Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Dyson 14 suction low when using footplate
Wand suction is fine but when using footplate suction is low and won't pick up dirt. Seems to pick up better when in an almost upright position? Tried cleaning filter but no difference. No blockages at all. Brushes working fine.
  • Dyson Master
  • 18,409 Answers
There could be a few things that would cause your Dyson to have no suction. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose udyson 14 suction low when using footplate - 54cb5e5.jpgks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply rdyson 14 suction low when using footplate - 8b33cd4.jpguction port covers at both of these locatiodyson 14 suction low when using footplate - be63721.jpg
Possible Problem #4. If none of the above solutions worked for you, try this last one. The Dyson DC07 models use a clutch mechanism that stops the roller brush from spinning when changed from carpet mode to bare floor mode. This clutch mechanism is a notorious problem with all Dyson models, in fact they were such a problem that Dyson had to redesign the DC07 model to a non-clutch system. Even if yours is one of the newer ones that don't use a clutch, yours still has a belt inside. You can tell if your model uses a clutch or not by the shape of the roller brush. If your brush is a perfect cylinder shape, yours does NOT have a clutch. To check and see if the clutch or the belt have gone bad, first release the handle on the vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet mode. Now while the handle has been released, turn the machine upside down and see if the brushes are spinning. If the brushes are spinning then turn the vacuum right side up and put the brushes on the floor. Can you still hear the brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your brush roll, clutch, or belt have gone bad.
If these solutions still didn't fix your problem, I'd be happy to try and help you further. Just use the Clarification Request, or comment section here on the Fixya repair page.
If this repair was helpful to you, please be sure to rate this repair as helpful by clicking the thumbs up icons in the top right hand corner of the repair. Thanks so much!
Posted on Jan 04, 2013
5 Suggested Answers
  • 142 Answers
SOURCE: Dyson won't pick up heavier particles -
check the hose line from the base to inlet of the canister, there may be a blockage, like hair or plastic (i had a lego block and hair)
clear obstruction, and check the belt.
hope this works !
Posted on Jan 30, 2009
Dysonteam
  • 167 Answers
SOURCE: No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Posted on Apr 22, 2010
Dysonteam
  • 167 Answers
SOURCE: Dyson DC07 bagless - upright mode v poor suction, wand mode ok
From your description of the problem, it sounds as though the bleed valve is activating which only happens when there is a blockage.
We would recommend following the full blockage through as outlined in your user guide or in the Support section on our website at www.dyson.com.
Kind regards
Darran
Dyson Customer Service
Dysonteam
  • 167 Answers
SOURCE: My Dyson 14 Animal seems to not have the suction
Firstly check that the brush bar control on the cleaner head is in the correct position. You may have switched the brush bar off the last time you used it or the dial may hav got knocked when you vacuumed under some low furniture.
If this is in the correct position but the brush bar is still not turning, switch the machine off and remove the soleplate by turning the 3 fasteners on the base of the machine and checking for blockages and remove any threads or hairs around the brush bar.
I would recommend washing the filter if it hasnt been done for a while.
You may find it useful to follow the blockage procedure and filter washing instructions in your user guide, however if you no longer have this available you download a replacement for free via the support section on our website at www.dyson.com.
I hope that this information is useful to you.
Kind regards
Darran
Posted on Apr 27, 2010
Very low suction. hardly picking up dirt . cleaned rollers and all openings.
There could be an obstruction somewhere. Start from the brush bar and work your way back trying to determine where it is.
Mar 14, 2015 | Dyson Dc18 "slim" Upright Model...
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Model DC40, the wand doesn't have any suction when I want to use on stairs, etc.
Hi there, it's Jack at Dyson.
If your DC40 doesn't seem to have suction through the wand but picks up as normal on flooring, it's likely there's a blockage in the wand or hose. To locate and remove any obstructions, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc40/dc40-multi-floor/my-machine-is-not-working/machine-not-sucking-up-well/check-the-wand-and-hosedc40
It's also worth giving both filters a wash as shown in the video below - in normal use this should be done at least once a month. Use cold water without detergent and at least 24 hours for the filters to dry completely before replacing them.
I hope this helps, but if you'd like any further assistance please call our freephone Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 04, 2013 | Dyson DC18 all floors Bagless Upright...
The suction on my dyson is too strong
i don*t know alot about dyson but if it has a thing to raise it up off the floor then that will work
Jan 26, 2013 | Dyson Vacuum Dc 14 Low Reach
Dyson DC14 Animal: Loses suction when in the upright postion and I am using the wand. I have cleaned the top spongy filter. It sort of 'blows' out of the top of the cylinder if that makes sens
Hi Sharon,
I'm sorry to hear you're having difficulties with your DC14. If the machine doesn't seem to be picking up as well as usual through the wand, this may be due to a blockage in the wand, hose or U-bend. The easiest way to check for this is to follow the steps shown in our online support guide:
http://support.dyson.co.uk/support/dc14/dc14-origin-iron/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
Although I note you've cleaned the filter, you might want to check you've washed it as shown in the video below - in normal use, this should be done at least once every 3-6 months. Wash both parts of the filter in cold water without detergent, and allow at least 12 hours for it to dry before replacing it.
This should resolve your issue, but for any further assistance, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can help.
Best wishes,
Jack
Feb 07, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson suction problem
I'm sorry to hear you're having difficulties with your Dyson. If the cleaner won't pick up via the cleaner head and will not stand upright, the valve carriage needs realigning. This is simple to do - please follow the steps shown in the video below.
This should resolve the issue, but for any further assistance or advice with your machine, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dec 22, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Kind regards
Darran
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Low suction not picking up
i would say you have a blockage in the pipe or in the footplate.
Apr 03, 2009 | Dyson DC15 Animal Bagless Upright Cyclonic...
Vaccuum forms in hose- will not pick up dirt
Check your wand for a clog. The DC17 line has common clog issues in its wand. It may be difficult to remove but if you have a long skinny pole(like one for curtains) you can use that to remove the clog.
Dec 05, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
122 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
