Question about Microsoft Internet Explorer 7
Sonarca Sound Recorder XiFi 3.8.3 - Microsoft Internet Explorer 7
Sound recording device disabled. enable of soud recording device
1. Open the all users, specific users or groups, or all users except administrators Local Group Policy Editor for how you want this policy applied.
2. In the left pane, click on User Configuration, Administrative Templates, Windows Components, and Sound Recorder. (See screenshot below)
3. In the right pane, right click on Do not allow Sound Recorder to run and click on Properties. (See screenshot above)
4. Close Local Group Policy Editor window. Your done
Jun 04, 2011 | Computers & Internet
Friends say When i speak sounds like Static any 1 know how to change setting or find it in computer. Im using Satellite Fusion
The external microphone itself could be the culprit, or its connection to the 3.5mm port could be flaky. To test the theory do this:
1 Connect an external microphone to the computer.
2 Click Start, point to All Programs, Accessories, Entertainment, then click Sound Recorder.
3 Click the Record button and speak normally into the microphone.
>>>> WIGGLE THE CONNECTION AT THE LAPTOP OR FLEX THE MIC CABLE WHILE RECORDING. Maybe even narrate what you are doing while you record your voice. "Flexing cable near mic, now near plug..." <<<<
NOTE: You can only record 60 seconds at a time.
4 When you have finished recording, click the Stop button.
5 To hear what you just recorded, click the Play button.
6 To save the file, select Save from the File menu.
>>>> If you hear crackling in the playback that correlates with your handling of the cable then bad seating or a bad cable are the problem. <<<<
Adjusting recording quality
The better the quality of the recording, the more disk space the sound file requires. Experiment to find a balance that fits your needs.
1 Open Sound Recorder, if necessary (click Start, point to All Programs, Accessories, Entertainment, then click Sound Recorder).
2 In the Sound Recorder window, click Edit, then click Audio Properties.
3 In the Audio Properties window, adjust the Sound Playback quality and volume, and the Sound Recording volume.
4 Click OK.
Your new settings take effect the next time you record.
Dec 30, 2010 | Toshiba (P000257700) Microphone
My Panasonic DMR-EH55 recorder produces no sound anymore after 3 years of good functioning. There is no sound on TV through the scart interface and also no sound through the analog audio interface to my...
Did you get anywhere with this? I have a similar problem with a DVD/PVR from Woxter. I've tried different cables and changed many of the settings without luck. I've seen a couple of posts which suggest changing country and sound settings (to PCM), so I'll check them out before I call in a repairman to check out the circuitry around the sound output.
Sep 29, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
Hi, While performing voice chat over gtalk, I could hear the conversation on my part - but people on the other side could not hear me. Could you please let me know the possible cause of this...
ok, check your microphone connection . if it connected wrongly please connect it properly . 2.check your microphone recording ability by using "sound recorder".(goto start menu >programs> accessories >entertainment>sound recorder.) try to record your sound. 3.if your sound doesn't record in "sound recorder" check the audio manager.(start menu>control panel>"your audio manager") open it and check the recording sound is mute .if it is mute unmute it . if this information was helpful plese vote for me and write a comment for it. if this information cannot solve your problem plese post a question in this website . i will solve it.
Sep 02, 2010 | Google Talk
Microphone not detecting sound in sound recorder
1. Right click the sound icon in the system tray
2. Click "Adjust audio properties"
3. Go to the "Voice" tab at the top
4. Ensure that a device is selected for the section "Voice Recording"--ensure the appropriate device is seleted--most likely ti will just be one option --make sure it is selected
Dec 19, 2009 | Dell Inspiron 1520 Motherboard
My laptop microphone isnt working
Good day, Hi, to test your laptop mic, open the sound recorder. 1. if you ar using XP, goto START, All Programs, Accessories, Entertaiment, Sound Recorder. If the sound recorder loads normally, press the red button, shout as load as you can, you will see sound waves on the recorder. 2. If the sound recorder does not loads, chances are your mic isn't working properly, Load the device Driver for your mic, you can find the driver on the CD that came with your laptop, if not you may need to go to the Internet to find the MIC driver. 3. If the driver is loaded on your laptop, chances are it may be defective, you have 2 options, 1. replace the mic on your laptop, which requires you to dismantel it, get the defective mic and replace it. 2. just get an external mic. hope this may help.
Aug 02, 2009 | Computers & Internet
Picture/Sound freezes
This model does NOT work well with HD boxes. I would double-check the Philips website, and upgrade the firmware for device since all 3 players were doing same thing.
Aug 13, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Audacity
Use Sound recorder that is included on Windows XP it gives the easiest conversion option for .WAV files.
Converting the File Properties
1. Left click Start, Programs, Accessories, Entertainment, Sound Recorder. If you
intend to do this procedure often it is recommended to drag the Sound Recorder shortcut
icon onto your Desktop for convenience.
2. In the Sound Recorder box click on File> Open
3. In the Look In field locate and select your file. Click Open.
4. The Sound Recorder box is back. Click File> Save As.
5. In the Save As box click Change…
There are all the options listed that you can change and the bit rate is one of the options.
Jul 19, 2008 | Olympus VN-3100PC Digital Voice Recorder
Olympus VN-2100PC Handheld -
May 31, 2008 | Olympus VN-2100PC Digital Voice Recorder
No sound from LG HDD DVD recorder
Same Problem here, have not done anything yet, but I am convinced that it is due to blown Capacitors in the Power Supply......
Apr 25, 2008 | LG RH-4820 DVD Recorder
Microsoft Internet Explorer 7 Logo
56 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
