun
Mar 22, 2017 | Televison & Video
Samsung le26r51bd picture loss.
it is problem your tv high voltage (EHT) not properly supply or creats high voltage
Nov 22, 2009 | RCA D52W19 52" Rear Projection Television
Samsung LE32R74BDX/XEU Picture problem Picture moved to the right leaving 25% of the screen a blue blank area.Has reverted to full screen picture for a few periods but now back on75%. Did this once...
A loose Scart cable caused the problem.I fortunately found this beforetaking the set to the repairers who wanted £117.50 just to look at it.(Samsung appointed repairer)
Oct 06, 2008 | Televison & Video
Flashing led light
Sounds like the circuit board may need to be replaced. Mine did a similiar thing only my picture turned upside down, screen went blank yet had good voice. Samsung tech said the 2 circuit boards were bad and had to be replaced at a cost of $780 in parts plus labor. I bought a new LCD TV, not Samsung.
Aug 27, 2007 | Toshiba TP50G60 50" Rear Projection...
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
159 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
