Question about Pioneer DEH-P3900MP CD Player
Rca jacks for external speakers have no output
I don't have the manual-have 2 pioneers and brought the wrong manual-anyway i have the appropiate stuff switched on as far as i can tell, but still no output to the rear/external speakers. I don't have a sub woofer connected just the 2 speakers connected to the rca jacks.
    Sergeant:
  • 233 Answers
Rca jacks are a low level output. you have to use an amplifier with rca's. you cannoy hook rca's directly to speakers.
Posted on Jan 19, 2009
  • Skatetrue Dec 26, 2011
    Does this solution go the same for the sub rca hook ups. Trying to run them from the deck but vetting no sound.
How do I connect an external speaker
There are a couple different ways.you ca go
On the back of your tv you could have either,
1 - Optical Audio output
2 - RCA jack audio output ( Red and White color ports )
or
3 - 1/4 inch auido jack. audio out
When you find the jack that matches up to the deice you want to connect hook them up ad then go into your TV settings menu and turn on External speakers
Mar 04, 2015 | Televison & Video
Broken connector in subwoofer connection on receiver
The only thing you do is to open your receivers,then locate the output connector if you see the female RCA jack ,then push it out the broken piece ,that's it
Jul 27, 2008 | Audio Players & Recorders
Power but no sound help plz....
well here we go how do you have your pioneer radio connected .
did you run the radio speaker wire out to the factory speaker or did you have an amp connected to the rca output jacks.
1 well if the radio connect by the speaker wire out the
output chip in the radio is fried and needs repair ....
2. if u have a amp connected to power your speakers for sound
check the amp to make sure you have power and no lose connection or speaker wires disconnected.
3. it also possible that the rca jacks are fried too
I no by experience that pioneer loses ground on the audio output jack (rca) well what we did to fix it is..
take and 18 gauge wire stripe back about 1/2" to 1" of the insulation to expose the copper wire and wrap this around the metal casing of the rca jacks and then ground the wire to a ground point do this for both left and right rca jacks...
radiorepair@windowtintingin239.com
Oct 30, 2013 | Pioneer DEH-P3500 CD Player
The speaker phone on our panasonic KX-T7633 dosn't go loud enough. We are trying to hook up an external speaker, but when we plug it into the headphone jack we just get a buzzing noise. Is there a...
There should be a way to do that. 1st make sure speaker jack is fully inserted. If you still have same problem try normal headphones and see if there still is foreign hum- then if headphones work, check the size of both the jacks to see if there the same- you might just have wrong size jack. If that is not the problem the Impedance(ohm symbol) is probably wrong and the phone doesn't have enough power to drive your speaker.. Use a speaker with same Impedance, you might have to use a speaker with its own power supply to get appropiate volume. You could try your PC external speaker. I hope this has been helpful.
Aug 25, 2011 | Panasonic KX-T7633 Corded Phone
Ok i just got the sub from a sony sswg450 i want to know is there some way to hook it up to my Pioneer home Receiver
Did you get a manual with it? According to the Sony site this speaker originates in Sony MHC-GX450.
"This product bundle includes the following models:
HCD-GX450 - STEREO MINI SYSTEM
RM-SC3 - REMOTE CONTROL for Shelf Mini Systems
SSRG444 - FRONT SPEAKER FOR MHCGX450
SS-WG450 - SUBWOOFER FOR MHCGX450"
Find the manual here and learn a bit about your seprated sub...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX450
See page 7.
As can be seen, the subwoofer has two connections to the mothership, very unlike the standard speaker level (+/-) speaker wire or RCA-Line-Level subwoofer out that 'normal passive or active subwoofers use, respectively.
Not knowing which of those your unspecified Pioneer receiver supports, it is impossible to say. Does your Pioneer have that control jack?
Mini-systems are generally not designed to be pieced out and used with grown-up gear. The absence of standardized connections is the clue.
Apr 17, 2011 | Sony MHC-GX450 CD Shelf System
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
No Audio when disconnect from external amp and hook to speakers
In a radio like your Pioneer and all similar units there are always a pre-amp circuit that feeds a power amp circuit,In some players there are more than one pre-amp circiuts. It is possible and highly probable that the power amp circuit in your Pioneer is shorted, so you still get some audio output , but very little. I believe this is your problem and I suggest that you bring it to a repair shop for an estimate or replace the unit. Good luck and please rate this answer, Thanks.
Apr 12, 2009 | Pioneer Car Audio & Video
Pioneer DEH-P2900MP head unit
There is no power from the rca jacks. Option 1; connect the speaker wires directly. Any aftermarket auto manual (Hayes, Clymer) with wiring schematics will let you know what wire is what in the dash. Option 2; RCA jacks output to an amplifier. There is no power coming from the RCA jacks. They have to be used with the amp. If you chose to use the normal speaker wires, be aware that these radios do not like stock speakers or wire. If you take the time and money to replace all of it, the head unit will last much longer. If you choose to use an amplifier, it will burn out fast unless you replace the speakers and wires immediately.
Mar 04, 2008 | Pioneer DEH-P2900MP CD Receiver...
Bose 901 connection to Pioneer VSX-917v Receiver
any pre-out should work. i believe the bose have a rca jack connector for attaching to the receiver. look at the new receiver connection diagram. any output that is rca designed for use by a recording device will send a signal that the 901's can see.
always check the manual on both before connecting for any precautions.
good luck
mark
Dec 28, 2007 | Bose 901 VI Main / Stereo Speaker
Wiring my tuner-DEH-1800 to Amp GM-5300-T into my 4 speaker system.
In most head units as in your case the Pioneer DEH-1800, there would be 2 RCA female jacks at the rear of the unit. These are your OUTPUTs.
While in most amps including your GM-5300-T, there would similar RCA jacks which would be your INPUTs.
You need to connect the output to the input using an audio cable terminated at both ends with RCA plugs. Further you need to connect the remote trigger on from the head unit to the remote/external amp to switch it on.
A more comprehensive connection diagram is available at page 6 of the GM-5300T Manual which may be downloaded from here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Pioneer DEH-1800 CD Player
Pioneer DEH-P3900MP CD Player Logo
287 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
